TOYOTA PRADO RV 2000 model : 2.7 litre
Submitted: Wednesday, Oct 20, 2010 at 09:49
dean.76
wondering if someone anyone can tell me what the 2.7lt prado goes like.i have read many forums and it like a 50/50 call on good and bad. im really close to buying one as a second car i love the car it's so clean it's like new, on the road it goes
well for a four cyclinder but what i really want to know is how does or would it go on
the beach. i live on the fraser coast so thats where i want to use it. will it be able to cope with sand? and yes i know that i should buy the V6 or the turbo diesel but i want to spend only $15'000 and they are still more than that. please let me know before i make a big mistake. thank you
Reply By: Robin Miller - Wednesday, Oct 20, 2010 at 10:09
Hi Dean
They really are to tall and narrow for my liking - but regarding there ability to go on sand they wil go better than you think at first as they are already relativiely light.
So much of sand driving really is getting your tyres down to 15 and keeping the momentum up , and you do not say, so I will presume its a manual. (auto is better)
Only last week I spent time on
Stockton dunes chasing a 3.4lt manual version prado which overall probably did better than I did due to a better driver which is the main factor in this equation.
433640
Reply By: Member - Tour Boy ( Bundy QLD) - Wednesday, Oct 20, 2010 at 10:52
The V6 was a thirsty beast on sand but the 4 cyl seems to pull as
well as the V6. Keep in mind the V6 (3.4l) requires the timing belt to be changed every 150,000km. AFAIK the 4cyl has a chain.
433642
Follow Up By: dean.76 - Wednesday, Oct 20, 2010 at 13:52
ok then, doesnt sound so bad. it has wider tires and rims on it which for some reason i had in my head that u couldnt do that to the RV, and yeah i didnt mention if it was auto or manual so to answer that it's a 5 speed manual.
704594
Follow Up By: Mark Howlett - Wednesday, Oct 20, 2010 at 14:10
You can certailny put the wider tyres and rims on the RV's, just need to fit some flares to cover them. The GXL's have the plastic flares and side body cladding. The 2.7's also only have the single 90L
tank, no secondary 59L
tank. From all reports they nearly go as
well as the 3.4 and better economy as you would expect. I would think there are some 3.4's for less than $15,000 these days.
Mark.
704599
Follow Up By: Member - Tour Boy ( Bundy QLD) - Wednesday, Oct 20, 2010 at 14:36
There is a
vx prado in seq for $6500 but it is a 96
704605
Reply By: Hespy (NT) - Wednesday, Oct 20, 2010 at 16:07
I have had my 1998 Prado 2.7 3rz since new and I would never contemplate getting rid of it. Has never had any issues and tows a
5 metre boat fully loaded around the rough NT roads no dramas at all.
Fuel consumption doesn’t alter very much but they only have the one
tank unlike the V6 which has the twin tanks. I have been told however it is quite easy to fit the second
tank from a wrecked V6 and using the original pump and pick up assembly just set it up to transfer the secondary
fuel to the main
tank. The
tank brackets for the second
tank are already on the vehicle. The eight seats are great for the kids and as stated no timing belt and servicing is inexpensive and done with ease with one exception the
fuel filter which for some reason is situated under the engine air intake and you need a crows foot spanner to undo the metal unions on the filter. Plenty of aftermarket options are still available and extra wheel rims are not hard to find if you are contemplating doing a long trip.
Second hand parts if you require them shouldn’t be a problem as the engine and gearbox is the same as what is used in the same model hilux which from what I believe has had a good reputation. Just make sure if you purchase it that has had the recalls for the rear axles and ball joints done. You can visit www. recalls.gov.au for further information. This vehicle should bring you plenty more years of enjoyment.
433669
Reply By: Kimba10 - Wednesday, Oct 20, 2010 at 17:21
2.7's in my opinion go as
well as the 3.4 and not as thirsty I have had one outpull me going up mooney mooney here in
Sydney. I had the 3.4 and was a great car till I put it on LPG (another story) the rv's dont have as many bells and whistles as the GXL and upwards but probably less to go wrong. Even 80 series cruiser rims fit the prados which give you a wider stance but as they are 8inch wide the rv's only 6 I'm pretty sure it would make it ilegal but the 7 inch from the GXl and upwards wouldnt be a problem as long as mentioned above you have flares to cover them up (available from ebay). For $15k you would definately get a V6 easily, gxl even, grande maybe maybe not, I sold my 97 grande with bullbar etc for $16500 with 176k on it, I have diesel 90 grande now with 103 on it and might I add a blown head (common with 1kz). I reckon the petrol went heaps better on the sand as you could rev it more,where as the diesel dosent rev so you lose momentum on those big dunes. 2.7's if the same as the hilux's DONOT like LPG, guaranteed to do the head . I would have no hesitation on owning a 3.4 again or 2.7. I know Robin doesnt like them due to their stability but at the end of the day comes down to drivers experiance and /or stupidity. Of course the cruiser or patrol would be more stable at a 40d slope but hey I have seen in my time plenty of cruisers and patrols on there side too, plenty of troopys used by travellers as
well especially Frazer, even they manage to keep upright,
well most any way half dont even know to drop pressures down. Go the Prado you will be happy just dont do any reverse snatches the front diff doesnt like it....Regards Steve M
433679
