camping shower
Submitted: Tuesday, Oct 27, 2009 at 09:17
ThreadID: 73333 Views:4787 Replies:14 FollowUps:6
Any recommendations for a camping shower set up. Also what would be the best pump to use for a 'stand in basin' type shower?
Thanks!!
Reply By: Shaker - Tuesday, Oct 27, 2009 at 09:46
In regard to the camping shower, do you want to spend $40.00 or $400.00?
AnswerID: 388912
Follow Up By: JohnnyTasman - Tuesday, Oct 27, 2009 at 12:49
$40 sounds good!
FollowupID: 656659
Reply By: Member - Troll 81 (QLD) - Tuesday, Oct 27, 2009 at 10:23
Really depends on how much $$ you want to fork out. You could get by with a $30 shower setup and a bucket or you could do what many people do is and get a under bonnet setup.
I have a 80l water bladder behind the front seats on the floor. I connect that with a hose to my engine bay and start the car, turn the pump on and hot water come out the shower end. It's quick to setup and pack away and it keeps the wife happy
AnswerID: 388917
Reply By: Nath'n'Lynz - Tuesday, Oct 27, 2009 at 10:32
Hi.
We have an ARB (Glind ) - under bonnet shower on our Mazda.
Put it on around 4 years ago now. Cost was $360.00 back then. Not sure how much the install was.
A 3-4 minute shower uses around 5-10 litres, depending on how often you stop and start the flow.
Wouldn't go without one now.
Lynz
AnswerID: 388918
Reply By: bruce - Tuesday, Oct 27, 2009 at 10:57
We use a 12v model that uses batteries or can be hooked to the van battery with supplied cig type connector and stand in bin of hot water...water recycles over you as you shower and you can shower for as long as you like or the water gets to cold...and use pop up type tent...cheers
The shower pump works better when hooked to the van battery(better pressure)
AnswerID: 388921
Follow Up By: JohnnyTasman - Tuesday, Oct 27, 2009 at 12:50
Which model is this?
FollowupID: 656660
Follow Up By: bruce - Tuesday, Oct 27, 2009 at 19:41
Do not know the model off hand as it is packed away at the moment , but we got it from our local disposals store..Rays Outdoors stores also stock them...about $30 2 yrs ago....cheers
FollowupID: 656734
Reply By: Member - Tony (ACT) - Tuesday, Oct 27, 2009 at 11:39
My vote is for the Heat Exchanger type, fitted to the engine. Its always with you.
Had one on the last two vehicles and they are the best there is bar none. If you are lucky enough to be near a constant water supply, run a hose to it and pump straight out to the shower. Or even fill the water tank on camper/van.
AnswerID: 388929
Reply By: Member - lyndon NT - Tuesday, Oct 27, 2009 at 12:08
We have a Power Shower under the Troopy bonnet. Works well. Was the "other half's" idea. As we generally camp up north it has been used ONCE! Have a canvas shower bag that was dad’s, I tie it in a tree. Much better flow and as said water does not need to be heated anyway.
Moral of the story, make sure you really will use it.
Cheers Lyndon
Now is the only time you own
Decide now what you will,
Place faith not in tomorrow
AnswerID: 388936
Reply By: Fab72 - Tuesday, Oct 27, 2009 at 12:58
I use a PVC tube that's mounted on the roof racks and painted black. At the back end of the tube, I fitted a snap on male airline fitting and made up a shower head with a female fitting on it and a tap to turn the water on and off. Providing there is sunlight about, it's ever reliable and cheap to make.
AnswerID: 388943
Reply By: Member - John and Val - Tuesday, Oct 27, 2009 at 17:35
We use a 12v type that we drop into a bucket containing about 3l of water, unless there is a plentiful supply in which case we use more. Its amazing how good you feel after a 3l shower! Or we have a folding bucket with a shower head which also works pretty well. We heat water in various ways - on the fire, in a 10l black plastic bottle left in the sun (travels on roof racks) or as a last resort using the gas stove. Sometimes no heating is required.
None of these options cost more than about $30 and have no running costs (unless we use gas to heat water). The good thing about these systems is that you can control the amount of water that you use, very important on a desert trip.
Val
J and V
- Albert Einstein
AnswerID: 389000
Follow Up By: Member - joc45 (WA) - Tuesday, Oct 27, 2009 at 19:28
Agreed.
Jaycar sell a good one for about $20. I seem to get about 4-5 years out of one before it's time to replace it (usually the rubber shaft seal packs it in). I've even used these with sea water with no problems. Just make up a long 12v extension lead to run from the vehicle to the shower. Doesn't have to be a heavy lead, as the pump draws quite a low current.
