how long before a dual battery system becomes unreliable?
Submitted: Tuesday, Nov 09, 2010 at 00:55
Member - Brenton C (WA)
I have had a Rotronics dual battery system in my 4wd for 13 years and it has never missed a beat, or so I have assumed. It has been subjected to heat, water/rain, dust all the usual things from off-road that you get under a 4wd bonnet including salt sea air etc. Does anyone know if these things keep going (the Rotronics unit I mean) forever or should I be changing it before our next trip?
Reply By: Sand Man (SA) - Tuesday, Nov 09, 2010 at 07:06
Brenton,
All things will malfunction eventually, but unless you are experiencing battery problems, then you can assume the Rotronics Isolator/Controller is still doing its job.
Hell, that is a long time though. It must have a good set of contacts in it.
If you have any doubts at all, then by all means replace it with a new controller, if for nothing else but to give you piece of mind.
Bill.
435424
Follow Up By: Member - Phil G (SA) - Tuesday, Nov 09, 2010 at 11:52
Gday Bill,
Best of luck if you can find a set of contacts :-)
The Rotronics are all electronic - transistors are used for the switching.
706613
Follow Up By: Sand Man (SA) - Tuesday, Nov 09, 2010 at 19:48
AHhh!
That's why the little bugger is lasting so long:-)
Bill.
706657
Follow Up By: Member - Phil G (SA) - Tuesday, Nov 09, 2010 at 21:56
And...thats why the little buggers cost twice as much :-))
706679
Reply By: jdwynn (Adelaide) - Tuesday, Nov 09, 2010 at 07:39
Reckon with this good report, Rotronics should just give you another one, or promise to support you (wherever you are) until it fails - if it lasts 15 or 20 years or longer that'll be great advertising for them . Cheers
435428
Reply By: Patrol22 - Tuesday, Nov 09, 2010 at 08:16
From personal experience they can fail at the most inopportune time. I had an ARB one fail on me on the way to
Cape York a few years back - only 2years old as
well. Thankfully I was in
Longreach and close to an autosparky so was able to get the bits to jury rig a set up. I've now taken to carrying a old time electro-mechanical isolator with me for those 'just in case' scenarious. But seriously a quality solid state isolator should last for donkeys years.
435432
Reply By: Member - John and Val - Tuesday, Nov 09, 2010 at 08:24
brenton,
If it's not broke, why fix it? It has a good history with no reason to think it won't continue working. No replacement comes with that. If you feel uneasy, maybe carry a replacement, but I wouldn't fit it until you need to (maybe some time in a decade or 2).
| J and V
- Albert Einstein
435434
Follow Up By: Member - Josh (TAS) - Tuesday, Nov 09, 2010 at 22:24
I agree with John. Chuck a spare in that way it will keep going until you forget the spare one day. Kinda like carrying a spare axe handle, it will only brake when you leave the spare at home. Good rap for them though
Josh
706685
Reply By: Rod - Tuesday, Nov 09, 2010 at 11:42
My Rotronics unit is coming up to 10 years in age and has been in two vehicles since I first bought it. About six months ago I thought it was starting to fail as the starting battery was not charging fully. I then discovered that one of the connections had started to work loose from corrugations. No problems since i tightened it up. Good reliable product.
435447
Reply By: Member - Phil G (SA) - Tuesday, Nov 09, 2010 at 11:50
I'm on my 2nd Rotronics unit.
The first unit was used in two vehicles from 1987 to 2000, and was sold in perfect working order with the vehicle.
My second unit (MH10) has been in 3 vehicles and has worked perfectly for the past 10 years.
The reason they last is that they do not have a solenoid. The switching is with FETs (transistorised).
435448
Reply By: Member - Brenton C (WA) - Tuesday, Nov 09, 2010 at 23:24
Thanks one and all. I think carrying a spare unit is the way to go. Off to the Rotronics
shop I go..
435516
Reply By: Member - Brenton - Thursday, Nov 11, 2010 at 13:01
As a finale to this conversation for future readers, Rotronics advised me the service life for their units is 10 years. They say that this is most likely a minimum though. They also said some people mistakenly change out units thinking it is faulty, but in fact it maybe battery or cabling. They have correct testing procedures available on request.
The guys there are super helpful and offer trmendous support and advice.
http://www.rotronics.com.au/
Technical & Information: email at rotronics@bigpond.com
Telephone : -- +61 7 5497 8066
435652
