landcruiser 100 series stud patterns
Submitted: Sunday, Aug 29, 2010 at 19:59
vicex
need help with landcruiser stud patterns i am buying a new caravan getting landcruiser
wheels so i don't have to carry extra spares sounds strange but hav'nt bought cruiser yet when and what model do they change are ifs different need to tell dealer wich ones to put on caravan thanks guy's.
Reply By: rumpig - Sunday, Aug 29, 2010 at 20:09
can't help with when they changed, i thought all 100 series were 5 stud but i could be wrong. IFS have a different offset in the rim to live axle models though, that much i do know.
428876
Follow Up By: Muddie - Sunday, Aug 29, 2010 at 20:49
Oct. 2002 saw IFS front end fitted to all models except the pov pack and GXL diesel wagons with the 1HZ engine, the very flat looking 40mm offset 5 stud
wheels.
699625
Follow Up By: Muddie - Sunday, Aug 29, 2010 at 20:56
Some IFS models,
Kakadu Sahara also came with 17"
wheels just to make it harder, you really need to buy your cruiser first.
699626
Reply By: Member - Phil G (SA) - Sunday, Aug 29, 2010 at 20:48
Any 100series landcruiser with the factory TD (2000-2007) or Petrol V8 motors will have IFS.
Any 105series Landcruiser with the 1Hzzz (1998-2006) normally aspirated diesel motor or 4.5litre 6 cyl petrol motor (1998- about 2002) will have a rigid front axle.
The stud patterns are all 5 stud, but the RFA have zero offset, while the IFS have 60mm of offset. 60mm is a lot, so you have to specify offset if you want the
wheels to match.
428885
Reply By: Member - Carl- Sunday, Aug 29, 2010 at 20:52
The caravan brakes will most likely come from "Vehicle components". Check with your caravan manufacturer if this is their source.
All the manufacturer will need to do is ask for 100 series stud pattern and they will know what to supply.
The stud pattern has not changed from 100 series to 200 series.
428886
Reply By: Injected - Monday, Aug 30, 2010 at 16:25
Vicex
The Landcruiser stud pattern is 5/150pcd. Another words they are 5 studs on a PCD of 150mm. They all run 14mm suds and are all the same from early 100's through to 200's and the new 76 series wagons/ utes.
As mentioed above the critical thing is the offset.
Vehicle components or ALKE can help you out if required.
428939
Follow Up By: Injected - Monday, Aug 30, 2010 at 16:26
Sorry that should be ALKO.
699662
