Cooper creek ferry.
Submitted: Monday, Jun 21, 2010 at 19:11
Gitto
Just want to know if 4wds with campertrailers are allowed to cross the ferry. Looking at travelling down from
birdsville around 26th july and heading to
lyndhurst if at all possible and whats the
water depth leading up to the crossing on the
birdsville track. Any help appreciated.
Reply By: Member - Stephen L (Clare SA) - Monday, Jun 21, 2010 at 19:30
Hi Gitto
The simple answer is that you will not be able to take your camper over on the ferry. Even though you will not be able to do so, it is worth heading down for a few days and just take it all in. As for the
water depth, it was 5 metres deep at the ferry crossing and expected to rise over a further metre.
StephenImage Could Not Be FoundImage Could Not Be FoundImage Could Not Be Found
421656
Follow Up By: Member - Nick (TAS) - Monday, Jun 21, 2010 at 20:37
Not that Ill be up there but would it be possible to load camper first, take it over and push it off then go back for vehicle??
692073
Follow Up By: Member - Stephen L (Clare SA) - Monday, Jun 21, 2010 at 20:47
Hi Nick
To do this you will have to have a few good strong mates. As you can see, there are only two ramps and there is no where for the jockey wheel to go. The ferry operator will have the final say and they have no responsibility to help load and unload any goods.
692074
Follow Up By: Member - Nick (TAS) - Monday, Jun 21, 2010 at 20:54
Yeah good point, forgot about jockey wheel.So maybe if you were travelling with another vehicle not towing it may be possible.
692078
Follow Up By: Member - Prickle (SA) - Monday, Jun 21, 2010 at 21:36
I think it may have been Larry (ferry operator) saying, that they will not take campers at all. I believe his post clearly said, campers cannot be put on alone.
So I gather no campers under any circumstances.
692087
Follow Up By: bushman401 - Tuesday, Jun 22, 2010 at 14:10
Hi guys yes its larry sorry but no trailer to be put on not attached to a vechiel us guys dont make the rules we just enforce them .
There is a
gate at each end that must be shut OHS&W rules .
20 years ago you could get away with a lot more than you can now.
But still do the ferry ride you may never get to do it again.
Larry
692142
Follow Up By: Member - Stephen L (Clare SA) - Tuesday, Jun 22, 2010 at 14:46
Hi Larry
Good to see that you monitor this great site. It was great to have the ferry rides and we will be back again in August, this time to spend about a week there. Has the
water level risen much in the last week. I have not sent off the pictures to you yet, but will do so very soon.
You are doing a great job,
well done.
Stephen and Fiona
The Black Prado with the Yellow Kayak.
692144
Reply By: olcoolone - Monday, Jun 21, 2010 at 22:11
According to the SA gov site you can take camper trailers across as long as the total length does not exceed 7.8m and the trailer must remain hitched to the tow vehicle whilst crossing.
Link
www.transport.sa.gov.au/quicklinks/northern_roads/area1.asp
It's all under "special notices" - "
cooper creek ferry information"
421680
Reply By: Ozhumvee - Tuesday, Jun 22, 2010 at 08:28
I took my camper across in 1990 on the back of the 75 series troopy but it was only a very light hardfloorCUB Supamatic, basically just a tent on
wheels. It only just fitted with only inches front and rear, it also had a very short drawbar so it wouldn't fit now. The biggest problem from memory is the weight distribution as the trailer is lighter than the front end of the vehicle so the ferry gets very low on one side if the weight isn't even. There was a bit of umming and arring when I went on as to whether it would fir and be safe.
At a guess most larger 4wd's towing the current crop of campers would not fit.
421704
Reply By: Member - Duncs - Tuesday, Jun 22, 2010 at 09:47
Not
Birdsville but....
We crossed the Wenlock on a hand pull barge in 1999. My camper would not fit on the barge behind my GQ. Fortunately we were able to hook it behind a much shorter Discovery that was travelling with me. It was still a close call. Those operating the barge were very supportive but we were the only ones there at the time.
If the operators will not allow it that really is the end of the story, as it would have been for us at the Wenlock. I can understand the operators not wanting to muck around when they have a line up of customers.
Duncs
421723
Reply By: Browny66 - Tuesday, Jun 22, 2010 at 14:05
G'Day All,
1st post in several years for me, getting back into the 4wd &
camping scene after a long lay off, (Hopefully it's not to silly a question) The wife
young fella and I are heading off on a trip around OZ in mid August and had planned to be in
Birdsville for the races, but with us towing a camper am I right in thinking we must find an ulternative rout other than the
Birdsville track (leaving from
Melbourne) if so any suggestions/recomendations on how to get there would be appreciated.
Cheers Browny
421741
Follow Up By: Browny66 - Wednesday, Jun 23, 2010 at 17:32
Thanks Crackles
692249
Reply By: Teraa - Tuesday, Jun 22, 2010 at 18:27
Sounds like a littel zuzuki 4 x4 would be handy sitting by the ferry you could make some dollars. The visitors to the northern end is very low so local buisiness is feeling the pinch.
421770
