Xtrail V Forrester........dare I ask??
Submitted: Sunday, Aug 30, 2009 at 19:31
ThreadID: 71899 Views:8064 Replies:11 FollowUps:13
Howdy all,
Been off the forums for a while doing some........ ahhh........'work' is what I think it is called. Anyway, I have worked that damn hard that the beancounter has decreed that I should salary sacrifice a vehicle on a full operational lease. So I have made enq's of the firms salary sacrificing guru and have been given a choice (?) . Subaru Forrester or Nissan Xtrail. No, I cant have any sort of a ute or a shiny new landrover/Patrol/Cruiser due to some freaky FBT law and the apparent dislike leasing companies have to real 4x4's. (and probably my intended use thereof)
So that is my conundrum. Now, being a landrover owner, I am used to being made to camp next to the dunnys, and be sat on the downwind side of campfires on this forum so do your worst. If you had a choice which one would you choose/not choose and why?
BTW neither vehicle requires a fridge, tyres, lift kits, driving lights or storage drawers so that should thin the debate out a bit.
I think I am going to regret this post but anyway..........
Craig
Reply By: Member - Toyocrusa (NSW) - Sunday, Aug 30, 2009 at 19:47
Hi Craig. From what I have seen of the Xtrail diesel they dont seem too bad. The 2.5L Forrester is a bit underpowered if you want to tow anything. Regards, Bob.
AnswerID: 381151
Follow Up By: Member - Craig M (QLD) - Sunday, Aug 30, 2009 at 19:49
Thanks Bob
Power comment duly noted as I tow a heavy trailer regularly.
Craig
FollowupID: 648569
Follow Up By: Member - Toyocrusa (NSW) - Sunday, Aug 30, 2009 at 20:36
Craig. Had a friend trade in a 4 year old Forrester on a Hyundai Santafe CRD in may this year(both auto's). He tows a 16ft Caravan. Just completed 1500Klms towing the van and said there was no comparison. The diesel ate it in terms of torqe and fuel economy with ample room and comfortable ride as well. May be another vehicle in the lease range. Bob.
FollowupID: 648580
Follow Up By: Member - Craig M (QLD) - Sunday, Aug 30, 2009 at 20:43
Don't know about Hyundai.
I know the I30's have been popular at work.
Will ask the Q.
craig
FollowupID: 648583
Follow Up By: Fiona & Paul - Sunday, Aug 30, 2009 at 23:00
Graig I have a 2.5 Forester X with high/low range and I agree with Bob about being a bit underpowered, but for fuel consumption when I take it easy the Forester gets not too bad mpg.
In the four+ years we have had the Subie we have towed a 680kg campet trailer with 60ltr water tank - probably 950-980kg loaded and (first time towing for me any further than to the tip). I got stuck once through lack of power on a short sharp but pretty steep bit of ground (off-road), really struggled to get it start moving again that time and we averaged;
- 6.2km/ltr while travelling very fast to get SWMBO out of 40C heat & into motel;
- 7.2-8km/ltr travelling at 95-100kph;
- 8-8.7kmltr travelling 80-90kph.
We got into a Coromal Magnum 340 Rally XC camper, 980kg with 80 ltr water tank, big toolbox - probably 1300kg loaded and if I stopped on any steep suburban pinches around Blue Mountains I had to work hard to get it moving.
All above averages were down 7-8% with the Magnum.
Now we have a Coromal Compac Caravan 860kg and we were down again probably another 5-7%, but recently travelling south from Tibooburra to Broken Hill (60% black top) I averaged;
- 8.6km/ltr travelling around 20-70kph on the dirt and 75-82kph on the blacktop.
I found that travelling 78-83kph between Bourke - Cunnamulla and then out to Thargomindah was the most economical speed to travel at.
The occasional high speed burst to clean the cobwebs out has gone completely out of my time behind the wheel, especially as I can get another 60-120km out of a tank of petrol.
