looking for an Landcruiser75 intusiastic cheap mechanic around Sydney
Submitted: Tuesday, Sep 07, 2010 at 18:36
ThreadID: 81189 Views:3250 Replies:4 FollowUps:1
I bought a good running 1978 Type 75 Landcruiser (Troopy) from backpackers.
Its steering a little sideways, they said, they hit a hole on a dirt track.
I would like to find a mechanic around Sydney who is able to see, if its only wheel alignment that has to be done, or if there is a part that has to be changed.
So Troopy experience is needed.
Does anybody no somebody or a honest workshop, that did lots of work with them?
thanks guys
Reply By: Member - Tour Boy ( Bundy QLD) - Tuesday, Sep 07, 2010 at 18:43
Hi Chris,
First of all the 1978 landcruiser is a 45 series the 75 series started in late 1985.
Secondly is it just the steering wheel that is crooked or is it crabbing down the road. If it is crabbing, it will have loose / broken U bolts holding the diff on or a broken centre bolt on the spring pack.
Any mechanic should be able to eye the u bolts off in about 20 seconds. There will be scrape marks on the springs if it is the bolt (from where the diff slides forward and back under acc or decelleration).
Dave
Dave
2015 Fortuner
Had 72 cruisers in my time
AnswerID: 429620
Follow Up By: Chris@forum - Tuesday, Sep 07, 2010 at 19:22
hi Dave, thanks, thats a nice Coaster!
I mixed up the numbers, its a 87 Troopy, not quite that old.
Yes, you are right, I shouldn't assume the worst, maybe its just the U bolts.
I let somebody have a look and see what he says
Chris
FollowupID: 700389
Reply By: Member - Alastair D (NSW) - Wednesday, Sep 08, 2010 at 08:03
Chris,
I have used HiTech 4wd in Penrith for work that I choose not to do myself. They seem knowledgeable and are happy to talk about options or possibilities before pulling things apart.
I have also heard that the chap in Seven Hills who is often referred to on this forum is very good. I do not have first hand experience only from others.
It does sound like the hit has shifted the axle. A simple tape measure will tell you if the axles are parallel and in the right place.
good luck.
AnswerID: 429638
Reply By: Signman - Wednesday, Sep 08, 2010 at 15:36
If the steering is 'wandering' a bit- could be worn spring shackle bushes. I changed ours to the teflon?? type material, and it made a huge difference.
AnswerID: 429667
Reply By: Chris@forum - Thursday, Sep 09, 2010 at 10:15
thanks guys, great help!
I will slide myself under it and measure a bit around
AnswerID: 429738
