tx472 transmitter..need help.
Submitted: Saturday, Apr 10, 2010 at 22:31
FJ62tojo1985
hey there, i have just purchased a toyota landcruiser fj62.....i have a problem with my UHF.......i can recieve, but cannot transmit....the model number is tx472s, i think the problem may be the mic....does anyone know where i can purchase a new one, and if not a new one, a second hand one.Please help, as i am in need of the UHF, and dont really want to do away the the old unit.Any help would be greatly appreciated.Brett
Reply By: Dave(NSW) - Saturday, Apr 10, 2010 at 22:45
Most truck stops will carry spare mics for UHFs or Tandys/Dick Smith, Depends wear you are.
412450
Follow Up By: FJ62tojo1985 - Saturday, Apr 10, 2010 at 22:47
cheers for that mate, tryed a couple of stores so far....with the reply's.."sorry they dont make the mic's for the unit anymore".....so yeah, will look in the stores you mentioned.
682469
Reply By: Twintrail(W.A.) - Sunday, Apr 11, 2010 at 00:27
hi had the same problem with a mike , try to open it up and for shore 1 loose conection will be the problem, solder offeneding wire . should overcome your prolblem. regards
412456
Follow Up By: FJ62tojo1985 - Sunday, Apr 11, 2010 at 01:10
cheers for that!funny was just doing tht!
682472
Reply By: DIO - Sunday, Apr 11, 2010 at 10:39
Check with Electronic Bug. They stock quite a bit of secondhand stuff.
LINK If they don't have it, they may be able to recommend another.
412493
Reply By: Stu & "Bob" - Sunday, Apr 11, 2010 at 12:35
the other thing to check is for a broken centre conductor in your co-ax.
Usually happens just after the connector. The broken centre conductor will let you receive, but not transmit. Be careful here, as to continue to try and use it will damage the power amplifier in the radio.
HTH.
412517
Follow Up By: FJ62tojo1985 - Sunday, Apr 11, 2010 at 23:47
cheers for your help!!!excellent advice.
682646
Reply By: bjgard - Sunday, Apr 11, 2010 at 18:15
check that you haven't turned VOX on. Took my Uniden out and down to Electric Bug, the tech heard me talking to the sales man who was in the throws of booking it in. Tech grabbed the radio went away and less than 5 minutes was back there fixed no charge. Ok what was wrong? usual problem VOX turned on, have turned it off and now your mike will work. It does.
412551
Reply By: Stu & "Bob" - Sunday, Apr 11, 2010 at 19:11
Found this on ebray.
Electrophone mic
412567
Follow Up By: FJ62tojo1985 - Sunday, Apr 11, 2010 at 23:46
cheers for the help mate, but this tranmitter is a five pin mike.....where
mine is a 6.cheers heaps anyway.
682645
Reply By: Michael46 - Sunday, Apr 11, 2010 at 21:14
