Thetford toilet fuse - useful information re fuses.
Submitted: Thursday, Dec 31, 2009 at 10:40
ThreadID: 74764 Views:9336 Replies:2 FollowUps:2
Just checking the Jayco Sterling Outback van before we take it away in a couple of days and discovered that the 'flush button' on the thetford toilet wasnt working. Checked the red fuse marked toilet/pumpin the fuse box and it was ok so phoned our local Jayco service centre for help.
The helpful man there suggested we check the purple fuse in the bottom part of the toilet locker, visible when the lower (holding) tank is removed. No mention of this in the Thetford instruction booklet which came with the van!
The husband was sent to Supercheap auto for purple fuses and a short time later it is all working again.
Thought all you fellow travellers with Thetford toilets in Jayco caravans might be able to use this information in a time of need.
Cheers.
Happy New Year
Reply By: MEMBER - Darian (SA) - Thursday, Dec 31, 2009 at 11:35
Thanks indeed - noted in my files - will have a look in my locker shortly - all such info well worth sharing - no matter how sophisticated the user instructions are on such equipment, vital info is often left out.
AnswerID: 397062
Reply By: Faulic_McVitte - Thursday, Dec 31, 2009 at 13:29
my caravan man told us to put Morning Fresh detergent in the top tank flush water so algae does not grow in the tank and jam the flush pump. Told us you can burn out the flush pump with algae. since adding good squirt of Morning Fresh no more black algae coming through. Also give quick squirt into bowl before use lubricates bowl and seals and keeps clean. caravan man said do not put antiseptic or bleach and other stuff in tank as corrodes metal and breaks down plastic.
AnswerID: 397074
Follow Up By: Faulic_McVitte - Thursday, Dec 31, 2009 at 13:30
cant find the edit button
should have said since adding the Morning Fresh we find the cassette rinses out clean and nothing sticks first time. Added bonus :)
FollowupID: 665823
Follow Up By: Member - Heather G (NSW) - Thursday, Dec 31, 2009 at 13:36
It has thetford toilet chemicals in it (pink rinse in top and green in the holding) so that wasnt the isssue. Just a blown fuse so it is working again. I posted the thread so that people would be aware that there was a fuse to the side of the bottom tank in the toilet casette locker.
FollowupID: 665824
