CTEK Multi XS 7000
Submitted: Sunday, Nov 07, 2010 at 15:40
ThreadID: 82349 Views:12442 Replies:5 FollowUps:5
Please help! We have a CTEK Multi XS 7000 and we are really having trouble getting enough information from the manual. Could someone please explain (simply) the uses for each of the modes:- Standby, Normal, Snowflake, Supply and Recond. For example, which mode should be used for trickle feed when the battery is not in use? And when it is in use. We are quite new to this and want to get the best life from our batteries.
Thanks!
Reply By: Notso - Sunday, Nov 07, 2010 at 15:59
Use normal for almost everything it will manage a battery long term while it isn't being used.
Supply is only when you want to use the charger without a connected battery.
Recondition if you think the battery is in need of a good stir up after being deeply discharged.
Snowflake if the battery is cold, eg below 5 degrees C, not just the air temp but the battery. Won';t happen often in Aus.
AnswerID: 435268
Follow Up By: Notso - Sunday, Nov 07, 2010 at 16:01
Missed out on a couple of words above.
Supply is only when you want to use the charger as a power supply without a connected battery.
FollowupID: 706438
Follow Up By: Alloy c/t - Sunday, Nov 07, 2010 at 18:16
Codswollop , Snowflake is simply a higher voltage suitable for AGM batteries , Supply gives a constant voltage of 13.2v but should still be used with a battery inline , read your manual !
FollowupID: 706448
Follow Up By: Ozhumvee - Sunday, Nov 07, 2010 at 18:48
supply does not need a battery to be present!! been using my XS7000 for years as a stand alone power supply as the manual stipulates.
FollowupID: 706456
Follow Up By: Notso - Sunday, Nov 07, 2010 at 20:31
Not quite so much Codswallop, methinks? If you are going to use big words perhaps you could spell em right too!
FollowupID: 706467
Reply By: Member - Phil G (SA) - Sunday, Nov 07, 2010 at 17:30
There's a nine page manual that comes on the net, which may explain it better than what you've got:
UK Manual
AnswerID: 435275
Reply By: Sand Man (SA) - Sunday, Nov 07, 2010 at 17:57
I have an XS 7000 and the manual is quite plain to understand.
Mode Normal (14.4V) is best for standard wet cell and most Gell batteries.
Mode Snowflake (14.7V) is recommended for most AGM batteries and when charging in temperatures below 5 degrees centigrade.
Mode Supply (13.6V) the charger provides a constant voltage and can be used as a power supply when no battery is present.
Mode Recond (15.8V) is for very discharged batteries as an attempt to recover them for over discharge but should be used with caution.
There is no Mode setting for "Standby"
In a nutshell, if you have a "normal" wet cell battery whether sealed or with caps on, starting or deep cycle, use NORMAL mode.
If you have an AGM battery use Snowflake mode.
Any mode will start with a primary (bulk) charge (at the specified maximum voltage) until the storage voltage reaches around 80% capacity, then the charger will change to maintenance (trickle) charge mode at a reduced voltage level. The battery can generally be left in this mode indefinitely, remembering that unsealed batteries need to have the electrolyte level checked and topped up with distilled water if necessary.
Bill.
Bill
AnswerID: 435278
Reply By: Spud01 - Sunday, Nov 07, 2010 at 19:11
Thank you so much for your replies. I still have more questions. If standby is not a mode, what is it? And, after using the battery (it is in a camper trailer), do we leave the ctek connected to power on the normal mode indefinately? Thanks!
AnswerID: 435284
Follow Up By: Sand Man (SA) - Sunday, Nov 07, 2010 at 20:16
The idea of "float charge" is that once the battery has reached around 80% charge, the charger will change to a float charge. This reduced voltage will top up the battery to a full capacity and the battery can be left connected without damage for months on end.
But, in the case of an AGM type battery, once a full charge has been reached, there is no real reason to leave the charger connected. You are basically only using power for no real gain. An AGM battery does not "self discharge" significantly over a longish period of time. If the camper is not being used regularly, you may connect the charger to "maintain" the battery every month or so for a day or so.
I don't bother with this too much. I ensure the batteries I use are all at full charge and then leave them be, only checking them "once in a blue moon" and before the next trip.
I still don't know where you get "standby mode" from. It is not a mode available on the Cteck 7000. Maybe this is another term for maintenance or float mode?
Check what type of battery is in your camper. If it is an AGM type, Snowflake mode is the better mode to use for the bulk charging process and the charger can be left connected "indefinitely" if you wish. In Maintenance mode (the automatic final charging process), the charger will alternate between float and pulse, depending on the exact voltage level of the battery.
Bill.
Bill
FollowupID: 706466
Reply By: Spud01 - Sunday, Nov 07, 2010 at 20:46
Thanks Bill. Standby is not a mode but a light that comes on when going through the modes. On further research, we have found that standby suspends the charge. We have a Ritar 12-120 battery so we will make sure it is fully charged after our trip and then check occasionally to maintain the level. Please feel free to add further advice to the novice! In the meantime thanks so much for your help!
AnswerID: 435293
