Piston / broke 1HZ
Submitted: Sunday, Oct 11, 2009 at 20:17
Member - Bill L (NSW)
G'day all. Just wondering if anybody out there has had a 1hz piston fail.I have a 1998 100series with after market turbo and intercooler with 240000klms on the clock that went off with a bang (thought i had a ZD30 under the bonnet for a minute !). Took the head off today to find number 6 piston split accross the top and the
bore buggered.Thinking of replacing it with a 1hd-t or 1hd-ft,has anyone done this and any tips please.
Reply By: Member - Mark E (VIC) - Sunday, Oct 11, 2009 at 20:37
Bill,
I have been doing a heap of research on turbo charging a 105 series with 1HZ. There are numerous reports of failures in these engines, particularly when the turbo is wound up with excess boost, overfuelling and advanced timing, all to create greater power in an engine that was never designed for this.
Have a read of this thread:
http://www.bushtrackerforum.com/viewtopic.php?t=923&sid=742ef01535c6ff88100b54738aad5403
LCOOL
forum is also a great place for advice on the Toyotas.
Mark
386651
Reply By: mazcan barry - Sunday, Oct 11, 2009 at 21:05
piston/broke 1 hz
yes been in that condition several times over the years
after staying at the pub too long lol
386653
Follow Up By: Fatso - Sunday, Oct 11, 2009 at 21:17
Isn't that called"the mechanics nightmare"?
654216
Follow Up By: Richard Kovac - Monday, Oct 12, 2009 at 18:23
Now thats funny,.. LOL
654296
Reply By: fisho64 - Monday, Oct 12, 2009 at 00:49
while I dont know about "numerous failures", Im certain that doing all Mark has mentioned puts a 1HZ in danger of this.
Uncountable numbers of 1HZ's have been turbo'ed (3L Hilux's also)
Both these motors are the same indirect injection setup.
Boosting over about 8or9 psi is something I wouldnt do. Most common I think is a crack between precombustion chamber and exhaust valve followed by piston failure.
386666
Reply By: NUTS! - Monday, Oct 12, 2009 at 14:05
1HD-FTE into a 105 Landcruiser = YES
Would end up with an awesome vehicle too.
There's a posts on LCOOL
forum about this, a guy in
Sydney has done a few of them:
http://www.lcool.org/forum/viewtopic.php?t=7407
NUTS
386702
Follow Up By: Member - Shane D (QLD) - Monday, Oct 12, 2009 at 18:13
Must be a member to use this link
654292
Reply By: NUTS! - Monday, Oct 12, 2009 at 14:07
Reply By: NUTS! - Monday, Oct 12, 2009 at 20:37
For any Landcruiser owner, LCOOL is worth signing up to...heaps of good knowledge on that
forum.
Anyway, the short and curly's of it, look these guys up:
Total Care 4WD at Seven Hills
There is another post on LCOOL about a guy putting one of the new V8TD Toyota motors into a 105 series (out of a tray back). Nice rig and he surprisingly managed to do it with very little expense.
386760
Reply By: Member Dick (Int) - Monday, Oct 12, 2009 at 22:10
Bill,
Jason Dymock
Total Care 4WD
1/13 Bearing Road
Seven Hills NSW 2147
Phone: 029838 9779
He has done a lot of engine upgrades including 1HD-FTE's as replacements for 1HZ's.
Dick
386780
Reply By: The Lobster - Tuesday, Oct 13, 2009 at 17:09
Yep, this is one of the most common failures with turboed 1HZs. Usually seems to be a result of excessive boost, but not always. This is also the reason I would personally never turbo my 1HZ. The not designed to run with turbos and reliability is just never there.
As others have said, LCOOL is the place for conversion info. Can definitely be done with any of the 1HD engine variants (1HD-T, 1HD-FT, 1HD-FTE). Obviously the newer models are better, but it's not a cheap exercise, so your budget will probably make the decision for you. Get over to LCOOL and have a read.
matt
386894
Reply By: Member - Bill L (NSW) - Tuesday, Oct 13, 2009 at 19:22
Thanks for the helpful info.Have registered with LCOOL and will have a chat with their members soon.Will also give Total Care a call tomorrow.
Cheers Bill
386905
Follow Up By: Member - ross m (WA) - Tuesday, Oct 13, 2009 at 19:49
Do yo knw what kind of boost you were running or the EGTs it was making?
654485
Follow Up By: Member - Bill L (NSW) - Tuesday, Oct 13, 2009 at 20:59
Gday
Ross
About 12psi pre intercooler,8psi at manifoldand running 550degree max post turbo.
654517
