Hema 5
Submitted: Monday, Dec 27, 2010 at 15:20
ThreadID: 83272 Views:3446 Replies:5 FollowUps:8
I am about to purchase the Hema 5 GPS but I have heard that Route 66 has its limitations and not as good as other systems. Is this true or just rumour?
Reply By: Member - Stephen L (Clare SA) - Monday, Dec 27, 2010 at 16:21
Hi Reuel
I have a HN5 and they are a great unit. I only use mine using OziExplorer and it is just like using a laptop, but in a small on the windscreen unit. As for Route 66, what you have hear is correct and for city destinations, I revert back to the far superior Garmin Nuvi.
People that buy these units mostly buy them for the Ozi ability and not Route 66
Other will comment and may be different to what I have said.
AnswerID: 439921
Reply By: The Explorer - Monday, Dec 27, 2010 at 17:32
I have used Route 66 a limited number of times on the Hema 5. It seems to work Ok - got me where I wanted to go. I am lead to believe they have recently changed how the software works so maybe some of the previous bad comments about the program (on the older HN 4.3) are no longer relevant? I have also used a Mio, Garmin (CityNav on Oregon) and TwoNav - none of them are perfect. Havent used any enough to say what is better or worse. Have however learnt that it pays to plan and review your trip at home first if possible including making reference to "proper" map (street directory) or even google maps.
AnswerID: 439930
Follow Up By: blue one - Tuesday, Dec 28, 2010 at 19:36
Agree with that.
Though when I am in the city I need a decent GPS to guide me through the pain of city travel.
Steve
FollowupID: 711898
Follow Up By: The Explorer - Tuesday, Dec 28, 2010 at 19:45
Understand...only tried it in Perth...which I would assume is easy when compared to other capital cities.
FollowupID: 711901
Reply By: MEMBER - Darian, SA - Monday, Dec 27, 2010 at 19:03
Member Sand Man has a blog on this device - well worth the read.
AnswerID: 439944
Follow Up By: blue one - Tuesday, Dec 28, 2010 at 19:30
Have spoken to you on VKS737 and enjoyed your SKEDs
FollowupID: 711896
Follow Up By: blue one - Wednesday, Dec 29, 2010 at 08:54
Yep a good read. Tossing up now between a HEMA or VMS??
FollowupID: 711932
Follow Up By: MEMBER - Darian, SA - Wednesday, Dec 29, 2010 at 10:58
My current thinking on the H5 hasn't changed from my rambles on Sandy's blog - we have used it a fair bit now and it has proved quite valuable re trip planning on the go - it is stating the obvious, but confirmation of direction and exact location on a map while mobile makes a huge difference to confidence levels when we are in unfamiliar territory - at the end of the day we usually input/edit our waypoints (good camps, points of interest etc.) and now know how to reliably save those points with descriptions etc. As for much cheaper units that have better street nav and can take cheaper maps etc - true, but I don't trust myself with that work through, re compatibilities etc. I just wanted great maps, turn on and go. B grade street nav I can put up with.
FollowupID: 711950
Follow Up By: blue one - Wednesday, Dec 29, 2010 at 13:47
Yep currently using Oztopo V2 on a Garmin 760 which has left us short around Walkers crossing, remote parts of the Gulf and around Alice.
Not a huge issue as I always have maps as a backup.
The Garmin also only shows how fast you are travelling when not in use as directing you to an address.
From what I have seen Oziexploer is the go with some raster maps. Following the map section on this site which I believe uses the same digital maps, there is clear direction of tracks for the areas noted above.
$1000 is alot of money for a GPS hence al the questions.
I will give yu a yell next time your on VKS.
FollowupID: 711967
Follow Up By: MEMBER - Darian, SA - Wednesday, Dec 29, 2010 at 14:37
Thought I'd seen it closer to $800 on special somewhere a few months back - mine was $890 I think - Sandy paid more earlier - keep alert for specials I guess, if going Hema.
FollowupID: 711970
Reply By: Member - Leon A (SA) - Monday, Dec 27, 2010 at 21:01
If you want to use a GPS on road then don't buy the HEMA. I took mine back a week after buying it and swapped it for a VMS Touring 500 which also has OziExplorer and Memory map and an excellent on road program as well.
AnswerID: 439964
Follow Up By: blue one - Tuesday, Dec 28, 2010 at 19:33
Thanks Leon,
Kinda get left behind with the tech advances.
Steve
FollowupID: 711897
Reply By: Sand Man (SA) - Wednesday, Dec 29, 2010 at 17:14
Reuel,
I have stated my opinion of Route 66 on my blog and haven't changed my mind.
Regardless of what you use, you need to understand the differences between "on road" and "off road" use.
Hema can only run one of them at a time and to my knowledge, most others would be similar.
I used to run a PDA with OziExplorer and Natmap premium for country travel and Co-Pilot Live for voice guided navigation in metro and major country town areas.
Both programs were excellent and because the PDA also ran GPSGate, the output from the GPS could be shared amongst multiple programs concurrently.
Two problems with this however.
The screen from the PDA was too small.
Co-Pilot Live ceased to be distributed in Australia.
Unless you can find a device that allows both types of navigation applications to be running concurrently, you will be much better off with two separate devices.
I run the Hema with OziExplorer and the excellent range of digital maps included with it for country travel wherever I go, recording track and waypoint data which can be saved for future reference.
I also run a TomTom device for voice guided navigation for city and country towns I come across.
This dual device solution gives much greater flexibility IMO.
Bill.
Bill
AnswerID: 440108
