in car navigator
Submitted: Monday, Oct 26, 2009 at 09:23
ThreadID: 73302 Views:3342 Replies:5 FollowUps:5
Hi all
Taking off next year on another trip around the block and will be driving in Melboune & Sydney with the van.Looking at buying an in car navigator to help with this especially one that will tell me which lane to be in as I'm very much much a small town driver.
Any suggestions as to the best buy. We travel on the pension so there's not a lot of money available.
Reply By: you eat the bear - Monday, Oct 26, 2009 at 10:51
Hi John.
If all you need is main road (i.e. not bush track) navigation, I would highly recommend a TomTom (with voice navigation).
They are very easy to use and the entry level units I believe can be had for around $200 now.
They are the top selling unit in Europe (presumably for a reason) and I have had no trouble with mine in over 2 years now - use it in Sydney and Perth when I travel there and it even helps me to avoid the toll roads!.
Steve
AnswerID: 388740
Follow Up By: Member - Graham H (QLD) - Monday, Oct 26, 2009 at 11:36
Second that although I have TOTOM GO730 which is a bit more expensive.
It is much better than the Garmin Nuvi I had previously.
Reasons It give turn warnings earlier and has better lane descriptions than the Garmin.
It is also easier to use than a Navman.
However it is in how you set it up that gets you the best use out of it .
Play with it before you go and see how you want it set up
You can run demos of the route so can see prior to leaving where it will take you.
Shortest route is not always the best as it may take you through back streets
Depends where you are sometimes.
Cheers Even a cheapie is Ok.
FollowupID: 656441
Follow Up By: Member - Graham H (QLD) - Monday, Oct 26, 2009 at 11:40
Ask to see one with predictive lane directions as on the TOMTOM
How it works is it shows the lanes on a freeway and defines which ones turn off
I have mine set to start telling me to turn 1km ahead and it counts down to nothing on the way to the turn.
Very Very good.
FollowupID: 656443
Reply By: Member - Tony (ACT) - Monday, Oct 26, 2009 at 11:59
I have the Garmin 5000 Nuvi, and it works great, came down through Sydney from the central coast yesterday, no problems getting into the right lane. I turn the voice off and just glance at it. With the 5" screen its easy to read.
AnswerID: 388747
Follow Up By: Member - Graham H (QLD) - Wednesday, Oct 28, 2009 at 00:13
I find its easer and SAFER to watch the road and listen to instructions.
I thought that was what the text to speech was all about.
In Sydney a quick glance away from the road could result in a big rearender.
FollowupID: 656789
Follow Up By: Member - Tony (ACT) - Wednesday, Oct 28, 2009 at 07:10
If that what works for you fine. I've got enough people telling me what to do when I'm driving I don't need another one.
It can tell you what to do visually as wel as voice.
FollowupID: 656794
Reply By: Member - Cantiva Clay (NSW) - Monday, Oct 26, 2009 at 13:41
I use a Tom-tom one xl which is not the official "lane" version - eg 730 etc... (but its cheaper) and its fine on the motorways around sydney, while it doesn't say exactly what lane it does tell you "keep left/right" which works fine i find. Just remember not to panic if you miss an exit, just cruise along and take the next one. There are a couple of caveats with the tom-tom, first if you get of the beaten track and mistakenly choose "shortest route" don't complain if you get sent down lanes barely wide enough for a mini! (Its just doing what its told!) Secondly, don't waste money on the traffic feature, while technically it works it only ever tells you the obvious and usually 10 mins to late. Third on the hit list it has "opportunities for improvement" when navigating of the beaten track in the countryside - if you are planning leaving the main roads you really need a topo gps with 250k + hema maps and ozie or equiv. This type of gps is made for city slickers. There's one other quirk about the tt, the gps receiver chip can loose its ability to gain and hold a good satellite lock if the "quick fix file" (ephemeris data) gets to far out of date. The file needs to be downloaded from the internet and installed regularly/ at least fortnightly, you can probably survive a month or two without an update but after a couple of months it gets a serious case of the attitude "you don't want to give me my quick fix I won't give you your location....." Seriously with the tt you need access to the internet every coupla weeks to update it to get decent performance, funnily my 7" HK special gps has no update files and works fine - but it is a claimed sirf3 chip. When it has its updates it works remarkably well, something I really like about it is that once you get use to the street display its really easy to read on the run - there's a bright green arrow on the screen showing your route and next turn and you just drive. If you miss a turn it recalculates quick enough to catch the next and with the screen sun shield you can see the display ok. If mine was stolen I would buy a tt again because even though it has foibles, once you understand them it works really well. One other good thing support has an australian office with an australian person ! (Bus. hours) try and get support for your navman.... Interestingly a number of reviewers recommend the "one" version which they say for $217 (hunt the web-ryda( is a steal - you get all the features of the bigger brother just a smaller screen which by all reports is fine.
