Shower problem
Submitted: Monday, Nov 29, 2010 at 12:03
Bunny
We have a Coromal Princeton with shower and
toilet.
Has anyone had the need to remove the vertical rod in the shower recess - we have a broken slider and need to replace, however, we are not sure if the vertical rod is able to be removed.
We think the cylinder parts at the top and bottom should come off, but they won't budge (perhaps with a lot of force which we are reluctant to do).
Anyone ever had this situation before
......Thanks for any help
Reply By: Rockape - Monday, Nov 29, 2010 at 13:00
Bunny,
I had a problem with how to remove some of my upholstry to have it repaired.
I rang Coromal in WA. and they were only to happy to help me.
Have a good one.
437256
Reply By: Member - Niss42 - Monday, Nov 29, 2010 at 13:25
Bunny.
Try gently tapping the top bracket upwards.
Some of these are mounted onto a wedge type base that is attached to the wall.
Hope this helps.
niss42
437266
Reply By: Member - Graham H (QLD) - Wednesday, Dec 01, 2010 at 09:26
Ring a Coromal service agent before you try anything as it may be screwed in from the back and if you break it you will be screwed.
437455
Follow Up By: Member - Graham H (QLD) - Friday, Dec 03, 2010 at 14:10
Had a look in my van this morning and you do this
in the groove in the piece on the wall there are little
grey plastic pieces top and bottom of the groove.
They slide up or down and behind them there is a screw.
Undo both and it will all come off in one piece.
Looking at it I would say the ends will then slide off the pole and you will be OK
709282
