burke road info please
Submitted: Tuesday, Jan 26, 2010 at 10:04
Member -hamo (NSW)
G'day all,I will be in Burke mid march and going to
Tibooburra driving a rodeo and towing a 19' van,which road,I don't mind dirt or gravel but don't like corrugation,so to be sensible which is the best option,via
Wanaaring or via
Cobar or
Wilcannia via
Louth &
Tilpa,
hoping for some helpful advice.
Hamo
Reply By: Gramps - Tuesday, Jan 26, 2010 at 12:40
Hamo,
You can get some info from
this thread
All dirt/gravel roads in these areas have corrugations it's just a matter of driving to the conditions.
401097
Reply By: bardenboy - Tuesday, Jan 26, 2010 at 12:41
we drove from Burke to Tiboooburra via
Wanaaring last July in a standard Hilux.
The road was in very good condition and a very enjoyable trip
Enjoy
Dennis
401098
Reply By: Member - Tony V (NSW) - Tuesday, Jan 26, 2010 at 12:49
Hamo,
I was in
Tibooburra recently, (5th January) just as the floods were on.
The road was closed by the RTA who were working on some
washouts. the locals said that it ok to use but I decided to go back to
Sydney via
White Cliffs and
Cobar.
In dry condutions its ok with a van on the back, it does get corrgations.
It really depends on your van, is it an off road unit? If not then maybe via
Cobar and up the Kidman Hwy.
Today's report.
WILCANNIA TO
TILPA (EAST SIDE) SR1 CLOSED
WILCANNIA TO
TILPA (WEST SIDE) MR68 (A) CLOSED
You need to check closer to the dates on
Western Region and on
Central Darling Shire to be sure.
401100
Reply By: Rangiephil - Tuesday, Jan 26, 2010 at 13:11
Both the
Bourke to
Tibooburra Rd and The Darling route are dry weather only and if it rained you could be stuck for quite a period.
The most bitumin would be to go down the highway to
Wilcannia then up to
white Cliffs on bitumin.
But then
White Cliffs to
Packsaddle is dry weather only and not gravelled. I understand that they are bitumising the Broken Hill/
Tibooburra rd but I do not know how far they have gone .
While the
Louth Rd south is shown as a major track , my recollection is that it is unformed ie no gravel, certainly the last 100KM north of
Wilcannia is.
So all of the dirt roads are unpredictable. They could be great or corrugated or cut up badly.
Regards Philip A
401104
Follow Up By: Member -hamo (NSW) - Tuesday, Jan 26, 2010 at 13:48
Thanks guys very helpful,will check closer to the day just getting an idea for know.
hamo
670362
Reply By: Rangiephil - Tuesday, Jan 26, 2010 at 14:56
Reply By: Member - Duncs - Tuesday, Jan 26, 2010 at 21:15
Hamo,
I have driven
Bourke to Tib in about 6 hours when the road was good and in about 12+ when it was wet and probably closed, local advice from
Wanaaring suggested it was open but the signs at Tib end said it was closed. Things are like that out there.
Anyway, the bottom line on those roads is that they are regularly maintained and if you get there just after the grader they are great. If you get there just before the grader they are rough as. If they are wet they get closed pretty quickly but generally re-open in about 24hours.
Their is no way of getting to Tib without the risk of road closures due to rain. The most sealed road is
Bourke to
Cobar, all sealed about 2.5 to 3 hours. Then west to
Broken Hill all sealed and about 4.5 hours probably a bit more towing a 19' van. Then north from BH to Tib 390km about and about 2/3 sealed. I would count on about 5 hours.
From the pics on your profile it looks like you get out there and have a liitle go so I reckon going via
Wanaaring should present few problems for you. Check the road conditions section on this site for info that is as good as you will get anywhere.
Duncs
401207
