Gas struts
Submitted: Thursday, Sep 10, 2009 at 18:19
ThreadID: 72165 Views:6088 Replies:8 FollowUps:4
I have a camper with a door held up by gas struts. Only problem is they are too weak. They will hold the door up but a slight wind and it drops down to half way and I have already walked into it a couple of times.
My question is - the current struts are 200n - to up size how much more should I go. I found some similar ones but they are 580n - is this too much - like would I nearly break my door when it opens and need two heavy blokes pulling down to shut or is would 580n be alright if only a bit stiff.
And where is the best place to buy struts - like is there a place on eBay or some local shop - Mandurah or Perth. The local auto shops have a very limited supply and insisted they needed a car make and model - even after explaining it was on a camper.
David
Reply By: Gone Bush (WA) - Thursday, Sep 10, 2009 at 18:31
David,
contact the people who make canopies, Rosco's etc. I'm also sure that TJM in O'Connor would know a gas strut supplier. They did a few years back when I spoke to them but I can't remember who it was.
AnswerID: 382664
Reply By: mazcan barry - Thursday, Sep 10, 2009 at 18:36
hi there
if you google
gas struts/western australia the search will come up with several suppliers that you can contact
hope this is a help as they are availuble in varios lengths and pressures not having seen your door makes it hard to suggest a pressure rate but you may find 300 or 400n will do the job
mazcan barry
AnswerID: 382665
Follow Up By: mazcan barry - Thursday, Sep 10, 2009 at 21:07
hi again
if you look in the wa yellow pages on page 1257 gas struts there is 3 entries for w a supplers
gsr enterprises
23 fairbairn rd coogee
0414393595
selectrix-selectlok
gas strut range
factory 8/96-100 briggs st welshpool
94705433
strut specialists
u5/35 guthrie st osborne pk
94459119
FollowupID: 650283
Follow Up By: Serendipity of Mandurah (WA) - Thursday, Sep 10, 2009 at 21:15
Thanks Mazcan Barry
Asking around I have heard that 'The Strut Specialists' in osborne pk are the go. And the can regas to whatever pressure your need.
FollowupID: 650285
Reply By: mazcan barry - Thursday, Sep 10, 2009 at 19:14
hi
struts.com.au in the east will help you work out what pressure rated struts you need for your camper door
i'd suggest 350 or 400 should do it but then i haven't seen the door
hope this will help mazcan barry
AnswerID: 382669
Reply By: Welldone WA - Thursday, Sep 10, 2009 at 19:54
Hi David
There is a place [that I can't quite remember the name of] in Carlisle on the corner of Briggs and Harris streets that has all sorts and sizes of gas struts .
I got new ones for the work/camper trailer there a couple of years ago , I just took in my old ones and they matched them up with new ones for around $20 each.
Hope this helps
Welldone
AnswerID: 382675
Reply By: Wilk0 - Thursday, Sep 10, 2009 at 20:25
Hi David,
I put new Gas struts on my cub. I put 800n struts on it, Replacing the 750n ones on it.
They are rated by taking a zero of the newtons to give you an approx rating in kg's.
ie 800n = 80kgs
I got mine from a local caravan/smash repair centre
AnswerID: 382678
Reply By: Member - Gaz@Gove (NT) - Thursday, Sep 10, 2009 at 21:07
If you don't have any luck locally, there is an online store "ovesco.com.au" selling gas struts. Was looking for some for my camper last night and came across their site.
Gaz.
Mmmmmmmm, now where do we go next?
AnswerID: 382683
Follow Up By: Serendipity of Mandurah (WA) - Thursday, Sep 10, 2009 at 21:14
Thanks Gaz
That is an awesome site. I have book marked it for future use as well.
FollowupID: 650284
Follow Up By: mazcan barry - Thursday, Sep 10, 2009 at 21:49
hi gaz
have just had look at that site and well what a little beaudy it is they've got stuff iv'e been looking for 4 a while
cheers and thanks
mazcan barry
FollowupID: 650289
Reply By: pop2jocem - Thursday, Sep 10, 2009 at 22:20
Try www.uesint.com/index.php they have shops in Malaga and Belmont. They specialise in supplies for motor body builders. You'd be surprised what they have
Cheers Pop
AnswerID: 382690
Reply By: Sand Man (SA) - Thursday, Sep 10, 2009 at 22:26
David,
My advice is to go to a gas strut installer. You should be able to find your nearest one by yellow pages or Google.
There may be nothing wrong with your struts that a bit of extra pressure won't fix.
An installer can test them and replace only if necessary.
Bill.
Bill
AnswerID: 382694