C.
AnswerID: 388772
Reply By: Member - Gavin D (QLD) - Monday, Oct 26, 2009 at 13:59
I have had my TomTom One XL for just on two years. I like the FREE updates and corrections which are download weekly, and you can upload changes as well via their MapShare Corrections, and only have to get new maps when there are major changes. I also like the fact it is compatible with both my Apple Mac and WinVista laptop for managing the Tom Tom - eg. for adding Macca's, KFC's, National Parks, designing routes etc.
Gavin
AnswerID: 388775
Reply By: Fatso - Tuesday, Oct 27, 2009 at 22:55
Never used one. I am an old fashioned young bloke that reckons it is a waste of money & talent.
The first city I ever drove in was London. At 5pm on a wet Friday afternoon at the tender age of 22 I picked up a van in North London on my own & headed up the M1. Navigating & driving.
I drove around GB as well as Western & a bit of Eastern Europe for over 12 months.
Then it was off to Africa to travel over quite a bit of Egypt then hitch-hike around Kenya, Uganda, Zaire & Tanzania. All this without a GPS navigation system.
No body had one back then in 83. They hadn't even been invented & if they had I still wouldn't of had one.
My theory is that they limit the development of your own talent's & make you subservient to an electronic gadget.
In my travels around Africa I came to the conclusion that travel guides inhibited the travel experience by limiting your ability to source information for yourself. Too much emphasis is placed on the readings from the book instead of reaching out & meeting fellow travellers & sharing experiences & information. The same could probably be said of TVs in the caravan parks these days. That is something else I will never take on holidays.
This year we drove into Adelaide & found our way to West Beach without even having a map in the car. The only other time I have been to West Beach was for 5 days 10 years ago.
At 20 years of age a mate & I drove from Cairns to Perth with no more than a map of the national highways when we left. We bought a map of Sydney & of Melbourne when we arrived in these towns.
You don't need an "in car navigation system". You already have an "in brain navigation system". You just gotta exercise it & it will work well. You will also be able to say " I found it OK" & not have to say "we had to rely on Tom Tom".
Another weird sounding thing that most people wouldn't understand was when I teamed up with 5 others backpackers in Tanzania & rented a 4 x 4 & guide to travel the Tanzanian game parks, one of my companions never took a camera. He was an Aussie doctor that had worked in South Africa for 7 years & had travelled all the game parks below the equator. He kept saying that this trip was his best out of all of them. He put that down to not having a camera for the first time. He claimed the camera was a distraction from the sight before you & the taking of a photo took precedence over admiring the view.
I think he was right.
AnswerID: 389056
Follow Up By: Member - Graham H (QLD) - Wednesday, Oct 28, 2009 at 00:10
Working on your theory You are lucky to have a car to travel in.
Working on heightening your own systems woulld have only lead you to walk faster.
Some people can do what you did Some get lost in a revolving door
Technology is there if you wish to use it.
I prefer to listen to instructions than try to read a map and drive at the same time.
FollowupID: 656788
