custom drawer slides
Submitted: Monday, Oct 05, 2009 at 09:10
ThreadID: 72775 Views:3206 Replies:3 FollowUps:7
well forum viewers,
im now working on some custom rear drawers for the back of the troll.
its still a work in progress, but i couldn't help my self posting a few pickies.
so far it has turned out good, just need to make the drawers and carpet the whole lot now.
Image Could Not Be Found
thats all i have done thus far, stay tuned for more
Reply By: Member - Mark G Gulmarrad - Monday, Oct 05, 2009 at 09:43
nice work mate.......i also made my own. my drawers
these pics may be able to give you some more ideas,cheers.
AnswerID: 385794
Follow Up By: Member - Greg T (ACT) - Monday, Oct 05, 2009 at 18:18
Thanks Mark,
I made the drawers today, fail!!!
i am looking at your pics now.
I tried to do it on the cheap and use bunnings draw slides. end state, not good.
im going to try it again with H/D 100kg slides next weekend. will be a lot better
FollowupID: 653414
Follow Up By: Gary5167 - Tuesday, Oct 06, 2009 at 19:14
Mark,
how did you attach the frame to the floor, or does it rely on the weight of everything to hold in place?
FollowupID: 653571
Follow Up By: Member - Greg T (ACT) - Tuesday, Oct 06, 2009 at 19:18
the drawers are attached to the mounting points on the floor of the troll. took a couple of measurements and drilled into the base of the draw frame, bolted draws down.
i need the drawer frame bolted down due to the weight of the drawer when opened. otherwise the whole shabang would tilt up when opened
FollowupID: 653572
Follow Up By: Member - Mark G Gulmarrad - Wednesday, Oct 07, 2009 at 21:20
Gary5167
i just used a small peice of aluminium angle with a pop rivit...has held so far.
4 of them along the front and 4 along the back,cheers.
FollowupID: 653756
Follow Up By: Gary5167 - Thursday, Oct 08, 2009 at 07:45
Thanks Mark,
I guess I didn't look closely enough at your pictures.
FollowupID: 653790
Reply By: gbc - Monday, Oct 05, 2009 at 17:40
r u going to be able to remove them without demolishing them?
AnswerID: 385834
Follow Up By: Member - Greg T (ACT) - Monday, Oct 05, 2009 at 18:21
yes and no.
i dont want the whole lot to come out.
if i want to take it out for some reason, i just remove the top of the drawer and it will come out.
a 1/2 cage is going in next, so i wont be able to use the whole back as storage anyway.
got the drawers, carpet and fridge slide to do still, early days
FollowupID: 653415
Reply By: Best Off Road - Thursday, Oct 08, 2009 at 08:03
Greg,
For home made drawers to run properly you'll need to get some decent quality slides. Try Hafele in Dandenong. They do slides rated to 100 kg and more, but they're not cheap. If you for 700mm extension expect to pay about $120/pair and 900mm gets to over $200/pair. Obviously you'll need two pairs.
Jim.
AnswerID: 386212
Follow Up By: Member - Greg T (ACT) - Thursday, Oct 08, 2009 at 17:47
Bloody hell!!
my drawers are about 900mm...$400...thats more than all the rest combined
FollowupID: 653860
