Patrol dual cab conversion?
Submitted: Monday, Sep 28, 2009 at 11:21
ThreadID: 72591 Views:14015 Replies:9 FollowUps:6
Hi all,
I'm looking into converting my '99 GU patrol to a dual cab ute, and can't seem to find any places that do it in Perth. I know TL engineering used to do this sort of thing but have been told they have closed down.
I've done a google search and searched the archives of this fine forum and can't find any in W.A.
I know Roachie has a dual cab Patrol - so if your watching, any advice mate?
I don't want to extend the wheel base or move the rear diff - just a straight cut off and put a small tray top on ( longest I can fit without moving diff ). I'm not any where near smart enough to take an angle grinder and welder to it myself, so if any one can point me in the right direction it would be much appreciated.
Any idea what sort of cost I would be looking at would also be helpful?
Thanks in advance, Keith
Reply By: wafarmer - Monday, Sep 28, 2009 at 11:43
I have a mate had his TD Landcruiser wagon cut and extended and turned into a spacecab trayback to carry a slide on camper in Perth.
I will try to find out who did it but not cheap.
I know Unicorn body builders used to do them.
wafarmer
AnswerID: 384900
Follow Up By: stumbly1 - Monday, Sep 28, 2009 at 11:58
Thanks mate, I'll try and look up unicorn body builders.
The not cheap part doesn't suprise me that much but hoping to get out of it for under 8k, any more than that and it will become unviable.
FollowupID: 652675
Reply By: Member - Frogman (WA) - Monday, Sep 28, 2009 at 12:19
Hi Keith, was at TL engineering last month.and they still have their web site so give them a call on 08 9279 54 66 . Or Unicorn Tel : 08 9455 1434 .
Hope this will help. John.
AnswerID: 384906
Follow Up By: stumbly1 - Monday, Sep 28, 2009 at 12:33
Thanks John,
I was trying their website yesterday and wouldn't come up, then a mate told me they closed down! Good to know their still up and running, I'll give them a ring, thanks for the contact details.
Cheers, Keith
FollowupID: 652679
Reply By: Member - Malcolm (Townsville) - Monday, Sep 28, 2009 at 16:10
Hi Keith
I investigated doing the same thing with my 2005 Patrol with Creative Conversions in Brisbane (sorry son't know anybody in WA). But, this will give you an idea of the costs involved. $15,000 for dual cab ute.
I'm like you. Too scared to take a cutting wheel to a perfectly good vehicle.
FYI, I already have an old Sahara ('84) that has been cut n shut. Check out my pictures. Was/am/maybe/maybe not selling it. Too expensive to replace in the same configuration. LOL
Malcolm
living the 'good life'
AnswerID: 384938
Follow Up By: joff1 - Monday, Sep 28, 2009 at 22:03
$15k is for an extended conversion. More like $10k for a cab only job. Well at least it is on a cruiser.
FollowupID: 652737
Follow Up By: Member - Malcolm (Townsville) - Tuesday, Sep 29, 2009 at 08:41
joff1
You are correct. I was talking to them about extended Dual Cab with GVM upgrade. $9,950 for Dual Cab only. $13,950 to include extention.
Malcolm
FollowupID: 652763
Reply By: Member - Stuart P (WA) - Monday, Sep 28, 2009 at 18:38
russel at 52 dellamarta rd wangara
AnswerID: 384965
Reply By: Member - Phil G (SA) - Monday, Sep 28, 2009 at 19:31
When its being done, can I suggest you get the chassis reinforced in the usual places they bend and if you have rear coil springs get the towers strengthened.
And when you load the vehicle, keep the heavy stuff as far forward as possible.
AnswerID: 384976
Reply By: Bonz (Vic) - Monday, Sep 28, 2009 at 21:13
You should expect $15000 with a tray supplied Al or steel. I know a guy in Vic who has done many cruisers and a couple patrols and thats what his charges are.
AnswerID: 384993
Follow Up By: Best Off Road - Monday, Sep 28, 2009 at 21:56
I know him too.
His work is of such a standard that the finished product looks like it came out of the factory that way.
Al Grierson, Darkside Conversions. An outstanding Engineer.
Jim.
FollowupID: 652735
Reply By: stumbly1 - Tuesday, Sep 29, 2009 at 17:18
Thanks every one,
Its starting to sound like an expensive proposition but I will look into the places you have suggested. Thanks also the advice with strengthening the chassis / coil towers. I havn't had any problems so far but upgrading to a van with 300kg ball weight soon, so I will be doing that regardless of the conversion.
Thanks again, Keith
AnswerID: 385077
Follow Up By: Travelin OZ - Tuesday, Sep 29, 2009 at 17:34
FollowupID: 652814
Reply By: Member - Matt (Perth-WA) - Tuesday, Sep 29, 2009 at 19:49
try http://www.laingley.com.au/
AnswerID: 385100
Reply By: Outbacktourer - Thursday, Oct 01, 2009 at 21:26
Done my '02 Patrol by Specialised Vehicles in Sydney. Check the rig pics.
No chassis extension saves heaps of $$, at least $10K but depends what you want. I did a 600mm extension and ended up with a 2.1 tray which is a good size.
I'm into my 3rd year since the stretch and have done Cape York (at 3500 GVM)with no issues related to the conversion (blew an an airbag though, another story).
What you may not know is that even after my 600mm stretch (with Alloy tray) the vehicle was lighter than what is was as a wagon by about 100KG and a lot of the weght balance moved forward. I had to change the front springs from HD prgressive to HD linear (both Kings) and wind up the Koni's. I went from running 32 PSI in the front BFG's to 42 (unladen) for the same contact patch.
OT
AnswerID: 385376
