Portable toilet dumping
Submitted: Sunday, Dec 06, 2009 at 23:04
ThreadID: 74233 Views:7032 Replies:6 FollowUps:5
We've just got ourselves our first porta-loo and are wondering what we do if there are no dumping points around. Are there any chemicals (we were planning on using napisan) that we can use and dig a hole and dump it in the ground?
cheers,
jason and avril.
Reply By: GerryP - Sunday, Dec 06, 2009 at 23:48
Sometimes you don't have a lot of choice. Obviously, use dump points if possible, but if it needs to be emptied away from anywhere, digging a hole is fine IMHO. Just make sure it is deep enough to get a good covering of dirt over it and keep well away from waterways. I always also make sure I pick a spot where anyone is unlikely to wander or want to camp etc.
Gerry
AnswerID: 394029
Reply By: Notso - Sunday, Dec 06, 2009 at 23:51
There are special chemicals you add to the holding tank and the water supply tank that are supposed to keep it all smelling reasonable.
They don't work too well really.
There are eco friendly ones that you can use also, check at your local camping store.
There are "Dump Points" in most towns these days, don't dump them in septic systems as the chemicals apset the bugs.
If you can't get to a dump point then dig a decent deep hole away from any water course and bury it. Don't just dump it around some camp site.
AnswerID: 394030
Reply By: Motherhen - Monday, Dec 07, 2009 at 01:06
Hi Jason and Avril
Yes, you are on the right track. Use the Coles and Woolworths brands Napicare Plus or Nappy Treatment Plus. We have found this more effective than Bio Magic we started out using. Some people add a bit of the same to the flushing tank water as well - we don't. These products are all septic safe (and long drop safe), but if you have to dump in toilets best to do it when others are not watching as they might not understand that your system is chemical free.
Like Gerry, if we have to stop and dig, we choose a spot no-one else is likely to stop at - ie avoid regular camps and rest areas. It will be a slurry which disappears quickly in loose soil or sand.
Regardless of what method you use, you will want to empty after around three days.
AnswerID: 394033
Reply By: Member -Pinko (NSW) - Monday, Dec 07, 2009 at 08:35
If you do dump in a toilet make sure you clean up the specks and spatter that might occur during the exercise. Come well equiped to deal with this possibility.
Stan
AnswerID: 394042
Follow Up By: Member - Porl - Monday, Dec 07, 2009 at 10:21
As a prospective buyer of one soon, what is "equipped", having 2 kids under 5 I am in my mind to take toilet paper and sanitary wipes for the hands at the end, but I don't want to put sanitary wipes in a toilet so what do you do?
FollowupID: 662245
Follow Up By: Member - ross m (WA) - Monday, Dec 07, 2009 at 11:33
You can get special toilet paper for chemical toilets.
Another good product is the ethylene based hand cleansers that doctors/nurses use.
After a few seconds it dries and leaves no residue. It cost about $9-10 from a chemist.
Its great for avoiding the risk of faeces contamination and kids will think its magic when it goes cold and disappears: )
Any paper waste can be put into an airtight bag and disposed of at the next stop
FollowupID: 662262
Follow Up By: Member - Porl - Monday, Dec 07, 2009 at 11:34
Thanks Ross
FollowupID: 662263
Follow Up By: Motherhen - Monday, Dec 07, 2009 at 19:08
Any regular septic safe toilet paper dissolves very quickly with movement on the road. Put hand wipes in your bin.
When emptying into a long drop, take a bucket or large bottle of water to rinse the cassette and clean up any splashing on the side of the pan. If emptying into a flushing loo, there will most likely be a water source nearby.
Mh
FollowupID: 662327
Reply By: Member - Min (NSW) - Monday, Dec 07, 2009 at 13:00
Hi Jason and Avril,
I agree with Motherhen.
I have read that one of the things that causes a problem with dumping in any toilet or septic system is the volume of matter going in in one hit. This could possibly be solved by emptying in two or three batches and flushing in between. I understand that if using the nappy treatment products (which we use) there is no problem of harmful chemicals causing a problem.
Happy travels
AnswerID: 394066
Follow Up By: Member - Min (NSW) - Monday, Dec 07, 2009 at 13:08
I also understand that if using nappy products it is okay to dump in enviro or long drop loos.
I would be very grateful if anyone with expertise in this area would help clear up any misunderstandings in this matter because all we are going on at present is what others say on this and other forums, i.e. grapevine info (no offence intended to those who have contributed now or in the past).
FollowupID: 662282
Reply By: Tony - Monday, Dec 07, 2009 at 15:46
Hi, Just wondering how you use the napisan. And does it work better than the chemicals
AnswerID: 394079