When travelling from Noccundra to Tibooburra, Fionas first trip over 5km on dirts roads terrified her as we had a brand new van (not even off-road), I got down to 10kph when I had to I felt I had made it when one joker and his bride driving a new Toyota and towing a hughe new off-road van going north on a really rocky section, throwing dust and rocks all over the place didn't slow down but managed to wave madly as they went past and we came to almost a complete stop. I saw it coming but only because someone here had related a similar experience.
One more thing, the Subaru has low entry and exit, not a lot of ground clearance and in the very sandy sections (Noccundra -Tibooburra) I think I was doing a bit of grading and chewed a lot of petrol.
Hope this helps Paul & Fiona
Paul H
OZ Downunder
FollowupID: 648621
Follow Up By: Member - Craig M (QLD) - Monday, Aug 31, 2009 at 06:48
Thanks Paul
Fortunately I have the landie for the real off road stuff. The Xtrail/Forrester will only be a drive car from our property to work and back each day (around 70k round trip) The driveway at home can get a bit interesting in the wet season hence the requirement for something better than a sedan.
Work are reccomending both these vehicles over sedans (all sorts) due to better resale. Apparently a Commodore/Falcon is worth a hand full of stones at the end of a 3 year lease with 75000 k on them.
Craig
FollowupID: 648636
Reply By: Gone Bush (WA) - Sunday, Aug 30, 2009 at 19:52
Go the Subaru.
Then you could do this:
http://www.youtube.com/watch?v=BkNzkutTiGs
AnswerID: 381152
Follow Up By: Member - John F (NSW) - Sunday, Aug 30, 2009 at 20:15
My vote also for Subaru, simply on engineering and build quality. Have had a WRX since 2001 now with 186k, only normal maintenance, except rocker cover gaskets replace recently. Still original clutch! If the Xtrail diesel mentioned above is like other small Nissan diesels the torque is developed way too high and this is not great for towing, especially in diesels. The Subarus have very low levels of NVH due to their superior engineering, IMHO.
Regards, John.
FollowupID: 648575
Follow Up By: Member - Craig M (QLD) - Sunday, Aug 30, 2009 at 20:24
Thanks John,
How well do they compare on interior size though? The subaru seems a lot smaller especially in the cargo area.
Craig
FollowupID: 648576
Follow Up By: Madfisher - Sunday, Aug 30, 2009 at 20:59
John and Craig,
We run Foresters and xtrails plus Ravs.Believe it or not the xtrail is far superior to the foresters in nvh and general driveabity. All our ferry drivers prefer the Xtrail also as a road vehicle, in fact one brought one himself after driving the work ones. Now if it was my dollars I* would go the Forester purely for reliabity and resale.
Cheers Pete
FollowupID: 648587
Follow Up By: Fiona & Paul - Sunday, Aug 30, 2009 at 23:03
Thanks for the backup Pete, but, I wonder if I could fit a WRX motor into the Forester - maybe!
Paul H
Remember we have to start arrangements for the Bathurst members Xmas do.
Paul H
OZ Downunder
FollowupID: 648622
Follow Up By: Madfisher - Monday, Aug 31, 2009 at 10:13
LOL , might lack in low down torque.
Cheers Pete
FollowupID: 648660
Follow Up By: HGMonaro - Monday, Aug 31, 2009 at 14:58
Paul, the factory do that for you... it's called a Forester XT (it's down a few KW ion a WRX but same motor)
FollowupID: 648704
Reply By: Bonz (Vic) - Sunday, Aug 30, 2009 at 20:48
The Subie would be a better all around vehicle. If you already have a Landrover then you'll need something comfortable to drive to and from the repair shop. The Subaru will equip itself perfectly.
Space wise they are much of a muchness, the Subie is more of a comfy rather than a tinny vehicle.
AnswerID: 381161
Reply By: Member - Captain (WA) - Sunday, Aug 30, 2009 at 20:56
Hi Craig,
Are you restricted to a particular leasing company? I have my 200 on a full novated lease and check out in my profile the accessories that I have fitted (the lease company is aware of all these + insurance company too). With my previous vehicle (a Patrol) I used a different lease company and still had my full choice of vehicle and it was also very modified for touring.
