Sunday, Oct 31, 2010 at 00:54
If starter battery greater than 50Ah (~RC90), then the easiest way for this nightly load requirement is to wire a 50Ah spiral wound pure lead/tin AGM battery directly in parallel to it, using B&S2 wire. Isolation switch is optional.
If starter battery smaller than 50Ah, then the same as above, but isolation switch is recommended.
If isolation switch is used, the wire gauge may be reduced to something like B&S6 or 8.
If no isolation switch, use a plug in type voltmeter in your ciga lighter socket for occasional battery charge monitoring.
In this case your combined battery capacities are available for powering the fridge overnight, and for starting the car next morning.
The batteries will store a useable 90Ah, while the fridge only draws 30~35Ah overnight (16 hours), and starting only requires less than 0.5Ah.
During the whole day, the fridge consumes around 50~55Ah, meaning you'll have to run the motor for 2hrs in the morning, and 1 hour in the evening (or 3 hours spread over the whole day).
If both starter and second battery were spiral wound pure lead/tin AGM batteries, you could cut the motor run times in half, i.e. 1.5 hours spread over the whole day.
There are no advantages of using a gel battery for this, only disadvantages.
A three stage battery charger for occasional topups of both batteries is recommended in both cases to extend battery life.
cheers, Peter
434653
Follow Up By: stockade1 - Sunday, Oct 31, 2010 at 07:35
Thanks everyone for the detailed advice
705745
Follow Up By: Member - Andrew (QLD) - Sunday, Oct 31, 2010 at 08:23
Peter,
I believe those figures for the 40L engel fridge are in excess of normal expectations. 24-36Ahrs would be more realistic over a 24hr period. ;)
Andrew
705746
Follow Up By: Battery Value Pty Ltd - Sunday, Oct 31, 2010 at 08:43
thanks Andrew,
I tend to overstate consumption figures for a few reasons which I don't want to mention every time in a load budget:
By overstating the consumption, you have some leeway for unplanned additional loads, for a less than 100% charged battery, for batteries which aren't new (batteries reach their peak capacity early in their life and from then on, gradually weaken), hot nigths with lots of fridge access, and last but not least you gain more battery service life if it's not discharged as deeply.
cheers, Peter
705751
Follow Up By: Member - Andrew (QLD) - Sunday, Oct 31, 2010 at 08:50
No worries Peter, just thought they were high when the fridge draws less than 2.5A ;)
Andrew
705752
