Specialist Wheel Manufacturers
Submitted: Thursday, Dec 17, 2009 at 22:54
ThreadID: 74486 Views:7695 Replies:12 FollowUps:16
Does anyone know where I could get steel offroad wheels made for a reasonable cost - looking at 9 or 10" wide and 16" diameter.
I have a unique wheel stud pattern (nato six stud) with a large PCD that no standard manufacturer in Australia makes. The best price so far is just under $400 a wheel.
Garry
Reply By: Member - Garry G (WA) - Friday, Dec 18, 2009 at 00:39
Hello Garry, As a suggestion why don't you try a tyre retailer (tyrepower/bob Jane etc}who sell rims. I'm sure they could tell you if anyone make rims in your state
AnswerID: 395535
Follow Up By: garrycol - Friday, Dec 18, 2009 at 10:10
Thanks - but no luck - they loose interest as soon as I explain what I want and they realise they do not sell what I want.
Garry
FollowupID: 664111
Follow Up By: Member - Garry G (WA) - Friday, Dec 18, 2009 at 12:20
Garry, Summerfield Engeneering in WA make rims. 08 94591078. Give then a call.
Good luck.
FollowupID: 664127
Follow Up By: garrycol - Saturday, Dec 19, 2009 at 13:18
FollowupID: 664300
Reply By: ChrisE - Friday, Dec 18, 2009 at 05:30
Where are you located?
If in Vic you can try this guy:
http://www.unlimitedindustries.com.au/
Know some guys who had some custom wheels made by him.
AnswerID: 395538
Follow Up By: garrycol - Friday, Dec 18, 2009 at 10:47
Thanks - have now sent them an e-mail - they make Patrol wheels for $305 with beadlocks - which I do not need.
Garry
FollowupID: 664116
Reply By: Member - Bucky - Friday, Dec 18, 2009 at 05:48
Try this mob
http://www.easternwheelworks.com.au
they will make anything !
AnswerID: 395539
Follow Up By: garrycol - Friday, Dec 18, 2009 at 10:48
Thanks - already tried them - just under $400 a rim.
Garry
FollowupID: 664117
Reply By: Skippy In The GU - Friday, Dec 18, 2009 at 08:27
Adelaide Wheel & Rim
AnswerID: 395562
Follow Up By: garrycol - Friday, Dec 18, 2009 at 10:54
They want a $1100 per rim.
FollowupID: 664119
Reply By: Bonz (Vic) - Friday, Dec 18, 2009 at 10:15
I would contact Chris Hummer at Dynamic Tyres and ask him.
Take a look here.
Chris is an importer of steel wheels and has lots of competition experience so knows a bit about strong wheels.
No affiliation etc but I do know he is a good guy.
Bonz
AnswerID: 395572
Follow Up By: garrycol - Friday, Dec 18, 2009 at 10:55
Already tried them and they are unable to help.
Garry
FollowupID: 664120
Reply By: garrycol - Friday, Dec 18, 2009 at 10:58
Thanks for the replies looks like if I continue this route I will need to pay about $400 a rim or maybe do a private import for not much cheaper.
Garry
AnswerID: 395574
Reply By: Simon C - Friday, Dec 18, 2009 at 12:18
Also try Mullins Wheels in Brisbane......We use them from time to time, but I still struggle with the price they charge us.....custome made = custom price !!!!!!
AnswerID: 395582
Reply By: signman - Friday, Dec 18, 2009 at 13:39
Another one for you..Titan Wheels.
Office in Wetherill Park nr Sydney...and I think their manufacturing plant is in Mildura !!
AnswerID: 395588
Follow Up By: Mandrake's Solar Power- Friday, Dec 18, 2009 at 15:50
David , There is something wrong with your email and you're not a financial member here so I cannot send a PM ..
Mandrake
FollowupID: 664172
Reply By: Member - Oldplodder (QLD) - Friday, Dec 18, 2009 at 17:14
In brisbane when we wanted some wider steel wheels for the racing rubber for the 74 beetle, we took some narrow rims (15x4.5) to a local racing wheel bloke, and they put the old centres in new rims for 15x8 rims.
They were about $120.00 each.
Plus painting, powder coating was about $40.00 each.
Try some buggy people in melbourne?
AnswerID: 395616
Follow Up By: garrycol - Saturday, Dec 19, 2009 at 13:22
Thanks the vehicle (Landrover FC 101) is a bit of a classic and the original wheels are quite rare and expensive so I really do not want to go this route. Looking for a second set of wheels so that the originals can go back on when needed.
Garry
FollowupID: 664301
Follow Up By: Member - Oldplodder (QLD) - Monday, Dec 21, 2009 at 08:39
At one stage, we were seriously considering that it would be cheaper to get the brake drum and disc brakes hubs redrilled to something standard like commodore to solve the problem. Quite a common conversion in VW beetle circles.
Is there something close that is more common that might be worthwhile converting to?
The FC101 landrover would be something different, front cab over and higher load rating I imagine?
Do Renault or Mercedes light trucks use something similar?
FollowupID: 664582
Follow Up By: Member - Oldplodder (QLD) - Monday, Dec 21, 2009 at 08:41
PS - by accident, we discovered that Hyundai excel rims fit the older beetles, that is one you wouldn't expect. Offset a bit different , but they will work.
FollowupID: 664583
Follow Up By: garrycol - Monday, Dec 21, 2009 at 23:22
The only other vehicle that has the same stud pattern are the smaller Unimogs but they have similar issues with suitable tyres.
Garry
FollowupID: 664695
Reply By: Eric Experience - Friday, Dec 18, 2009 at 21:54
Garry
What is the PCD you require,? I am thinking that a lot of bobcats use that type of wheel. Eric.
AnswerID: 395651
Follow Up By: garrycol - Saturday, Dec 19, 2009 at 13:25
The PCD is 6x210mm with 22mm wheel stud holes. The hole for the hub in the centre is 135mm.
Garry
FollowupID: 664302
Reply By: Eric Experience - Saturday, Dec 19, 2009 at 21:17
Garry.
I have 205 and 225 PCD on my two machines [American] The Bobcats from metric countries are going to be very close. Eric
AnswerID: 395723
Follow Up By: garrycol - Sunday, Dec 20, 2009 at 13:33
Thanks for that - I might have to have a closer look and see what comes up.
Garry
FollowupID: 664460
Follow Up By: ChrisE - Monday, Dec 21, 2009 at 04:28
Just check the speed/load rating and they may not meet ADR's for wheels (may or may not bother you - but may bother your insurance - imported alloy wheels can have the same issue), the good custom mob's x-ray/crack test the welds to meet ADR's I believe - may be worth the extra few $ for piece of mind depending on the k's your doing on them.
FollowupID: 664574
Follow Up By: garrycol - Monday, Dec 21, 2009 at 23:23
I guess there are not too many bobcats that can do 120kph.
Garry
FollowupID: 664696
Reply By: Steve63 - Monday, Dec 21, 2009 at 15:34
I went down that track about 4 years ago for a different vehicle. ~$400 was about the best I could do. It was still 1/2 the price of a new one.
Steve
AnswerID: 395955
