Wednesday, Aug 25, 2010 at 20:21
Luxboy
Garry is right about the hook on the front of your car. It is listed in the owner's handbook as a towing hook. If you contact Toyota direct, they will tell you they do not support the use of snatch straps and their cars are not rated for them.
Having said that, just about everyone uses that hook and most get away with it. There are examples on the net though of them, and similar hooks on other cars, breaking. Your best bet is to use two of them with an equaliser strap between them. You will find that hook can also be bolted straight on to the other side of the chassis. Buy another one, or better still two new ones if you don't know the history of the car, and attach them with new genuine Toyota bolts. While doing that, thoroughly check the condition of the threads in the chassis for rust.
It is not a good idea to snatch off the tow bar on the 2004 or earlier Hilux. The chassis are too lightly constructed. I am not sure if the later models are heavier or not. I know of two cases where the leverage caused by the bar trying to rotate around the side mounting bolts caused the chassis to crack through the bolt holes and the bars were ripped right off with the last 100 mm or so of the chassis still attached to them.
The outriggers on the side plates on the bar extend forward and sit in square holes in the chassis. They are designed to resist the twisting of the bar as a load is applied during towing and they work very
well. Unfortunately the loads imposed in snatching often exceed the maximum towing capacity of the car and that is where the problem lies.
If you must use that bar then be very gentle. That should be easy to do in sand. Take a shovel with you and move a lot of sand from in front of the
wheels. Don't just scrape a bit out by hand. If you do it properly you may find the stranded car will drive out without having to use the strap.
699153
