Cape York
We are currently in the process of planning our August/September 2010 trip to Cape York. As we have never been up there before, it is difficult at times to find the correct information to cover our own needs. It is our intension of making it to the top and back without destroying our vehicle through either drowning it or the motor. Simpson Desert and dry land 4WD action is not new to us like deep water creek crossings will be. Like most things in life, treat it with caution and things will normally turn out ok.
The plan at this stage is to go one way via the old Telegraph Track and the opposite way via the Northern Bypass and the Southern Bypass roads. While we assume (bad word that one) that there should be no issues with the Bypass roads, it is the Old Telegraph Track that we are unsure of.
We would like as much information as possible regarding the Old Telegraph Track from the Jardine River through to Fruit Bat Falls. Our map makes reference to “Bridge Creek (Nolan’s Brook)” with a caution notation advising that it is very deep clear creek with an alternate log bridge which is not recommended for large vehicles. What weight vehicle is considered large for this bridge? Is a Nissan Patrol or Toyota Cruiser too large to use the bridge? The map also shows a total of at least ten water crossing on this stretch of the Old Telegraph Track. Are any of these too tough for the average 4WD owner to tackle at this time of the year?
Are there any parts of the section of the Old Telegraph Track between Sailor’s Creek and Bramwell Junction other than Gunshot Creek that would normally be of a concern? Our map shows a 25km bypass road to avoid Gunshot Creek, is there any closer bypass to Gunshot? Although we will not be driving into Gunshot Creek itself, it would be nice to be able to have a look at it.
Any assistance that you can give us with these questions will be greatly appreciated.
Mick & Sally.
Reply By: timothy - Wednesday, Oct 14, 2009 at 09:03
The bridge at Nolans Brook isn't really in a state to be used by anything other than a motorbike, when I was there in July 2009 it was 3 1/2 logs. The water crossing itself isn't as bad as people make out, just be sensible and take it easy and remember to walk it first and figure out a route that you will be confident driving.
I don't think any of the crossings are particularly difficult and if you walk each of them before diving in you'll find you can go through without water over the bonnet and only dipping over the bumper. North of Fruitbat Falls the crossing that I was most nervous about was the one marked as a marshland on the Hema map, it was murky, quite long and was halfway between the bumper and bonnet on my vehicle for most of the way across.
I don't think there is a shorter bypass at Gunshot than the 25km route marked on your map, the chicken track might be quite chopped up by August/September because you'll be going after the school holidays but would be worth a look and you might find it not as bad as you thought.
This year the Southern Bypass was very corrigated between Fruitbat Falls and Bramwell Junction.
Feel free to check out my Cape York photos there's one of the Nolans Creek Bridge in there.
AnswerID: 386977
Follow Up By: Member - Tonyb (FNQ) - Wednesday, Oct 14, 2009 at 16:43
"the chicken track" - Correct name is Smart mans track - the other one is Dumb mans track.
:-) Cheers
FollowupID: 654608
Reply By: Member - Tonyb (FNQ) - Wednesday, Oct 14, 2009 at 16:51
In August and September water crossings will not be a problem, if you are unsure walk them. A couple need to be negotiated with caution because there is large holes that will eat a 4x4. Sorry cant remember the names of them.
I drove a standard cruiser up there for work and just after the wet I could still do all the TT creeks without too much of a problem.
Just take it easy and all will be fine - At gunshot just take the side track - the other way is for fools who do not like their car :-)
AnswerID: 387051
Reply By: DaveO*ST-R - Thursday, Oct 15, 2009 at 18:05
We have not long returned from the Cape, having travelled the Telegraph Track itself at the end of August - south to north. 2 vehicles, 1 a 100 series L/Cruiser with the lot, towing an Ultimate Camper and me with a near stock Navara towing a Tambo camper. I too was not overly comfortable with water crossings and much prefer sand and beach driving, but we had no problems with any part of the track, including Gunshot. We took the easiest option, the so-called chicken track. Just crawled down with no drama at all. When you get there, make up your mind then if yoiu are comfortable doing it. The conditions and track might be as we found it, not overly daunting at all.
Nolans Brook was of some concern to me, having read about how deceptive and deep etc it can be. I walked it first, picked the best line (right side) and got through OK. The depth was probably around 800mm with the bottom sandy and soft. But I made it without drowning the car !! The bridge crossing (what's left of it) you mention is at best, as suggested, suitable for motor cycles only. Most of the other crossings needed to be checked properly for depth, holes and drop-offs etc, and some required zig-zagging through to avoid them
A while ago, I watched the DVD of the Gall Brothers towing a 3 tonne Kedron van up the Telegraph Track. How they got it through is somewhat astounding, but they did it. Really worth watching if you can find a copy.
I was expecting the OTL to be far more difficult than it was. I drove to the conditions, took my time and had a fantastic time. From all accounts, conditions change from year to year, so who knows what it will be like when you get up there. For me, south to north was easier than the other way around. With a trailer in tow, I feel certain I would have had to winch out of some spots heading south. Can't wait to do it all again.
We did the bypass roads on the way back from the tip. The only horror section was somewhere north of Bramwell Junction - I can't remember the name of the area, but there was a 40? odd km section that shook the fillings out of the teeth...the worst corrugations I have been on. The rest of the PDR was not too bad at all - much better than I had anticipated. Depends on when it gets graded, I suppose.
Enjoy your planning and subsequent trip.
Dave
AnswerID: 387189
Follow Up By: Member - Allan B (QLD) - Thursday, Oct 15, 2009 at 18:29
Hi Dave.
Re walking the water crossings, what is the situation re crocs?
FollowupID: 654742
Follow Up By: DaveO*ST-R - Thursday, Oct 15, 2009 at 18:39
Allan,
There will be far more knowledgeable people on here than me, but from the research I did etc, the creeks on the OTL are fine, but the Jardine is definitely one place to stay out of, but we did not see one croc the entire trip. A disclaimer though...don't take my word as gospel !!
Dave
FollowupID: 654748
Reply By: S&N - Thursday, Nov 05, 2009 at 23:38
hi there, how long did it take you to do the cape?
AnswerID: 390164
