Wednesday, Nov 18, 2009 at 14:28
Hi Splits, There is quite a bit of material so if you can let me have an email address I will send it on to you. Send your address to nzrees@yahoo.com.
When you bolt a hook onto a chassis a very large percentage of the 'gripping' force is due to the clamping effect between the flat surfaces. As long as you use the correct torque settings for the bolts that you use AND the bolts are not smaller then the holes in the hook and chassis AND the hook is forged not cast, you should not have to worry about a bolt pivoting and stripping the thread.
You may also find the following of interest;
Recovery Loads
Loads incurred when recovering a vehicle can be very high. In the following tables LW is the Loaded Weight of the vehicle being recovered.
A pull of 100% of LW is required to free a vehicle stuck up to the top of the sidewall of a tyre.
A pull of 200% of LW will be required to free a vehicle stuck up to the hubs of its
wheels.
A pull of 300% of LW will be required to free a vehicle stuck up to the body.
Add the following load if a vehicle is to be recovered up a slope.
15 degrees - add 25% of LW
30 degrees - add 50% of LW
45 degrees - add 75% of LW
Also, have a look at the following web site for some interesting info on loading of hooks & slings etc.
http://www.pirate4x4.com/tech/billavista/Recovery/index.html
KK
PS get back to me soon if you can as I will be away for a week from Friday (4wding all next week).
659532
