Tuesday, May 25, 2010 at 15:32
I can't believe YOUR luck - not only found the vessels, but the receipt too!
The last were from Bunnings 16May2010:
Water Container Expandable 10L WE10" $7.48
Water Container Collapsible 20L WE20" $7.48 (yes, same price)
Packaged:
WE10 looks like a side-on crushed Jerry can - handle & tap up top 410 x 270 x 55; expands to (410x270) 250mm and then is football shaped - like variable depths - 55 becomes 100mm, and 210 & 250. Its label says 35Lx25Wx28H (cm) expanded.
WE20 is 250 x 250 and ~100mm flat including central handle and tap on top. It (unfolds &) deepens out to 250mm height plus the ~50mm handle & tap. Its label says 29Lx29Wx33.5H (cm) expanded.
Both taps are the removable 1.5" threaded types with ~10mmID outlet "twist-arm" handles.
Both are made in Taiwan by "ALL SET" (TM) - "The Intelligent Design Co.".
Material - recycle #4 LDPE.
FYI - the ancient one I have from years ago is "Reliance" - made in Canada.
I also have another recent one that looks like the WE20 - I don't think I got that from Bunnings though... Use a few times; so far so good.
688121
