VIEWING PILOT LIGHT
Submitted: Tuesday, Aug 31, 2010 at 22:32
aggie
I WOULD KIKE TO THANK ALL THOSE WHO ASSISTED WITH TIPS ON THE 3WAY FRIDGE IN 1988 VISCOUNT. ONE LAST HURDLE ...AT NITE THE SOFT GLOW OFTHE PILOT LIGHT, HOWEVER HAVING THE THAT SMALL VIEWING HOLE DOES NOT ALLOW FOR DAYTIME RELFLECTION OF FLAME IS THIS CORRECT OR IS THERE A KNACK INVOLVED.
Reply By: Shaker - Tuesday, Aug 31, 2010 at 22:45
It is regarded as bad manners to SHOUT!
429068
Follow Up By: Gone Bush (WA) - Tuesday, Aug 31, 2010 at 23:06
Image Could Not Be Found
699788
Follow Up By: ModSquad - Wednesday, Sep 01, 2010 at 13:29
Shaker,
All people have to start somewhere.
GB,
That is quite a good explaination of why not to use the Caps Lock Key.
The ModSquad
699823
Follow Up By: Shaker - Wednesday, Sep 01, 2010 at 16:03
I guess that is true, but they also learn by being told, as I was in the early days.
699830
Follow Up By: Gramps - Wednesday, Sep 01, 2010 at 18:15
No wonder people leave this site or are afraid to ask questions with this sort of response likely
AnswerID: 429068 Submitted: Wednesday, Sep 01, 2010 at 18:13
Shaker replied:
That is downright rude and totally uncalled for.
699840
Follow Up By: Member - Mark G Gulmarrad - Wednesday, Sep 01, 2010 at 20:45
Gramps
he probably GOOGLED it
699859
Follow Up By: Gramps - Thursday, Sep 02, 2010 at 17:56
This post has been read by the moderation team and has been moderated due to a breach of The Trolling Rule
Forum Moderation Team
699945
Reply By: aggie - Tuesday, Aug 31, 2010 at 23:13
sorry about the caps loc on still learning site etiquette
429071
Follow Up By: Member - Mark G Gulmarrad - Wednesday, Sep 01, 2010 at 20:47
aggie
no harm done there mate.......cant learn if ya dont make mistakes,cheers. :-))
699860
Reply By: Nev (TAS) - Wednesday, Sep 01, 2010 at 07:32
Hi Aggie,
all the vans I have seen with gas fridges have been as you say. Best thing is to try and darken around the aperture and see if you can see the flame then. Can be a bit of a pain at times.
Rgds
Nev
429079
Reply By: Ray - Wednesday, Sep 01, 2010 at 08:15
This post has been read by the moderation team and has been moderated due to a breach of The Inappropriate Rule
429082
Reply By: Nargun51 - Wednesday, Sep 01, 2010 at 10:29
Most van fridges have either a small prism or mirror to allow you to view
the pilot light. Check to see of there is not one there which has not been knocked out of place or out of alignment.
If there is not one there, work out whether the light can be seen with a small mirror and, if so, use some bluetac to fix a small mirror in the right place.
Been there, done that
429097
Reply By: The Geriatric Gypsie - Wednesday, Sep 01, 2010 at 10:39
429098
Reply By: Member - mazcan - Wednesday, Sep 01, 2010 at 14:55
hi aggie
on the gas fridges of that vintage the mirrow may have become dirty
or
the other thing that can course a problem which i found while renovating an 80's caravan last year
was that there is what i call a vision tube attached between the mirrow and ends close to the burner at the rear this tube which is about 25mm in diameter fits close to the mirrow assembly and creates a dark tunnel back to the burner which allows you to clearly see the burner flame
if this tube has been damaged and or dislodged from it correct position it will allow normal daytime light in to the normally dark tube and distaught the mirrow vision so that the clear view of the burner is iliminated by this source of light entering the tube
or there could also be a spider web in this tube blocking this vision
i had to remove the fridge and tilt it over to get to and fix the tube back in place i also cleaned the mirrow while at it
i was then able to see the burner flame through the viewing mirrow at all times
from memory i think the mirrow lens can be cleaned from the front of the fridge with the door open and/or off which would be step one if that does'nt help then the above tube will be the problem cheers hope its only a dirty mirrow cheers
barry
429105
Follow Up By: Member - mazcan - Wednesday, Sep 01, 2010 at 15:38
hi aggie
dont know if you went back to your original thread as it appears you started another
so if you want more gas fridge helpfull hints check out thread 80779
699828
Reply By: Ray - Thursday, Sep 02, 2010 at 08:09
This post has been read by the moderation team and has been moderated due to a breach of The Moderation Complaints Rule
429157
Reply By: Member - Gavin W (QLD) - Thursday, Sep 02, 2010 at 12:19
