Auxillary Battery - Deep Cycle ? or not
Just want to raise this subject, is it best to put in a deep cycle as my 2nd battery under the bonnet or a hybrid type battery.
I have heard that a deep cycle , as it is low trickle charge, would not be able to charge at the same rate as a starter or hyrbid.
eg. running a fridge for say 12 hours takes about 45 - 50 amps.
how long would it take for the car to charge up 45 amps on a deep cycle as opposed to a normal battery
Reply By: Maîneÿ . . .- Friday, Aug 21, 2009 at 19:07
in one word as your asking for a direct yes/no as to 'type' of battery
* DEEP Cycle *
Maîneÿ . . .
AnswerID: 379909
Follow Up By: Member - barry F (NSW) - Friday, Aug 21, 2009 at 19:35
Thanks Mainey for your comment. I have a bit of an interest in this subject at the moment & was wondering if you could elaborate a bit further.
In particular relating to Brians query at the end of his post, which I interpreted as how long would it take for the vehicle alternator to stick 45 amps back in the battery after having used 45 amps out of the battery?
I realise that probably alternators differ in output & that the answer to such a question would be dependant upon many variables such as cable size & length etc.
But as a rule of thumb, how long would it take for an alternator to stick 45A in after taking 45A out & would it differ from a deep cycle battery as opposed to a cranking battery? Thanks & cheers
FollowupID: 647254
Follow Up By: Maîneÿ . . .- Saturday, Aug 22, 2009 at 09:52
barry,
Various batteries charge at different rates, there is no correlation between two different *technology* DEEP CYCLE batteries, ie; when comparing a wetcell Calcium battery to a conventional lead/acid wetcell battery, they will accept charge at different levels depending on their condition and state of charge.
However, *AGM Deep Cycle* batteries will charge more fully and much faster than any wetcell DC.
my fridge draws ~10 Amps (~33% duty cycle)
it's *tested* consumption is: 2.8 ah x 12 hours = 33.6 Amps (indisputable)
some brands claim <1 ah ( therefore: 1 ah x 12 hours = 12 Amps )
100 Amp Alternator does NOT put 100 Amps into battery continuously
The vehicle *regulator* adjusts the charge going into the battery to what is 'required'
To attempt correctly estimate the time to (fully) charge a battery with "45" Amps is dependant on just too many factors to state here and what-ever is posted will be disputed anyway :) :) :)
I will suggest a few hours, that's the reason I use Solar power, it's continuously maintaining the battery fully charged during the day, (as my profile pics show) but that's not relevant.
Maîneÿ . . .
FollowupID: 647311
Reply By: friar - Friday, Aug 21, 2009 at 19:25
Brian B ,from my own experiance, I have had both deep cycle & cranking batteries, I now always match the starting battery with the same size starting battery for the auxilary, this has given me better service than a deep cycle , I never let the auxilary go much under 12 volts with the fridge on.
AnswerID: 379913
Reply By: Sand Man (SA) - Friday, Aug 21, 2009 at 19:40
In my opinion a hybrid battery is simply a compromise.
A true deep cycle battery is specifically designed for continuous current drain and recharging over a prolonged period of time, down to a minimum level.
I have buggered two deep cycle batteries over the years.
One was a wet cell that lasted about 8 months and the other was an expensive Orbital.
In both cases I inadvertently drained the battery well below the minimum level.
When the fridge stopped, I checked the voltage level and saw 10.4 volts which was dead flat. Doing this to a battery will soon destroy it beyond redemption.
I learnt the hard way but experience is a good teacher.
The Engel will try to run on "the smell of an oily rag" until the battery is totally exhausted.
I now use a low voltage cut out device to ensure it doesn't happen again.
As far as what you have heard, ignore it.
The best battery for deep cycle use and one that will charge quicker and more fully than all others, is an AGM (Absorbed Glass Mat) battery.
They are more expensive, are heavier and take up a larger footprint for a given capacity compared with a wet cell deep cycle battery, but are well worth the investment if you look after them.
I have read on this forum how somebody has got great performance out of a starter battery when used for higher current drain devices but I am yet to be convinced this is factual.
Bill.
Bill
AnswerID: 379919
Reply By: Member - Lionel A (WA) - Friday, Aug 21, 2009 at 19:51
While on the subject, the two bits of gear I would like to add to the 4by then call it finished is a winch and a 60L Engel.
I'm thinking 2 heavy crankers under the bonnet, - winch and spotties.
A D/Cycle stand alone in the rear for the fridge only and charged via a roof mounted solar panel.
Makes sense to me, how about others ?
Cheers.....Lionel.