One extra I suggest is one of those folding shower cubicles for about $70, which apart from giving privacy, keeps out the chilly wind. Only downside is trying to fold the damn thing up again (the salesperson must have practised for hours before demonstrating how easy it was :-).
cheers,
Gerry
FollowupID: 656729
Reply By: Sand Man (SA) - Tuesday, Oct 27, 2009 at 18:44
I use a $30 Coleman 12 volt shower.
It will provide what you need, for the cheapest cost.
I have owned mine for 5 years or so and it was still OK last time I used it:-)
I use alkaline energiser batteries (4 x D size) which last ages. Carry a spare set "just in case".
We have a 40 litre or so rectangular tub and place heated water in it. The pump is dropped in the tub and we then stand in it to shower. The operating switch is readily accessible and we find both of us gets a shower out of the one "fill" by recycling the hot water, most of which is returned to the tub.
"Herself" is offered first use:-)
I couldn't be bothered with a vehicle mounted shower. We shower without clothing and in semi public places but use a pop-up tent so as not to offend other people.
I am amused when you see the model showering under a Glind, or whatever but wearing bathers. (How can you wash your "places that need washing the most" with bathers on)
The Coleman el cheapo shower can also use a collapsible 20 litre bucket, or any other container that holds water. but you don't stand in.
It probably gets down to how much water you have available, but we find a shower utilising the principal above, every second or third day suffices for us.
Bill
AnswerID: 389013
Follow Up By: Member - Johny boy (NSW) - Tuesday, Oct 27, 2009 at 20:08
Hi Sand Man, I need to ask and I am not being cheeky but you and a few others mention standing in a tub of heated water and dropping the pump in ...wouldn't that mean that if your really dirty that you will and the person after you will be washing in dirty water!!! ???
Like I said I'm not being cheeky its just something I always think about when I read about this method :)
FollowupID: 656737
Follow Up By: Sand Man (SA) - Tuesday, Oct 27, 2009 at 21:00
Hi John,
Umm....yes... your assumption is basically correct mate.
That is why I let SHMBO go first:-)
In practise John, I have no problem in this method to save water, sometimes a precious commodity.
When I was growing up, I was one of three siblings and it was very common to share the bath water. The youngest got first dip and so on up the age scale.
I don't believe it really compromises hygene that much, however in really grubby situations it is simply a matter of changing the water between showers, albeit using much more water.
As I have mentioned, we don't find it necessary to shower every day when water is at a premium. During the "off-days" a simple "splash'n'go" suffices.
My interpretation of water being at a premium usually means we are carting all that is available because there is no alternative supply. such as a river or pond.
Actually, when you look at the condition of some water supplies at times, "double dipping" is no issue at all.
Bill.
Bill
FollowupID: 656750
Reply By: Member - Flynnie (NSW) - Tuesday, Oct 27, 2009 at 22:03
Johnny
I have some comments on my profile about camp showers. These are a work in progress with me. Have made some false starts and spent too much money. If you can get water warm enough I would go with a simple pump and a bucket.
Keep it simple, light, reliable and cheap.
AnswerID: 389040
Reply By: Member - Au-2 - Tuesday, Oct 27, 2009 at 22:19
And then Johnny T, there is the weed sprayer in the pop-up tent! We found this the most economical re weight, power and water wise. Tried the gas Coleman--the power cuts out every time you turn the shower off-- the black solar bag which only lasts until the handle rips off, until finally using the weed sprayer which we--3 adults-- still use.
I fill one of the old solar bags during the day when we are camped--fill in the morning--leave out all day--pour into sprayer bottle when needed, voila! hot showers for three using less than 5litrs of water all up. When travelling boil one litre of water in billy, add 3-4litres cold--same as before. Ladies can wash hair more than adequately with this method, same can be used for rinsing off greasy dishes, washing dirty feet before bed, windscreen washing and, finally, you can wash the dog if he travels with you.
Sheila.
AnswerID: 389045
Reply By: Member - Phil G (SA) - Tuesday, Oct 27, 2009 at 22:33
Its usually pretty dry where we travel, so our preference is to shower from a cheap 8 litre SS crockpot warmed up on the fire. Alternatively 5 minutes on the stove gets it to the perfect temp. then drop in the Jaycar electric shower.
Had a heat exchanger in the past - found it a pain to use.
And used the weed sprayer too - the spray is a bit too feeble, but you can shower with as little as 1.5 litres of water.
AnswerID: 389050
Reply By: Grundle - Wednesday, Oct 28, 2009 at 18:58
we used a pop up shower tent,took a little practise to work out folding up.(figure 8 setup)and a 12v pump bought at a camping store.Worked great for 4 people over three weeks.only needed a couple of ltr per person each shower.needed a handful of grass under a foam mat to keep feet clean.
AnswerID: 389139
Reply By: Member - Mike DID - Wednesday, Oct 28, 2009 at 19:50
When you just can't manage a shower, 5 Babywipes work wonders.
AnswerID: 389154
