Question re a 60lt Engel Fridge
Submitted: Tuesday, Nov 24, 2009 at 09:16
Bruce n Sal
Hi All,
We bought a 60ltr Engel at xmas time last year. I have a quick question about it,
well about powering it really.
If my battery goes flat while we are out will this damage the fridge or does it turn itself off to protect itself?
I always try to re-charge the battery in the morning and evening but it's not the best battery any more and don't want to spend the $$ on a new one just yet.
Bruce
Reply By: bruce - Tuesday, Nov 24, 2009 at 10:21
I believe that once the battery gets below a certain voltage the Engel will not run or even try to...cheers
392416
Follow Up By: Member - Phil G (SA) - Wednesday, Nov 25, 2009 at 14:50
Yep, thats right. The later series Engels will not cycle below 10.0V.
660522
Reply By: Scolers - Tuesday, Nov 24, 2009 at 17:44
The WAECO will automatically shut down but the Engel won't. It will keep going until the battery has thoroughly drained so it pays to keep an eye on your voltage drop.
We have a 60ltr Engel and lost a battery due to not checking it regularly whilst away.
HTH
Scol.
392465
Reply By: shanegu6 - Tuesday, Nov 24, 2009 at 18:03
Hi Bruce n Sal,
You can buy an in line battery monitor from
camping shops which you can set to cut out at 10.5v or 11.5v. They are priced at about $130.00. They plug into your 12v power cable.
Regards Shane
392467
Follow Up By: ozwasp - Tuesday, Nov 24, 2009 at 23:28
You can buy these on Ebay for around $25.... I'm sure Dick Smiths/BCF/Kmart wouldn't be much more.
660457
Reply By: Sand Man (SA) - Tuesday, Nov 24, 2009 at 18:35
Hi Bruce,
The Engel will run "on the smell of an oily rag".
It won't be damaged by reducing voltage, however this is the quickest way to stuff up a battery, permanently.
Deep Cycle batteries are designed to provide current drain down to about 50% capacity. Even draining the battery down to 30% should not adversely affect it, but draining it flat (10.4 volts) a couple of times will most likely damage it beyond "repair". The plates become calcified and will not hold a charge.
The cheapest solution is to add a low voltage cutout device in the circuit.
Derek Bester from Sidewinder (an advertiser on this site) has a good,
well priced unit available, or you can purchase a similar device from Projecta. They have a plug and socket to connect in-line with the fridge circuit and will cut out the supply voltage at around 11.6 volts or so, to protect the battery from total drainage.
Bill.
392471
Reply By: Member - Stephen L (Clare SA) - Tuesday, Nov 24, 2009 at 18:55
Hi Bruce
If you are worried about your battery going flat, you can buy the Engel in line power cut out monitor. There are two power setting for you to select. When it reaches your selected power setting, it will cut your fridge out, saving your battery. It is as simple as undoing the 12 volt plug on the end, and inserting the cut out unit, or there is the same unit that is wired direct to the power line that the fridge runs from. As a matter of interest, your 60 litre Engel will draw a maximum of 4.5 amps per hour, giving you something to work out on your battery capacity.
Both genuine Engel units sell for Under $100
392474
Reply By: Bruce n Sal - Wednesday, Nov 25, 2009 at 10:08
Thanks for the replies,
My main concern was the fridge being damaged by the battery going flat. The battery i am using is a large on out of a truck, a mate is a Diesel mechanic and when he changes one he change them all regardless if they are stuffed or not.
So the battery doesn't do too bad a job but i think the deep cycle is high on the list of things for the next trip.
I will however be more careful when i eventually buy a deep cycle battery.
Bruce
392533
