UHF aerial info
Submitted: Tuesday, May 25, 2010 at 20:29
Member - Warren R- Karratha
Hi Folks
I'm considering removing the fibreglass aerial from the bullbar and fitting a smaller aerial in the aluminium wind deflector on the front of the roof rack. The wind deflector sits at about 45 degrees, and although I can adjust the aerial to be vertical, I don't know if it's critical for the ground plane material to be horizontal?
Any thoughts welcome.
Waz
Reply By: oldpop - Tuesday, May 25, 2010 at 20:46
Waz
Just use a small Aerial like a Mobile one CD470 2.1 Db Ground Independant
Oldpop
418123
Reply By: Robin Miller - Tuesday, May 25, 2010 at 21:37
It can be important Waz, put your eye at the centre position of the proposed aerial and if you can't see the horizon past the wind deflector, then its a problem.
Would it be possible to pop-rivet a small bracket at the top of the wind deflector such that you have a flat surface to mount a cheap $15 1/4 whip on.
This will work
well , ideally the flat surface would be 15cm across but even 5cm will give acceptable results compared to the radiation pattern distortion one gets from bullbar mounts.
418143
Reply By: Mike DiD - Tuesday, May 25, 2010 at 21:39
You won't get decent coverage unless you use a Ground-independant antenna, but these will be at least 30 cm high.
You might be better off getting a high antenna that mounts off the mudguard.
418144
Follow Up By: Member - Warren R- Karratha - Tuesday, May 25, 2010 at 22:45
Thanks Mike.
I'm moving it up and back because I've put a couple of spots on the roof to light up the roadside and the aerial bounces the light back.
688191
Follow Up By: Member -Signman - Wednesday, May 26, 2010 at 15:06
Why not put a sleeve of heat-shrink (black) over the existing antenna ??
688270
Follow Up By: Mike DiD - Thursday, May 27, 2010 at 20:22
It will detune the antenna - I'm not sure by how much.
688552
Follow Up By: Member -Signman - Friday, May 28, 2010 at 09:57
Nah...
688605
Reply By: Dion - Wednesday, May 26, 2010 at 07:37
Waz,
it looks like your antenna is a 1.2m GME AE4705. This antenna is available in
grey as
well as white.
Have you considered changing it to
grey to overcome your problem? It would suit your vehicle, also being a shade of
grey.
Dion.
418175
