Googs Track
Submitted: Thursday, Sep 09, 2010 at 08:49
Member - david t (INT)
is googs suitable to travel in x trail (lifted 50mm )towing camper trailer as we are considering as an alternative to doing
corner country due to recent rain events and reading other forums looks like a lot of others are wanting to do either Corner or
Birdsville during school holidays and rd conditions may get bad with all that traffic cant see a grader getting out their to soon either?your thoughts
cheers Thommo
Reply By: Member - Duncs - Thursday, Sep 09, 2010 at 09:38
Thommo,
Your rig looks
well set up and the Trak Shak will have no problems.
I am not particularly familiar with the capabilities of the X Trail but yours does look good.
Goog's Track is
well defined and
well travelled. It is a sandy track through dunes and as a result has some steep, soft sections that require a certain amount of skill to negotiate. Many of the dune crests are rutted and wheel travel may be an issue for the X Trail. Some of this you can be negotiated by careful wheel placement, but not all of it.
I suspect an experienced driver would be able to get your rig through but not knowing yours or your vehicle's capability I am not willing to give a definite either way.
Have you had the rig on steep sand before? How did you go? I did not think Goog's was particularly difficult but the potential for trouble is there, especially if you don't take it seriously.
Duncs
429735
Follow Up By: Member - david t (INT) - Thursday, Sep 09, 2010 at 11:01
Duncs
no I have not had in steep sand but it has done sandy rds like
Ernest Giles rd,old main rd from
Kingoonya as
well pulling trailer no worries with standard
suspension and tyres now we have BF ATs and an xtra 50mm and heavier rear springs and struts I would like to hear from some one who has done googs recently.
I know the right tyre pressure and travel speed helps through the sandy rds
if I was travelling with another vehicle i would not hesitate to do it but we are solo.
thommo
700523
Reply By: Mick O - Thursday, Sep 09, 2010 at 13:10
Have driven Googs south to north in a D20 Navara and a Cooper
Tambo camper trailer.
Blogs may offer some insiight.
Googs Track #1Googs Track #2
Cheers Mick
429747
Follow Up By: Member - david t (INT) - Thursday, Sep 09, 2010 at 15:34
Mick O
blogs on Googs do give a good indication of track conditions looks like some hard yards i may have to reconsider to alternative plans
700546
Follow Up By: Mick O - Friday, Sep 10, 2010 at 11:03
David, there are some big dunes in the northern stretches but with the tyre pressures down as necessary, I'd think you should be OK. A great experience to drive and some beaut country. If you're worried, get a dozen or so Hessian sand bags and carry them with you. They are a much cheaper alternative to max-tracks and the likes and do a great job when 2/3 filled with sand and laid in your tracks. Just drive up on them slowly to prevent damage.
Cheers Mick
700642
Reply By: Ozhumvee - Thursday, Sep 09, 2010 at 13:26
Having travelled Goog's in a mixed group of vehicles , Prado's, Cruiser traytops, forerunners etc if the sand is soft the Xtrail will struggle on the bigger dunes without a trailer let alone towing anything. The lack of low range gearing to get going again when stuck on a soft dune crest may be your undoing. The 120 Prado's especially bottomed out and had to have another go in a few
places, having to be towed too and they weren't towing.
Low tyre pressures equals much less ground clearance.
But if Goog's has had plenty of rain then the sand will be firm and less of a problem but claypans and muddy sections might cause you grief.
If alone I'd give it a miss without someone else to give you a tug.
429750
Reply By: Member- Tony C - Thursday, Sep 09, 2010 at 13:37
Hello David,
I am heading off now to
Ceduna and will be travelling north on
Googs Track. I will be starting
Googs Track on Sunday and can give you an update on conditions probably by about next Wednesday.
When are you planning travelling?
Tony
429753
Follow Up By: Member - david t (INT) - Thursday, Sep 09, 2010 at 13:42
plan on travelling end of month all going
well any info on the track and its condition would be great
700532
Reply By: RobAck - Thursday, Sep 09, 2010 at 18:02
We completed Googs two weeks ago. If you don't have sand driving experience I do not recommend it and particularly if travelling alone and towing. If you get stuck then no low range and reversing down the dunes will be more than a challenge.
We had two Prado towing Ultimates and a Pajero. All vehicles used high range for the whole trip with no wheel spin or track damage. We run MTR with Kevlar all round and used 14 in the car and 12 in the camper trailer with no problems at all. The two other vehicles ran 16 psi and 14 in the other Ulti.
Mostly we cruised along in first gear taking it nice and easy over all the track damage that everyone else has left these days
Sand flags are mandatory as is using Ch 18 and your permit can be paid for and collected from the
Ceduna tourist advisory centre in the main street.
The track was reasonably firm after recent rains but drier and softer past Mt Finke.
We almost had a head on with one clown coming North to South with no flag or radio and were appalled at the track damage around Googs Lake and the environmental vandalism happening around Mt Finke. But there are also plenty of
wildflowers around and big patches of Sturt Desert Pea a few km out of
Tarcoola
If you are not experienced I do not recommend this if you are on your own and not prepared to lower your tyre pressures all round
RobA
429769
Follow Up By: Barry01 - Saturday, Sep 11, 2010 at 19:07
important do not forget the sandflag i too nearly had a head on last year with a guy who did not have one; sorry can not advise about towing a trailer ; enjoy the trip
700825
Reply By: whitedog - Tuesday, Sep 21, 2010 at 19:27
Hi David a heap of us are doing Googs Sat 2/10 if you want to tag along.
Travelling from
Adelaide Fri, heading from
Ceduna on Sat.
Mike
430980
Follow Up By: firesafe - Tuesday, Sep 28, 2010 at 22:00
Mike,
Only 1 day to go :-)
Scott
702530
