Cleaning the Cobb
Submitted: Friday, Oct 09, 2009 at 13:58
ThreadID: 72892 Views:3336 Replies:9 FollowUps:1
we have a Cobb and love it, we use it at home and when we are away, however it seems that the moat and fire box area is not the easiest of things to wash up, as ash from the fire box ends up inn the moat when tipping the liquid out of the moat.
So my question is what do you do to make this job easier?
thanks
Jason
Reply By: MrBitchi (QLD) - Friday, Oct 09, 2009 at 14:22
I lift the firebox out with tongs before emptying the moat.
AnswerID: 386387
Reply By: Member - cuffs (SA) - Friday, Oct 09, 2009 at 14:23
Line with Alumi-foil
AnswerID: 386388
Reply By: austastar - Friday, Oct 09, 2009 at 14:37
Cook the meat in an oven bag, pour out the juices for a gravy.
AnswerID: 386390
Reply By: George_M - Friday, Oct 09, 2009 at 15:48
Or cook your meat and vegetables in one of those rubber cake tin thingys that you'll find in Mrs Jason's pots-n-pans drawer. I sit mine (the rubber thingy) in the Cobb on a metal cake cooler I bought from Target for about $3.00 - just bend the legs with a pair of pliers so they fit into the perforations in the tray of the Cobb.
George
Come any closer and I'll rip your throat out!
AnswerID: 386398
Reply By: Isuzumu - Friday, Oct 09, 2009 at 16:11
I gave mine away and now use a camp oven on my Oz Pig
AnswerID: 386399
Reply By: Sand Man (SA) - Friday, Oct 09, 2009 at 18:45
I don't put extra liquid in the moat.
I also lift out the firebox with a three pronged hook I made up out of SS welding rods and a ring.
Bill.
Bill
AnswerID: 386416
Follow Up By: Member - Graham H (QLD) - Friday, Oct 09, 2009 at 20:46
Whats wrong with the little tool supplied with the Cobb
FollowupID: 654011
Reply By: Haza - Friday, Oct 09, 2009 at 22:47
I found washing liquid just doesn't have the power to remove the fat and grit, I use Jiff and an old washing brush and find it works a treat. When at home I just take it outside and did the same and use the hose.
AnswerID: 386451
Reply By: Member - Sigmund (VIC) - Sunday, Oct 11, 2009 at 16:53
Oven cleaner after each big trip.
AnswerID: 386613
Reply By: Member - Brenton H (SA) - Monday, Oct 12, 2009 at 09:50
Usually don't bother all that much. Give it a quick wipe out as best we can and a good clean up when we get home. I do lightly spray the moat area with oil however which helps to stop gunk sticking on the sides.
AnswerID: 386680
