Which In-car navigation devise
Hi all At present I am running Ozi explorer on laptop and a separate GPS unit. I wish to change to something more compact, which would be simple to use. We do quite a bit of remote outback travels and require a tracking devise to assist in tracking our location. I'm not comfortable travelling with the laptop sitting on my lap. would anyone be able to suggest a suitable tracking system, that could be mounted elsewhere in the vehicle. Cheers Mary Anne
Reply By: Notso - Friday, Apr 09, 2010 at 23:11
Any of the well known GPS systems would do the job.
Garmin have Topo Maps available for their Nuvi series. Routing on tracks and Cities built in.
You pay extra for the Topo maps.
HEMA also have something similar Hema Navigator I think.
AnswerID: 412315
Reply By: Peter_n_Margaret - Friday, Apr 09, 2010 at 23:15
OziExplorer CE will run on any PDA Mary Anne, or the HEMA Navigator runs OziExplorer CE and will also accept all the maps you run on the laptop (up to 16Gb). That would allow easy information switching between it and the laptop.
OKA196 Motorhome
AnswerID: 412316
Follow Up By: REV'S - Friday, Apr 09, 2010 at 23:34
Hi and thanks for your reply. May be I should have added that I'm not technically minded so please keep it simple. If its not a silly Q could you please explain what PDA stands for. I'm not sure what is available. I have seen the in-dash systems but I don't really have the room for that setup, is there any other way? and what would be the best and most simple to use. Cheers Mary Anne
FollowupID: 682331
Follow Up By: Pete Jackman (SA) - Saturday, Apr 10, 2010 at 03:33
PDA = Personal Digital Assistant
IPAQ or similar
FollowupID: 682334
Reply By: Member - Doug T (NT) - Saturday, Apr 10, 2010 at 01:31
Have a little poke around in HERE
AnswerID: 412319
Reply By: Member - joc45 (WA) - Saturday, Apr 10, 2010 at 01:34
There are some nice, very cheap Chinese navigators available now; eg, this one has a 5" touch screen and takes up to 8GB SD card for about US$100:
http://www.dealextreme.com/details.dx/sku.23569
With the Oz dollar the way it is now, these are quite cost effective. They run WindowsCE beneath the user interface, but need to be unlocked to get to CE. Then you can run apps like OziCE.
There are heaps of forums, including http://www.gpsunlock.net, which provide advice on unlocking the device, tho you need to be reasonably tech savvy.
Gerry
AnswerID: 412320
Follow Up By: Member - res.q.guy (Vic.) - Saturday, Apr 10, 2010 at 06:54
Hi Gerry
I have a Garmin Nuvi and 60Cx, but currently experimenting on the same thing.
I have purchased a http://www.dealextreme.com/details.dx/sku.26917 I have downloaded and installed the menu system from gpsunlock, have got Garmin XT and Ozi Running, this week, now working on the iGo and Tom Tom sections. You certainly learn a lot, in the process.
Neil
FollowupID: 682336
Reply By: Sand Man (SA) - Saturday, Apr 10, 2010 at 08:36
Hi Mary Anne,
I used to run a PDA with OziExplorer but this type of hardware requires a reasonable skill level to install the software and get things working. The same goes for some of the solutions mentioned.
The two best solutions in my opinion are:-
Hema Navigator.
This device comes with OziExplorer and all suitable maps pre-installed and ready to go. The 5" screen on the latest model is a good size and for Australia wide off road travel this device is excellent.
If you are already familiar with OziExplorer, the Hema Navigator will give you enhanced functionality with its touch screen operation and marking of waypoint data.
Garmin Nuvi.
I am not all that knowledgeable of the finer points of the Nuvi and Doug is the best source on the forum for this solution.
The one "negative" with the Nuvi is that it uses a more proprietary software solution, whereas a device running OziExplorer is more open to share plt (track) files and waypoint data.
As has been mentioned, the addition of Topographic maps is a separate purchase and requires installation.
Bill.
Bill
AnswerID: 412326
Reply By: JAX W - Saturday, Apr 10, 2010 at 08:58
Hullo All
For the past two years or so I have been using a Panasonic Toughbook computer mounted above the centre console on a fixed bracket (like the Police have) to run all our Navigation programs. I have a Garmin 10x bluetooth GPS unit mounted on the front of the dash.
I run OziExplorer and Garmin City Navigator, depending where we are travelling. Both work really well.
Of course the Toughbook is an excellent touch screen tablet like computer, which we use for all other computer related tasks whilst travelling (e.g. Internet access, downloading photos etc).
I have no connection with Panasonic or anyone, but believe they are very hard to beat if you want quality.
Regards, Jack
AnswerID: 412328
Reply By: Member - Graham H (QLD) - Saturday, Apr 10, 2010 at 11:26
You could also look at the VMS systems which will do what you want straight out of the box.
AnswerID: 412352
Reply By: Member - Leon A (SA) - Saturday, Apr 10, 2010 at 11:28
If you want the one compact unit to do off road and street mapping I would steer well clear of the Hema Navigator, the street mapping is near unusable. I swapped my Hema for a VMS Touring 500 which is 100 times better with excellent street mapping and the same off road programs (memory map, OziCE) as the Hema. If you've already got maps you can add them straight to your device.
AnswerID: 412354
Reply By: REV'S - Sunday, Apr 11, 2010 at 23:09
Hi Thanks for all replies. and suggestions etc. I'll be attending the upcoming Rosehill 4x4 camping show soon and be visiting the appropriate stand with a lot of Questions. Thanks heaps. Mary Anne
AnswerID: 412599
Follow Up By: vk1dx - Monday, Apr 12, 2010 at 08:45
Our son is also looking. We want an indash unit but the problem I am coming across is the SD card capability. The one we have needs at least 4Gb on the card for program and map files.
It would be very very hard to steal ours. Even the installer had trouble taking it out to check the antenna connection. I watched him. Poor character. But I flet good about the security.
I have heard the there may be more out in May so if its not urgent keep your options open.
But all that aside I strongly recommend the indash units. You can even get 7" screens now.
FollowupID: 682663
Follow Up By: REV'S - Monday, Apr 12, 2010 at 22:38
The 7" screens sounds great. We have a 70series landcruiser, and have a radio and UHF radio already fitted on the dash with not a lot of room remaining for anything else. Where would it be possible to fit one ? Mary Anne
FollowupID: 682739
Follow Up By: vk1dx - Tuesday, Apr 13, 2010 at 09:16
They are double din units and mount right into the dash.
Ebay example.
I am not necessarily recommending the one in the ebay link. I do not know a lot about the latest trends. Maybe next lot will include a FULL PC in the dash. Just an "old man" looking for a better GPS for our sons car.
You will find quite a few on ebay. But be careful of one thing. The greater majority I have seen so far use an SD card for map storage. Ours came with a 4Gb SD card and the maps I wanted to use on Oziexplorer amounted to more than 4Gb. Luckily ours took a 8Gb card. We have a VMS AVNC Mk2. I have not used the street nav yet but it looks like any other one. At least I recorded my own voice for the instructions for Ozi. Why can't they use an Australian for the anouncements. nah He may use slang (as I did) that no one would understand these days. My wife nearly shot me when she heard "Left ya mug" come out of the speaker.
I will say though that once you get one in the dash you won't want the laptop. Unless of course you are "tied to society" with emails, the internet and so on. Poor people. Just cannot fly the nest. That's get a response I betchya.
Phil (hope the able to get up to that show as well)
FollowupID: 682767
