Rear spring upgrade for Mazda Bravo, BT50 or Ford Ranger.
Submitted: Sunday, Aug 30, 2009 at 20:30
Member - DW (NSW)
Hi all,
Have any of you had any experience, luck or whatever with upgrading springs for these vehicles?
I have fitted supposedly heavy duty springs but they have done what Toyota springs often do, sag.
When I tow I do have a fairly high ball weight of around 180 kgs plus what may be on the tray. The trailer is single axle.
Look forward to you reply.
DW
Reply By: Member - Murray R (VIC) - Sunday, Aug 30, 2009 at 20:52
DW
I have a Bravo and had sag problems when I fit my tray camper. I solved this by fitting load assist air bags. They allow you to adjust the rear ride height then load is apllied, also give a smoother ride with camper on.Cost about $500 and fitted them myself.
Regards Murray
PS
From memory I brought them from Pro Bag in
Sydney
381163
Reply By: Foxhound (WA) - Sunday, Aug 30, 2009 at 21:04
My 76 Series LandCruiser suffered from the same problem. The easy fix but at some expense is to fit Firestone air bags. For leaf springs such as yours they fit between the chassis and the diff housing and become the primary load carrier. They are easy to fit and can be air adjusted to suit any load, they also improve the ride especially on corrugations as you are riding on air with
the springs taking the secondary load. They cost around $700 plus fitting costs if you can`t do the fitting yourself. Goggle up Airbag Man for more info, I am very happy with
mine.
381169
Reply By: Geoff M - Monday, Aug 31, 2009 at 09:18
I have upgraded
the springs on my BT50 with heavy duty Ironman springs and foam shocks. These have been good, and the service from Ironman excellent.
381222
Follow Up By: Member - DW (NSW) - Thursday, Sep 03, 2009 at 06:52
Geoff
Do you know what level of strength the Ironman springs were?
DW
649274
Reply By: Member - DW (NSW) - Thursday, Sep 03, 2009 at 06:53
Thankyou all for your replies. Much appreciated.
DW
381719
Reply By: Geoff M - Thursday, Sep 03, 2009 at 07:53
