'04 Patrol 3.0l head cracked! Reparier recommendations pls?
Submitted: Monday, Nov 15, 2010 at 14:28
ThreadID: 82510 Views:3709 Replies:6 FollowUps:3
Yup, 100k and a cracked head. I'm waiting for the I told you so's :)
Anyway I'm looking for recommendations either in Albury/Wodonga or eastern suburbs of Melbourne for a new head replacement, drive in drive out.
Thanks in advance.........Leroy
Reply By: guzzi - Monday, Nov 15, 2010 at 19:09
OK consider yourself told.
Never good news.
What were the conditions and the symptoms when it cracked?
Sorry I cant give an address Im 1800 km too far north
AnswerID: 436082
Reply By: Madfisher - Monday, Nov 15, 2010 at 20:34
Bad luck Leroy, unfortunaty an all to often occurrence with a lot of 4cylinder turbo diesels. Sorry I can not help you.
Good luck Pete
AnswerID: 436094
Reply By: Nutta - Monday, Nov 15, 2010 at 22:44
Hi Leroy.
why dont you try patrol4x4.com, there maybe someone not far from that area who can help, cheers Wayne
AnswerID: 436112
Reply By: Member - Malcolm (Townsville) - Tuesday, Nov 16, 2010 at 08:29
Leroy, if you are talking about the cracks between the glow plug hole and the valve seat then it is a no brainer.
There is only ~8mm and it is a known fault for a crack to develop at this point. I had it on mine and the engine recondition place said ÿou have a cracked head". After pointing out the above I asked for a leak test. Head came up OK. Guy said ÿeah, we have to tell people the head is cracked!".
I would only be doing a leak test and getting the surface machined if test is OK.
Make sure they replace the head bolts - they are a one use item because of the tensioning method used.
Malcolm
living the 'good life'
AnswerID: 436123
Reply By: Leroy - Tuesday, Nov 16, 2010 at 13:31
I've had a recommendation for CW Engineering aka Top Torque Engines & Cylinder Heads in Nunawadding whom sounded fine on the phone when chatting to them. Has anyone used these guys?
TIA....Leroy
AnswerID: 436140
Follow Up By: Frances - Tuesday, Nov 16, 2010 at 19:29
Don't go to the Shepparton Nissan dealer. Their mechanics are hopeless. The same thing happened to my father's 04 Patrol at 100k and they never repaired it properly and he was without his car for three months. After the 4th problem after they "fixed" it he traded it in on a Prado Kakadu and is very happy.
FollowupID: 707357
Follow Up By: Leroy - Monday, Nov 22, 2010 at 12:19
Is there any such thing as a good Nissan dealer these days? :D
Leroy
FollowupID: 707968
Reply By: Leroy - Wednesday, Nov 17, 2010 at 10:48
With all the carry on about 3.0l Patrols I was expecting to be inundated with repairer recommendations!! Maybe they are not failing as much as people think.
......Leroy
AnswerID: 436215
Follow Up By: ben_gv3 - Monday, Nov 22, 2010 at 13:18
Either that or people aren't bothering to repair them to the previous specs, ie fitting completly different engines or just selling it off.
FollowupID: 707973