The only issue with FBT that I am aware of is that if you go over the luxury car limit (~$54,000) then the vehicle repayment tax break is limited to that amount. However you still get the benefit for all operational costs like fuel, servicing, tyres etc... If you are happy with a Subaru/Xtrail then fine, but if you would prefer a Landrover/Patrol/Cruiser then may I suggest that you check out different leasing companies?
The main (only?) thing that affects the FBT is the number of kms you do and you are far more likely to do more kms in a vehicle you can take long distance touring. I am sure that after having a Landrover you would be very disappointed in any AWD vehicle.
Captain
PS. If you must have a Subaru/Xtrail, then IMHO go the Subaru for resale value.
AnswerID: 381165
Reply By: Sir Kev & Darkie - Sunday, Aug 30, 2009 at 20:59
The petrol X Trails are very very thirsty when you tow. I haven't driven a diesel one yet.
Cheers Kev
Russell Coight:
AnswerID: 381166
Follow Up By: Member - Jo Q (NSW) - Monday, Aug 31, 2009 at 14:37
That's not something I need to hear! lol..... Going on a month road trip in 3 weeks time from Sydney, hopefully up to the Daintree. Just got a new petrol x-trail in February and will be towing a camper trailer the whole way. Only done short trips so far, so looks like my fuel consumption is going to be interesting!
In general though, love the car - heaps of room and a smooth ride.
FollowupID: 648698
Follow Up By: Member - steveinoz (NSW) - Monday, Aug 31, 2009 at 17:23
Sir Kevvvvvvvvvvvvvvvvv...
I took mine to Cape York with my Tvan. 14.2/100 on the round trip.
FollowupID: 648722
Reply By: Member - Mike W (NSW) - Sunday, Aug 30, 2009 at 21:09
Hi Craig,
My Vote is for the xtrail (diesel) The dragon in law has one and it impressed me when she followed me on a couple of reasonable rough tracks down to the Macquarie river.
The Rodeo did it easyish and the x trail didn't get stuck once.
A guy who lives in my town took a petrol x trail across the Simpson last year(not something I'd recommend). It struggled big time and was lightly loaded in a convey But it did make it but he did say that it just wasn't the same afterwards
My only Bad point about it is that the soft roaders aren't built like soft roaders and wouldn't take regular offroading very well.
Cheers Mike
AnswerID: 381170
Reply By: Member - Phil G (SA) - Sunday, Aug 30, 2009 at 21:14
We've owned a couple of Xtrails and cannot fault them.
But if buying a manual, I'd get the diesel.
If buying an auto, then get the petrol Xtrail with CVT.
Look at the specs and you'll understand why.
AnswerID: 381173
Reply By: Member - Craig M (QLD) - Sunday, Aug 30, 2009 at 21:50
Thanks everyone............
Time for the test drive tomorrow I think. We have both flavours in our motor pool so it should be easy to to the A/B
Might explore the other lease companies as suggested , However being in the employ of the Government (higher education sector) I might get my wings clipped a bit..
Craig
AnswerID: 381181
Reply By: Member - cuffs (SA) - Sunday, Aug 30, 2009 at 21:59
I'd never buy an Xtrail, they can't go any where and only get 10lt/100km when towing.
Damm soft roaders lol.
AnswerID: 381183
Reply By: Member - TonBon (NSW) - Monday, Aug 31, 2009 at 13:08
Another vote for the Subaru having previously owned one. I was also told that Subaru are bringing out a 4cyl Boxster Diesel, might be worth the wait.
AnswerID: 381253
Reply By: Member - steveinoz (NSW) - Monday, Aug 31, 2009 at 17:11
Craig M...
I took my Xtrail Petrol, Auto.to Cape York in July/Oct this year towing a Tvan. Did the trip with no problems. Would not of felt so happy doing it in a Forester.
AnswerID: 381291
