What's to see in the Eastern Goldfields? Kal to Laverton in 3.5 days
Submitted: Sunday, May 09, 2010 at 23:01
ThreadID: 78346 Views:6368 Replies:5 FollowUps:13
Hi all,
I have 3 and half days to kill in the Eastern Goldfields starting from Kal and ending up in Laverton.
I been down the Connie Sue, been to Queen Victoria Spring through Yindi and visited Lake Yeo..
I'll probably visit Plumridge Lakes, Mount Luck and Lake Rason however is there any other "must see" places when I'm in the area?
Reply By: Member - Peter W (WA) - Monday, May 10, 2010 at 01:30
equinox
Going north from Kal, call in and see Niagra Dam and then carry on to Kookynie.Well worth the visit.
AnswerID: 416058
Follow Up By: equinox - Monday, May 10, 2010 at 19:57
Hi Peter,
I saw them both coming back from GCR last year. The dam is a pretty fine piece engineering out in the sticks; We were the only customers at the Pub - the beer tasted nice too!!!
FollowupID: 686252
Reply By: Member - Stephen L (Clare SA) - Monday, May 10, 2010 at 08:25
Hi Alan
Include The Lake Rason Area in your trip, as you could spend that time there alone. We will again be visiting the Lake Rason Area. Lots to see and poke around. Mallee Hen Rocks is well worth the drive in. Also the 7MM Hut should have been rebuilt, that is a real home away from home. Around Laverton there is Hanns camp and other interesting place like Albert Rockhole.
You should get more replies from other travellers of that area.
Image Could Not Be FoundImage Could Not Be Found
AnswerID: 416071
Follow Up By: equinox - Monday, May 10, 2010 at 19:59
Thanks for the info Stephen,
I couldn't find Hanns camp last time, however have the correct co-ords now :))
Albert Rockhole looks good.
FollowupID: 686254
Reply By: get outmore - Monday, May 10, 2010 at 09:30
Try the golden Quest discovery trail. The guidebook should be available either from the tourist beureu or newsagents
Ive marked a coule of extra spots on there A being breakaways at the nth end of Wangine lake
and B being the Anthony Gormly satues on lake ballard
http://i147.photobucket.com/albums/r308/wudinna/IMG-4.jpg
other features being the broad arrow pub
and historic ora banda pub with its shady past
as well as old mining centres and ularing soak
The Woodlands around the area consisting of blackbuts, gimlets and salmon gums will make a welcombe change from the desert to the East
When at Kookynie ask at the pub for the mudmap to nearby granite rock formations such as
split rock
balancing rock
and others
AnswerID: 416075
Follow Up By: get outmore - Monday, May 10, 2010 at 09:33
sorry heres the pic of the Lake ballard statues
FollowupID: 686157
Follow Up By: equinox - Monday, May 10, 2010 at 20:01
Thanks Davoe,
I reckon I'll be hanging east of the highway however will add these to the list.
FollowupID: 686256
Reply By: Member - Duncan W (WA) - Monday, May 10, 2010 at 09:46
Alan as part of Australasia Safari last year I had the chance to travel around Lake Minigwal. If your coming from Kal, head up via the Kurnalpin Pinjin Rd to the Nippon Hwy then North to Lake Minigwal. The area abounds with rock holes, and Gnamma holes and old abandoned mines and communities.
Around the lake has some fantastic scenery as well.
Dunc
AnswerID: 416084
Follow Up By: equinox - Monday, May 10, 2010 at 20:02
Hi Dunc,
I will check it out, as the route you mention is roughly the way I was thinking of going.
FollowupID: 686257
Follow Up By: get outmore - Monday, May 10, 2010 at 21:31
ill sort you out a short detour (actually its a short cut) tomorrow at work that takes in an old telegraph line, a coupleof Gnamma holes and hunts pinnacles if you go that way
FollowupID: 686276
Follow Up By: equinox - Monday, May 10, 2010 at 22:18
Thanks for that; Hunts Pinnacles sound interesting...
My email addy is in my profile.
FollowupID: 686288
Follow Up By: get outmore - Tuesday, May 11, 2010 at 09:25
righto - heres a cutn paste from a while back - if the directions look dodgey then follow your nose from the map
Hunts pinnacles
After Seeing these Pinnacles onmy previos trip to Queen Victoria Springs I decided to go for a look
I took off from kalgoorlie and headed n/e along yarria road past kanowna belle Mine and then the Hills which make a good playground. Just after the hills it is east onto the Kurnalpi pinjin road until (all 51j) e 437829 n 6626541 where there is a grid and you turnleft following the fenceline until e437476 n6628665 where you come to yowie rockhole and turn r through an open gate onto an old telegraph line. e4445588 gilgarna rock and rockhole kso until e445591 n 6644036 where there is an open gate but you head left (n) if you go straight on you rejoin the Kurnalpi pinjin road. e443803 n 6620269 there is a tank alongside the track and looking to your left is Hunts Pinnicles you drive accross the samphire salt pan to get to it e442633 n6649896. They are a series of steep hills grouped together that tower above the flat soroundings with breakaway formations at there base and caves higher up with a cairn atop the highest pinnicle. This trip is easily do able as a day trip from kalgoorlie or can be part of a longer trip to Queen victoria Springs
hers a pic from the telegraph line which gos to old pinjun (well worth a look in itself.
the pinnacles are maybe a bit less impressive than they sound but are an interesting diversion in a pretty flat area
id scan some pics if i was home. You can see them off in the distance from gilgarna rockhole and i new i had to have a gander
FollowupID: 686324
Follow Up By: get outmore - Tuesday, May 11, 2010 at 09:31
sorry try this
FollowupID: 686325
Follow Up By: equinox - Tuesday, May 11, 2010 at 19:17
Thanks for the info Davoe!!
FollowupID: 686430
Reply By: Kanga1 - Monday, May 10, 2010 at 10:46
Hi Alan, I will be heading out to the 7MM shack this week, should arrive Thurs afternoon, and spending 3-4 days based there. When are you looking to be in that neck of the woods Alan? I'll make sure to have a couple of coldies. Cheers, Kanga.
AnswerID: 416093
Follow Up By: Member - Lionel A (WA) - Monday, May 10, 2010 at 18:13
Al,
Theres a little place in Hay St.
181 reasons to visit......hehehe.
Cheers......Lionel.
FollowupID: 686233
Follow Up By: equinox - Monday, May 10, 2010 at 20:05
Hi Kanga - MM sent
Lionel,
It's hardly a little place :)
I remember walking back from the pub in the nineties when I working in the area, always avoided the place - one of the commandments you know - do not yield to temptation, something like that!!!
FollowupID: 686258
Follow Up By: Alan S (WA) - Monday, May 10, 2010 at 22:28
Lionel
Back before metrics came the street address there was no 69 hay st. But the metric conversion changed ot to 181.
FollowupID: 686291