AnswerID: 379922
Follow Up By: Sand Man (SA) - Friday, Aug 21, 2009 at 23:49
Lionel,
Why the need for two heavy crankers???
I believe you would be wasting your money.
Both the winch and the spotties are usually only used while the engine is running and therefore the alternator is feeding the Cranker with power as it is being used.
The winch is only ever used for relatively short durations and therefore will not drain the battery when used as above.
A deep cycle battery is best used in a dual battery configuration, regardless of whether it is portable, remote or whatever. In this configuration it is also charged by the vehicle alternator when travelling, or if removed from the vehicle, by a solar panel or other power source.
Bill.
Bill
FollowupID: 647298
Follow Up By: Member - Lionel A (WA) - Saturday, Aug 22, 2009 at 08:24
Thanks Bill, does seem a little over kill now that I think about it.
Cheers....Lionel.
FollowupID: 647308
Reply By: Mandrake - Friday, Aug 21, 2009 at 20:45
Don't you also have to be careful of the Volts going into an AGM -
Is it OK to connect directly to the alternator or do you need a
regulator somewhere to drop the voltage to max 14.6 Volts ?
Or is that only Solar input ?
Mandrake
AnswerID: 379937
Reply By: Maîneÿ . . .- Friday, Aug 21, 2009 at 22:26
# Cranking wet cell batteries are made to start engines and drive winch's.
Engine starters and Winch's need a very large starting current for a very short time.
Cranking batteries may last for thousands of cycles in *normal* starting use.
Cranking batteries are rated at "CCA"
# Deep Cycle wet cell batteries are designed to be safely discharged down as much as 50% time after time. The major difference between a genuine deep cycle battery and others is that the plates are of a SOLID Lead plates.
This gives less surface area and less "instant" power like starting batteries need.
Deep Cycle batteries are rated as "AH"
# Marine wet cell batteries are usually a "hybrid" and fall between the Cranking and Deep Cycle batteries.
Marine batteries are rated as "MCA"
Maîneÿ . . .
AnswerID: 379963
Reply By: Member - Mike W (NSW) - Saturday, Aug 22, 2009 at 09:20
Hi Brian
I run a a cranking battery and a deep cycle battery in my rodeo. It works well for me.
It is a 750cca main battery and a 100ah deep cycle. I only have the fridge and led lights running of it so its usually last 3 or 4 days before the need to recharge
I have heard(from my local battery and tyre store) that AGM battery will only take a charge that is 10% of its total AH capacity. That is a 75ah battery will only accept a 7.5 amp charge. (not sure of the accuracy of this).
I do like the ability to store the agm inside a trailer or caravan due to it not giving off any fumes (you can even use it upside down).
AnswerID: 380007
Follow Up By: Mrbrush - Saturday, Aug 22, 2009 at 10:36
I have a 100ah AGM, and bought this DC digital amp current meter thing from Jaycar.
I ran the battery down a little then connected this gadget inline of a 15amp 3 stage charger. and it was pumping the full 15amps into the battery.
FollowupID: 647315
Reply By: kiwicol - Saturday, Aug 22, 2009 at 21:48
Deep cycle batterys are waste of money for most types of camping and caravanning, exspensive, hard to fully charge to 100% from a vehicle alternator. The warranty offered is not worth anything.
The normal cranking battery offers the same as any more expensive battery on the market. Two cranking batterys fitted to a 4by running fridges,lights,showers,sterios,and what ever is all thats needed to run a camp site with out any problems. They are more able to be charged to a higher % of their capacity than any other battery, and are able to be replaced in more towns in oz. I have over a 25- 30 yr period of camping got on a average of 3 yrs life from cranking batterys, and now only have to pay about $180 per battery. I figure thats not to bad.
I speak from experience, some of my camping trips have been 8 months,charging only fron the alternator and a cheap 3 amp battery charger plugged in when in a carravan park. Have never been let down from a flat battery yet. Col
AnswerID: 380079
Follow Up By: Richard Kovac - Saturday, Aug 22, 2009 at 22:08
Col
That is very good advice, I two run two starter battery's in the Troopy.
I'm not sure if a deep cycle battery can start the 4.2 TD Troopy if the main crank battery craps itself, but I would rather drink hot beer them not to be able to start her out in the desert
Richard
FollowupID: 647392
Follow Up By: Maîneÿ . . .- Sunday, Aug 23, 2009 at 01:34
Col,
I won't suggest your talking rubbish, it would be just soo unkind, but you must understand two Cranking batteries are the same price as a GOOD Deep Cycle battery, yes based on your own numbers.
I use AGM's with a two (2) year warranty, so I don't have any problems, they retail @ ~$360 (same as your 2 batteries) and they do fully charge from an Alternator.
