Pajero NM Electronic fault when engauging 4X4
Submitted: Monday, Feb 22, 2010 at 09:28
Blackass55
Im sure that someone out there has had the same problem, I have the NM exceed and recently I have what I believe to be and electrical problem (when the vehicle is cool) as cool as it can get in
Townsville
The problem is that the 4X4 display lights on the dask will flash the centre (amber) light and not display the normal 2H mode.
When this happens I can not select any of the other 4x4 functions.
When the vehicle warms up I can stop, turn off the motor, restart the motor and on most occasions the selector will go back to normal.
My problen is that the local 4X4 Pajero dealer/service centre wants to replace everything in the circuit.
Can anyone help me with pinpointing the fault.
Many thanks
Blackass55.
PB
Reply By: Member - Leanne W (NSW) - Monday, Feb 22, 2010 at 09:50
Have you tried posting on the Mitsubishi Pajero Club
Forum? Someone there may be able to help.
www.pajeroclub.com.au
I have had 2 Pajeros, but neither have had the problem you describe.
I hope you get it sorted.
Leanne
405329
Reply By: Blackass55 - Monday, Feb 22, 2010 at 12:01
Thanks Leanne
I appreciate your thoughts
PB
405370
Reply By: Member - Ryan S (WA) - Monday, Feb 22, 2010 at 12:13
Very common in the NH/J/K/L for the super-select to flash when engaging 4WD. The fix is to either go 4WD'ing more often so it gets used and engages properly, or to get under the truck and spray every electrical connection with WD40/CRC and then go bush bashing more often.
Ryan
405378
Follow Up By: Blackass55 - Monday, Feb 22, 2010 at 14:23
Ryan,
thanks fopr the reply,
I agree it isnt getting enough work.
will give it a go
PB
675115
Reply By: CraigB - Monday, Feb 22, 2010 at 13:12
As mentioned above very common problem in your model. Easiest and cheapest fix is to do what you have already been doing ie: turn off motor and restart. I had exactly the same problem with my NM exceed.
Craig B
405395
Reply By: Blackass55 - Thursday, Feb 25, 2010 at 21:26
Thankyou all for your thoughts.
I will try them all.
Regards PB/Blackass55
406029
Reply By: Member - Graham H (QLD) - Thursday, Feb 25, 2010 at 22:14
Heres one for you Pajero owners
The mechanic at the bus company bought one 2 years ago brand new and had eternal gearbox troubles
HE sold it and told me the trouble was the aircon drain was placed incorrectly and draining over some electrical connectors associated with the tranny.
406049
Reply By: Member - Barry (NT) - Thursday, Feb 25, 2010 at 22:37
Very common problem
Had NM for 11 years and problem is two fold -
vacuum lines can cause this, so check them and replace or cut off ends and re attach
if this doesn't fix it look at electrical shorts
hope this helps Baz
406056
