UHF Radio
I wish to purchase a UHF Radio as a gift for the man in my life. Would you recommend a GME TX 4400 as an all round good one to buy? i have no knowledge of what he wants except that we will use it when travelling in convoy or alone on out back highways.
Hope some one can help?
Reply By: donk - Monday, Oct 11, 2010 at 17:18
I believe that TX4400's have a good reputation
What vehicle is it going to go into though as a TX4400 is a single din size & on a vehicle that does not have a spare din pocket in the dash you might be better off with a smaller unit (lots of small uhf's available from either GME or Icom)
Prestige Communications in WA http://www.prestigecom.net.au/ who send freight free all over Australia normally are a fair bit cheaper than other retailers & have a good reputation also for their service
You will also need a antenna and there are lots of different ones available to suit different applications
I have a TX4400 and a RFI CD5000 Antenna that works well for me
Good luck
Regards Don
AnswerID: 432711
Follow Up By: donk - Monday, Oct 11, 2010 at 17:23
Be careful what antenna you choose as some cheap ones will not last on corrugated roads
Regards Don
FollowupID: 703472
Follow Up By: donk - Monday, Oct 11, 2010 at 17:29
Just in case you dont know what a single din pocket this is what it is (the same as a standard radio unit size)
The link shown mine fitted in my Patrol
Regards Don
FollowupID: 703474
Follow Up By: Hairs & Fysh - Monday, Oct 11, 2010 at 18:46
Yep, We've had ours for just over two years now without any dramas.
FollowupID: 703483
Reply By: steve21 - Monday, Oct 11, 2010 at 17:19
have a look at http://www.prestigecom.net.au/
good prices...
rgds steve
AnswerID: 432712
Follow Up By: Mick O - Monday, Oct 11, 2010 at 17:59
I second Prestige as a place for good value. I've gone away from the single DIN units to the smaller units like the TX 3100 and TX 3220. They are a lot cheaper and have the same output as the larger ones. The smaller profile means you have a lot more mounting options and can even mount them with velcro as I have done in both the ute and quad. Coupled with a solid areal, they are great little units and much cheaper than the bigger DIN units.
Cheers Mick
FollowupID: 703481
Reply By: garrycol - Monday, Oct 11, 2010 at 17:24
If they are available - see if you can get one of the new 80 channel versions that will suit the new UHF CB band that comes into effect from Jan next year.
Garry
AnswerID: 432714
Follow Up By: Diesel 'n Dust - Monday, Oct 11, 2010 at 21:54
What new UHF CB band??
Matthew Clements
I just love the Pilbara!
1HDJ79 RV
FollowupID: 703512
Reply By: Member - Stephen L (Clare SA) - Monday, Oct 11, 2010 at 19:14
If you are not in a hurry, wait until early next year when the new model 80 channel unit are in the market. The final details have not been but in place just yet and GME are not sure which of their current models will be able to be reprogrammed for the new frequencies.
AnswerID: 432732
Follow Up By: Member - Boobook - Monday, Oct 11, 2010 at 19:50
What he said..
The standard isn't even finalised yet and time for comment with ACMA closes tomorrow.
The only one for sure that will work is a ICOM 400 Pro which can do 12.5Mhz spacing.
FollowupID: 703492
Follow Up By: Flynnie - Monday, Oct 11, 2010 at 20:44
I'd go for the ICOM 400 Pro. An excellent unit. Bit biased as I have one. Steep learning curve though and keep the instruction manual handy.
Flynnie
FollowupID: 703500
Follow Up By: Member - Stephen L (Clare SA) - Monday, Oct 11, 2010 at 20:58
Hi Boobook
There are GME radios that will work as well, but it will come down to what the final reports say on what radios can be reprogrammed.