They have a stated service life of 10 years, that equates to only $36 per year.
Your Cranking batteries cost you $120 per year, again using your own numbers.
I'm sure most people would rather spend $36 per year on batteries, than the $120 per year your paying.
With 2 AGM's it's only $72 per year, which is still less than what you are (happily) paying, and with three (3) AGM's it will still cost less than you have to pay per year.
They will also get superior performance from AGM's.
There is not a *web site* on the net that will even suggest a Cranking battery is superior to an AGM Deep Cycle battery for running a fridge or accessories, if you honestly believe there is, then please post the link and prove me wrong.
Richard, yes AGM DC's will crank a diesel, I've used mine to jump start my GF's troopy.
Maîneÿ . . .
FollowupID: 647402
Follow Up By: kiwicol - Sunday, Aug 23, 2009 at 16:22
Hi Mainy, for the price you pay for one battery i get two, and they to have 2 year warranty.
As for charging from your alt, no battery can be fully charged to 100% of its capacity by your vehicles alt, this is proven science. This is where deep cycle batterys fail because they are designed to be fully charged from discharge.
I never suggested cranking batterys are better than deep cycle, but i do say for the average joe and his 4by the cranking batterys are a better way to go.
Try reading the Rivers books on this exact subject and you may learn some interesting facts, as i did.
If you have a smart charger try fully charging your battery, then go for a days drive just using your normal power usage in your vehicle, when you get home put the charger back on and see how long it takes to get the battery back to 100%, This is a simple way of seeing that the alt doesnt fully charge the battery.
I also never stated that a deep cycle battery wouldnt start a vehicle.
In my travels i have met several people who have got rid of the deep cycle and gone back to normal batterys as they havent been able to fully charge the deep cycle.
Cheers Col
FollowupID: 647452
Follow Up By:- Monday, Aug 24, 2009 at 15:13
who says you can't charge your AGM fully from the alternator?
Wire up/plug in your 12/240 inverter to the main batt and run your AGM charger off it while cruising along....
Just keep the VA rating of your inverter twice that of your max charger rating and your all set. E.g if your charger can deliver a max 15A, you want an inverter of 400VA or greater.
best, mr.batteryvalue
FollowupID: 647585
Follow Up By: Maîneÿ . . .- Monday, Aug 24, 2009 at 15:42
Col,
What brand and capacity are these Cranking batteries you use ?
As to people not being able to fully charge a Deep Cycle battery don't you think it's the fault of the charging system ?
Maîneÿ . . .
FollowupID: 647588
Follow Up By: kiwicol - Monday, Aug 24, 2009 at 17:27
Mainy, They are yuasa made by century in australia, of hand not sure of the cca, and from memory they are 13 platers.
Its just not deep cycle batterys, but all batterys that will not charge to 100% of the batterys capacity. You are partially right it is tha fault of the chargeing system, by design only. The alt cannot read when a battery is full so by design the are made to put out heaps of charge after starting, to put back what the starter took out, then tapers of to put out a very small % of what the alt can deliver. This is to stop overcharging, which means the battrery doesnt get charged to its absolute capacity.
Deep cycle batterys are designed to be slowly charged, and the best way is with either a smart charger, or a solar pannel with a regulator. You will be suprised how much longer your fridge will run of the battery if charged by one of these methods.
Another good charger is the christy generator, it has a car alt fitted, but has a manual switch for low charge or the full 55amps for as long as the genny is running, in this mode you can overcharge your battery if you dont use the led read out fitted, or a multi meter to check battery capacity.
The Rivers books are very good reading and explain it better than i ever can.
Another good investment i found, is the c- tek smart charger, i got the 2500 and leave it connected to the 4by 24/7 when not using it, i also have the fridge connected all the time.
Col
FollowupID: 647602
Follow Up By: Member - barry F (NSW) - Monday, Aug 24, 2009 at 17:54
Hello, would you care to comment on the suitability of a Powertech intelligent Full Automatic Battery charger, Model # MB 3612 for the charging of a deep cycle 120ah/20hr AGM cyclic.
The charger was bought from Jaycar. Many thanks
FollowupID: 647611
Follow Up By: kiwicol - Monday, Aug 24, 2009 at 18:22
Hi Barry, sorry i dont know any thing about them, it sounds like a smart charger. The c-tek i have has 8 different stages, and can be left on indeffiantly and will handle having draw on the battery while charging. Col
FollowupID: 647617
Follow Up By: Maîneÿ . . .- Monday, Aug 24, 2009 at 22:05
Col,
from what I understand they may be N53's, is that correct ?
( 225 x 170 x 220 )
Maîneÿ . . .
