Removing Ugly Stickers
Submitted: Thursday, Aug 12, 2010 at 06:51
ThreadID: 80662 Views:3873 Replies:9 FollowUps:4
Our van cam with a few ugly stickers that I just can't budge
Have tried euclyptus oil and Oomph but no luck
Any help appreciated
Di
Reply By: On the Run - Thursday, Aug 12, 2010 at 07:23
Try a paint stripper heat gun on a low setting to soften the sticker and they easier to get off, used it on our 20ft van to remove the pin stripping and van logo............
Cleaned up any hard to budge residue with selleys sugar soap.
Used a hair-dryer first but it couldn't handle the constant long use.
good luck
AnswerID: 426996
Follow Up By: Cruiser 2091 - Thursday, Aug 12, 2010 at 08:07
Yep I agree.
I brought a really cheap heat gun from Bunnings and stickers I previously thought were impossible to remove just peeled away.
FollowupID: 697591
Reply By: Member Brian (Gold Coast) - Thursday, Aug 12, 2010 at 07:24
Try using a hair dryer to warm them up.... then you should be able to remove them. It's worked for me quite a few times!
Brian
AnswerID: 426997
Reply By: GoneTroppo Member (FNQ) - Thursday, Aug 12, 2010 at 07:25
I got rid of the Defender decals on my old Land Rover which were very hard and faded, with rubber disk thingy that I got from a auto paint place.
Apparently it's used by the pros to get pinstiping and similar stuff off.
You just put it on the end of a drill. It kind of works like a large high speed eraser. Took me an hour to get rid of about 1.5 sq m of hard stuff that hadn't shifted any other way.
AnswerID: 426998
Reply By: Sand Man (SA) - Thursday, Aug 12, 2010 at 07:29
Di,
Remove as much of the sticker as possible to enable the dissolver to penetrate better.
Try Orange Power Sticky Spot and Goo Dissolver. It comes in a small orange bottle of 110ml and should be available from your local supermarket.
Bill.
Bill
AnswerID: 426999
Follow Up By: didiaust - Thursday, Aug 12, 2010 at 08:23
Can't remove any at all if I try I sctatch it
Will try the heat gun
Thanks folks for your prompt replies
Di
FollowupID: 697594
Follow Up By: Fab72 - Thursday, Aug 12, 2010 at 09:47
T-Cut or Baby oil and a cotton ball.
FollowupID: 697599
Follow Up By: Member - Graham H (QLD) - Thursday, Aug 12, 2010 at 09:51
Buy some DISSOLVE IT from Woolworths.
Turps also works.
FollowupID: 697600
Reply By: Member - Carl- Thursday, Aug 12, 2010 at 10:16
Heat gun as above and "Shellite" for the glue. Will not scratch.
AnswerID: 427010
Reply By: Member - MUZBRY(Vic) - Thursday, Aug 12, 2010 at 10:39
Gday
We used to blow them off with the high pressure washer on cold. The stickers break off and float away.
Murary
AnswerID: 427012
Reply By: Member - Peter M (QLD) - Thursday, Aug 12, 2010 at 11:03
Try Preen spot remover or No More Bugs
I have found that you have to spray it on in small areas allow to soak for awhile & then hit the same area again and use a plastic scraper similar to the type you would use in a deep freeze or frig to remove caked on ice etc.
If all else fails use eucalyptus oil same instructions as above
Peter M
AnswerID: 427013
Reply By: Member - Doug T (NT) - Thursday, Aug 12, 2010 at 23:58
Try this.....try that..... just grab your wifes Hair dryer , if your not married you got a problem. Haaa I have used the one I had to dry little Dusty when he was alive, If you don't have a dog....you got a problem.
AnswerID: 427084
Reply By: Member - Jason B (NSW) - Sunday, Aug 15, 2010 at 18:33
Hi Di
I have had to do this exact thing to quite a few of my vehicles over the years. Most of the options above I have used to great affect. When they are really old and etched on there are only a few options that have worked for me without damaging the paint. The best place to get advice or the equipment I recommend is your local panel beater or graphic/sign writing (sticker) place
Firstly I would try PREPSOL which is a grease and wax removing solvent (like thinners) which will dissolve the glue without damaging the paint at all (unlike thinners or paint stripper). Just rub it on soaking the stickers with an old rage (great for removing Tar from your vehicle/van also.
Secondly I would try a heat gun and a plastic scraper (from sticker place/window tinters) this is what the graphics places use for removing stickers and window tint, and the plastic scraper doesn't scratch.
Finally when all else has failed, the pros use a rubber (like an eraser) on a drill attachment. This simply rubs the stickers of as it rotates in the drill. This does not scratch or leave any marks at all.
I have used all of these methods and have never failed. Don't use the Prepsol around you heat gun as it is highly flammable.
Jason
AnswerID: 427316
