Professional Welder Needed
Submitted: Monday, Nov 16, 2009 at 11:49
ThreadID: 73781 Views:3073 Replies:5 FollowUps:7
Hi Guys,
I am in the planning process of building an off-road tandem trailer. I have managed to find an engineering company that will provide me what I require, all i need to do is have it welded together. I can't weld to save myself.
Can anyone give me an idea of what it would cost to weld up a 9 x 5 tandem, all pieces are cut to size etc and approx how long it will take. Alternatively could prob get it all tacked together then just need the final welding done.!!
Just want to know if i am still significantly saving or not.!!!!
Bruce
Reply By: Member - George (WA) - Monday, Nov 16, 2009 at 11:59
Bruce, it would be helpfull if you mention your location, i.e a welder in Perth would be too expensive to go to Sydney. Cheers
AnswerID: 391385
Follow Up By: Bruce n Sal - Monday, Nov 16, 2009 at 12:05
Yeah True, good point. I am in Victorian Northern Suburbs approx 15min from Melb Airport
FollowupID: 659244
Follow Up By: Member - MUZBRY(Vic) - Monday, Nov 16, 2009 at 12:09
Gday
Try Alan at 03 5429 6949.
He is a member.
FollowupID: 659246
Follow Up By: Bruce n Sal - Monday, Nov 16, 2009 at 12:12
Thanks Muzbry
Bruce.!!
FollowupID: 659248
Follow Up By: Member - Pesty (SA) - Monday, Nov 16, 2009 at 13:36
Al Grierson, Romsey, i think there current signature on this site is Al and Mrs Al, if not I could put you in touch with them.
Pesty
FollowupID: 659255
Follow Up By: Sir Kev & Darkie - Monday, Nov 16, 2009 at 16:36
Al Grierson of Darkside Conversion Fame and also of Grierson Engineering.
Google Grierson Engineering for more contact Details for Al.
Cheers Kev
Russell Coight:
FollowupID: 659276
Reply By: Member - Josh J (NT) - Monday, Nov 16, 2009 at 16:31
Bruce and Sal,
Bit hard to give guesstimates without laying eyes on it, if everything is cut to size and has been done so correctly then a day should see the chassis along with spring hangers etc etc welded together no probs at all, gets a bit more fiddly when you start putting all the sheet metal in.
If it is just a basic 9x5 HD tandem trailer then i would imagine 2 days should have it close to done by a experianced welder with MIG..once you start adding all the little extras (gas bottle holders, spare wheel holders, water tank mounts etc etc) you could add 1,2 or maybe more days, all depends on how much you are getting done.
Overall though i think 2 days should see a pro welder come close to knocking of the basics...after that how longs a piece of string.
Good luck
AnswerID: 391405
Reply By: Bruce n Sal - Monday, Nov 16, 2009 at 16:37
Thanks for all your responses.
Just did a quick comparison with a trailer already built & I don't think getting a kit i going to be very beneficail, the welding & painting would need to be very cheap to make it worth my while.
Thanks anyway appreciate the comments.!!
Bruce
AnswerID: 391406
Reply By: MrBitchi (QLD) - Monday, Nov 16, 2009 at 20:08
And if you want it to last you need to get it hot dip galvanised..
AnswerID: 391434
Follow Up By: Member No 1- Tuesday, Nov 17, 2009 at 07:43
but that means drilling holes in it..(assuming its made from RHS)
FollowupID: 659360
Follow Up By: MrBitchi (QLD) - Tuesday, Nov 17, 2009 at 09:34
Not an issue.. Mine's 9 years old, lives 24/7 in the open, no rust. Never had/needed any maintenance on the body or chassis.
FollowupID: 659367
Reply By: Member - Lia H (SA) - Tuesday, Nov 17, 2009 at 21:57
Hi Bruce,
Hubby is a boilermaker welder, ticketed...
We looked at similar, but unless you had all the different bits and pieces (toolwise), it was nowhere near economically sound to do it yourself, as you said.
If you were in a workshop and could get your hands on everything you needed, all good.
Hope that helps.
AnswerID: 391554
