CAV filter adaptors GU price?
Submitted: Thursday, Oct 30, 2003 at 12:21
ThreadID: 8198 Views:2625 Replies:8 FollowUps:0
Hi All
Anyone know the cost for a cav filter adaptor for a gu patrol 4.2l diesel?
my local guys (newcastle) quoted me 140 which seems a litte expensive
Reply By: Peter L - Thursday, Oct 30, 2003 at 14:13
Try www.hiflo.com.au/mainframest.html
AnswerID: 35706
Reply By: Member - Chris (Wollongong) - Thursday, Oct 30, 2003 at 14:45
I paid $125 supplied and fitted .
AnswerID: 35712
Reply By: Member - Roger - Thursday, Oct 30, 2003 at 17:18
They cost about $100 and can be easily installed by a home handyperson.
Work great and allow one to see the how the fuel system is going via the glass bowl.
RegardsDodg
AnswerID: 35725
Reply By: joshinthecity - Thursday, Oct 30, 2003 at 20:51
I too am after the same thing for a 3.0 series IV Patrol.
Any suggestions on who I should see for the supply/fit ?
Ta.Josh.
AnswerID: 35746
Reply By: Martyn (WA) - Thursday, Oct 30, 2003 at 21:06
Simon,
I paid $100 the same as Roger and fitted it myself, it's easy and you also know it was done you as you wanted it done. Your choice, 4140 is getting up there.Keep the shiny side up
AnswerID: 35749
Reply By: Mick - Friday, Oct 31, 2003 at 08:24
$110 from Don Kyatts in Sydney.
Easy to fit, just a spin on adaptor(like the original filter) so the CAV filters can be used.
AnswerID: 35775
Reply By: Tony - Friday, Oct 31, 2003 at 12:05
Whats the CAV Part No for a GU deisel?
AnswerID: 35793
Reply By: Peter L - Friday, Oct 31, 2003 at 13:27
Because the standard CAV/Lucas filter is nominal 5 Micron (as opposed to 15? micron for the OEM), I was advised by injection engineer to instal 2 stand alone units in parallel on my diesel landcruiser.
Apparently Toyota lift mechanism is susceptible to too much vacuum.
Can't comment on the Patrol though.
PS It is possible to buy a longer CAV filter (than the standard 711 296)
It has more media & therefore flows better (at lower vacuum) - Don't know the number but obviously requires a longer centrebolt.
PPS Most long distance truck part outlets can supply similar (Donaldson/ Fleetguard) filters at very reasonable prices (I bought ten non-genuine 711 296 for $4.50ea. GST Incl.
Peter L
AnswerID: 35800