FollowupID: 703503
Follow Up By: Bonz (Vic) - Monday, Oct 11, 2010 at 21:44
My Icom 400 Pro says "BonzInc" on the display when it starts up! I reckon its an excellent UHF unit
FollowupID: 703511
Follow Up By: Member - Boobook - Tuesday, Oct 12, 2010 at 06:29
Steve, I currently have a GME and talked to their product manager about 5 days ago on this subject. You are right, it depends on the standard finalisations. There are discussions about A/B channel banks verses channels 1-40 and 41 - 80. The GME guy said it may be that the 3340 can me modified, or the 34xx can be modified or none can be modified. He even said they may repackage the TX 3600 for a while until then get a new design if necessary. They simply don't know yet. So I wouldn't buy any GME on the basis that it will have 80 channels just yet. Acutally I wouldn't buy any UHF right now unless I needed it. Even if you are happy with just 40 channels, they will be a lot cheaper on January 2nd given they will be illegal in 5 years.
One thing is for sure, the ICOM 400 can work in all these modes with 12.5khz spacing.
What no one knows is what will happen to repeaters which may not work with newer radios, even if they do they, will sound awful. It is a bit of a mess actually.
FollowupID: 703529
Follow Up By: Member - Stephen L (Clare SA) - Tuesday, Oct 12, 2010 at 08:03
Hi Boobook
One point that I was told by our GME rep just last week is that in 5 years times, the old UHF radios will still be legal to use, there are just too many out there and will still be using the same frequencies, just not the newer ones. Like he said, you will still be using the current 40 legal channels, but will not be able to communicate with people and vehicles using the new 80 channels. All stations and properties use UHF radio for many and varied uses, from monitoring tank levels to keeping in contact when out on their properties. They have used these radios for decades and keep doing so when the new frequencies are in place, as the new channels will mean nothing to them. The biggest change will be the repeater stations.
There is still a lot of work to take place and until it takes place, there will be lots of grey areas.
FollowupID: 703532
Follow Up By: Member - Boobook - Tuesday, Oct 12, 2010 at 08:26
Steve what the GME rep told you is not correct. While the technical specs are not finalised, the legal ones are.
The old ones will be able to communicate with the new ones in the first 40 channels regardless of what happens, but with reduced quality. But specifically the old ones will be illegal from 2016.
Here is the statement from the horses mouth, the ACMA website.
From 1 January 2016, everyone will be required to use 12.5 kHz equipment only.
Of course a sales rep that only has old ones to sell would like to think tell people they can be used forever.
FollowupID: 703534
Follow Up By: dbish - Tuesday, Oct 12, 2010 at 10:21
Hi Boobook. If they think old UHF CBs arent going to be used after 2016 they are dreaming. Same thing hapened back in the days when i was selling 23Ch 27Mhz CBs they were suposed to be ilegal to use when 18Ch was brought in. This didnt stop there for long before 40Ch were made legal, as once the flood gates are opened they are hard to shut & policing them would be a nightmare. Daryl
FollowupID: 703551
Follow Up By: garrycol - Tuesday, Oct 12, 2010 at 11:32
I prefer the Icom IC440 as it is a bit more flexible.
FollowupID: 703554
Reply By: Wilko - Monday, Oct 11, 2010 at 20:01
Hi Bowler,
Ive had a GME TX4000 for 16 years now and it hasnt missed a beat (most well known brands are also good though).
I use a GME A4018K1. It has gone over the roughest of roads/corrugations and has also performed well.
I look for a unit that allows group scan (you input the channels you wish to scan) and full scan in which it scans all the 40 channels. Mine also has priority channel.
Lets say you are using channel 18 and would like to scan channel 40 (truckies channel and say channel 12. Id use group scan and program the unit to scan those channels only.
Hope this helps
Cheers Wilko
AnswerID: 432737
Reply By: Member - Doug T (NT) - Tuesday, Oct 12, 2010 at 00:56
bowler1
YES...YES
AnswerID: 432766
Reply By: bowler1 - Tuesday, Oct 12, 2010 at 14:17
Thank you Don I will take your comments on board. We will be putting it into a 2010 Pajero. Not sure what din means but I will make enquiries
AnswerID: 432794
