Friday, Oct 15, 2010 at 10:03
Marc,
you can purchase them from here.
Muirhead (1739) low coolant level detector.
Remote Control Technologies P/L part # 9065, description. Kit Coolant Level.
Contact. Mt Isa (07)47490233.
Perth (08)93536577. Kalgoorlie ( 08)90211600 .
Brisbane (07)38801231.
Derek Bester at ABR Sidewinder is a business member on here, he also will have low level alarms and he gives great advise if you need it.
Low level alarm must also be AC to stop the likelihood of electrolyses.
I think you should be using coolant, Toyota have one that is very good and lasts for 4 years so use that coolant ONLY in the engine and don't mix different types. If you lose coolant you can still put
water in but when you get home you can flush it and put in new coolant.
Modern engines need coolant, besides destroying your ali radiator it is eating away at the insides of the engine/
fuel cooler/ Egr valve/ heater and heater valve. You will save yourself big dollars by doing this. The new common rail diesels demand clean
fuel so don't skimp on the filters. 1 injector is around $800.
If you install aftermarket shocks you will find they last, there are heaps out there at a price OME/ Toughdog/ Raw/ Tjm's/ EFS/ Koni's and the list goes on and on.
If you get some large radiator hose you can place this over the bottom of the rear shocks before you istall them to stop stone damage.
Have a good one
RA
703888