FollowupID: 647677
Reply By: Damian007 - Friday, Aug 28, 2009 at 13:18
Ok, I've read enough rubbish.
A vehicle alternator is Capable of fully charging a normal Lead Acid Battery. You can't get home, take a battery out of your vehicle and put it on a charger in order to tell if it's fully charged or not.
Normal, Wet Cell, Lead acid batteries require around 13.8-14.2 volts in order to charge correctly. A vehicles Alternator is designed to maintain a Constant Voltage NOT constant current. If you have a 55 amp Alternator on your vehicle that alternator is capable of producing 55 amps at whatever volatge the Alternator is set at via the voltage regualtor installed in the Alternator.
Bosch Alternators are available with a couple of different "Voltage Regulators". Most modern Vehicle Alternators will maintain a Constant Voltage of 14.2 volts. Some Early Bosch Alternators were available with 14.5 volt regs.
In order to tell if your battery is fully charged is to take a Specific Gravity reading of the Sulphuric Acid in the battery. The other way is to measure the cell voltage.
There's enough info on the internet to find about how to Chrage Batteries, Which Batteries are best for which application etc.
I'm a Qualified Auto Electrician. Been in the trade now for 20 odd years and I still hear these same arguments over batteries.
If it were me and I needed a dual purpose battery, A marine Battery is probably the best for this use. It's designed to take a lot of punishment. I'm not sure but I think a marine battery has fiberglass seperators in order to make them tough.
Anyhow, Keep arguing amongst yourselves about what's best and why batteries don't do this and don't do that. Doesn't anyone read the Exploroz Articles? There's a good one one here about What Batteries You Might Need..
AnswerID: 380829
Follow Up By: Maîneÿ . . .- Friday, Aug 28, 2009 at 15:58
Damian,
You say-> " If it were me and I needed a DUAL PURPOSE battery, A marine Battery is probably the best for this use. It's designed to take a lot of punishment. I'm not sure but I think a marine battery has fiberglass seperators in order to make them tough "
The original question is: "Auxillary Battery - Deep Cycle or not ?"
This battery is N0T going to be used as a Cranking and also a Storage battery, it's only a dedicated DEEP CYCLE storage battery, used for running Auxiliaries like fridge etc.
My question to you because you've "been in the trade now for 20 odd years" would be:
is an *AGM Deep Cycle* battery more suitable as a *DEDICATED AUXILILLARY* Battery, than either a wetcell Deep Cycle battery or wetcell Marine battery ?
Maîneÿ . .
FollowupID: 648273
Follow Up By: Damian007 - Friday, Aug 28, 2009 at 17:39
Actually, the head of the thread is what you say but the question explained is "Deep Cycle or Hybrid Battery".
Also, I wasn't actually replying only to the Original poster as I was to everyone who posted a comment. I mean, You have one person stating that a Vehicles Alternator cannot charge a Wet Cell battery to it's fully charged state. Well, I beg to differ.
Years Ago, (When I started my first Shop) I looked at batteries for this very use, I looked at all types of batteries for all sorts of uses.
Marine batteries used Fiberglass separators then and I'm not so sure they do now (Could be Plastic) I can only guess they still do. The reason for Fibreglass is to handle the Vibration, heat and other sorts of knocks etc.
In Answer to your second question: An AGM battery needs to be carefully looked after. For one, you cannot leave an AGM battery in it's discharged rate for too long or it will deteriorate very quickly. You must charge an AGM Battery as soon as you can, even it's been used to 75% of it's charge. If you want to get the best life out of a AGM you need to take in it's special charging characteristics. 14.4v all the way to 15.5 volts for some.
I have a an N70z Type Wet Cell Marine battery in my Caravan, It's been in and out of Boats and Caravans for the past five years but in saying that, I do take care of it. Specific Gravity for each cell shows it's still in good nick. Although I wouldn't take it as gospel. Any Battery can fail just when you need it the most.
An AGM Battery will last a long time too if you look after it. But Personally, I prefer the Marine Battery because I know it will allow me to Crank a 200hp Mercury or will last me the weekend out in the bush.
If you were using Solar Panels to charge batteries, then I would have to go with an AGM as it is charging and discharging everyday.
The main problem when using a "Cranking Battery" is everytime you crank a car with it and Charge it, it sheds some lead of it's plates and therefore will sooner or later fail because of lead build-up in the bottom of it's casing (Shorted Cells) or Plate Buckling.
I do know of people getting 7 years out of their car battery in a car. Doesn't everybody?
Anyhow, Thats my 2 cents worth.
PS, When I spoke to the Battery Rep about batteries he had the same opinion as me. I can't mention the company.
FollowupID: 648287
