How I --would do it/did it.
Submitted: Tuesday, Dec 28, 2010 at 10:18
ThreadID: 83290 Views:10267 Replies:5 FollowUps:13
Complete rebuild and total refit taking place in my endeavors of creating my home away from home. I recon I can handle all the fittings and fixtures my self, owing to my previous egotistical efforts of building and renovating houses and vehicles.
There are also obvious undertakings I will avoid, not just through fear of failure, but a more mature assessment of the unlikely chances of success. Brain surgery, Jet fighter piloting to name a couple.
My problem which I am sure someone out there can solve is simply this. Despite the most valiant efforts of people like Keninperth, Mandrake, Stuart P, Jon & Val and many others (Thanks guys) I just can't see me devoting the many weeks if not months I would need to studying to electricity concepts. I will never to become an expert. I just want to wire the ute and van to an optimum. Not looking for cheap and not looking for minimums.
I need someone to, metaphorically speaking, to stand behind me and say (don't be so stupid use a 6mm diameter multi strand wire there - not a No8 fence wire with electrical tape for insulation) -whilst hitting me in the ear as necessary.
The Ute is a patrol single cab with a real neat, home built canopy with shelves and still room for the double mattress.
The Van is a 22 foot Viscount.
1.Ute auxiliary Battery? (Yet to purchase)
2.Redarc 100amp Smart Battery Isolator SB112 already Purchased.
3.Fuse box under dash to feed two way radio and extra cigarette points for navigator mp3 player etc in cab.
4.Feed to cigarette point in tray canopy for engel fridge and lights.
5.Power feed to Anderson plug at rear of tray to feed back to battery bank in Caravan.
6.Tekonsha P3 brake controller already purchased yet to install.
7.Solar panel (80 watt?) on roof of tray canopy. On wish list. Will need a solar regulator close to the battery I know but size type wire size etc?
8.Two batterys in Caravan in parallel. (Yet to purchase – AGM?)
9.Central Fuse/ Master switching block Already purchased for boat a few years ago.
10.Two 12 volt water pumps. White water and grey water from shower to Macerater toilet.
11.Entire lighting system in 12 volts. No 240 volt lights.
12.Two (80 watt?)Solar panels and Regulator (Yet to purchase)
13.Projector Battery Charger 7 stage. Already owned. Clamped to both batteries????
14.240 volt wiring to power points only, a given and will be done professionally.
So how about it? Can everyone tell me how they would do it regarding wire size and colour?
What would even be of greater help is some “How I did It” drawings and explanations.
Feel free to be brutal with me but please NOT with each other.
Go on give it a go. It's probably raining and what else have you got to do?
Reply By: Mick O - Tuesday, Dec 28, 2010 at 11:13
Sounds like you’ve got the right idea. Take your time and don’t scrimp. Quality costs in my book but getting it right first time saves a lot of heartache (and cash) down the track. Regardless of management ability, you’ll have to do a bit of research and reading as it’s truly the only way. You’ll get a more than a few opinions, one of which will be mine) and you’ll have to decide what is best for you.
Under the bonnet, I’d suggest a Redarc BCDC1240. It’s a DCDC charger with an inbuilt MPPT solar controller (regulator) so you can plug your panels straight in. They are due for release in February. I have the current iteration in the ute managing the battery. I’d go a Hybrid Deep Cycle under th bonnet. One that allows for aux power and deep discharge capabilities while allowing enough cold cranking amps to start you up if and when needed. On the Redarc website you’ll find a series of wring diagrams for the ultimate dual battery set up which includes using your solenoid and including a switched jump start ability (no need for cables). Here is the link.
WIRING GUIDES
In the van – Yes AGM. They start at $300. I went for an America brand Powersonic due to quality and range of sizes available in various footprints. This allows a few more mounting options. They are around $500 for the 140 A/H. Size is really up to you dependant on need. Managing it all I’d recommend the Redarc BMS 1215. This is a one stop unit that has AC-DC charging, DCDC charging, Battery isolator, MPPT solar controller and a display unit that is exceptional in functionality and provides in one interface, every input/output reading and all the battery condition information that you require and would otherwise have use many separate displays for. The key is keeping it as simple as possible and that’s what the BMS will do. My wiring Diagrams became remarkably simple with these units.
DC Product Review
Solar, 80W will probably not be enough. Think somewhere in excess of 120W of panels again depending on need. With the two Redarc products, you won’t need any further controllers of displays for readout.
As for wiring, again you’ll need to figure what’s being drawn down the pipe and overcoming the loss through resistance. Do the sums and make your choice based on that.
It’s a start for you. You cannot escape some work on your behalf though. Good luck
Mick
P.S. It's sunny and I'm about to start sanding the house for a paint!
AnswerID: 440009
Follow Up By: KenInPerth - Wednesday, Dec 29, 2010 at 11:54
Mick
How's the sanding / painting going??
I am failing miserable with my fire sprinkler system ....... that is what DIY is all about in a field you don't have enough knowledge about isn't it.
I posted a follow up to Phil's reply if you have any comments / answers for me on that.
Ken
FollowupID: 711956
Follow Up By: Mick O - Wednesday, Dec 29, 2010 at 22:46
Nope. I'm no expert and continually learning. You blokes have it all over me so I'll just sit back and soak it all in. Wish I had more time and a spare brain to remember all of this stuff. Phil’s advice is always gold. Pity you can't get all this great info into a blog under the "electrical" tag.
Phil’s advice on the spare alt is a good one (as is the "keep it simple" principal as well as the "know what's going on with your batteries in any situation" maxim). I have a power feedback system so I can feed power from my two x 140 A/H AGM's into the vehicle system should batteries/alternators fail. A temporary measure only but one designed to get me out of trouble where needed. I also carry a lot of spares and a lot of things to fix bits and pieces along the way (even the butane powered soldering iron).
Hope SH can pick something up along the way.
"laminar flow is proportional to the 4th power of the radius" - My god what is that?
Cheers Mick
FollowupID: 712026
Follow Up By: Member - Phil G (SA) - Thursday, Dec 30, 2010 at 13:45
Gday Mick,
We never stop learning! Just keep our eyes and ears open, and get a multimeter out!
25 years ago, if we wired up a second battery, we simply used a "headlight relay" and slipped in a pair of paralleled 30A self-resetting circuit breakers so the wiring wouldn't get overloaded and the relay wouldn't burn out while cranking. Things have come a long way since.
I used to think a spare alternator was unnecessary for newer vehicles, but have noticed that others have managed to lose their alternators in the muddy and wet deserts this year.
Hehe do you really want to know?....Heres a link that explains it briefly and gives you a clue as to why I need to know about it. But simply, if you double the radius of a pipe, you increase flow 16 times (2x2x2x2) provided that flow is laminar and not turbulent - it matters a lot for flow through our airways, blood vessels, circuits etc - not just important for plumbing the house!
phil
FollowupID: 712080
Follow Up By: KenInPerth - Thursday, Dec 30, 2010 at 14:56
Well guys
Without turning this into a plumbing forum I thought the boss had the sprinklers on last night - turns out the PRV on the hot water system outside "popped it's top" - we do have high pressure where we are and looks like it succumbed.
So now in re-fitting a new one and getting a leak I could not stop at a joint further on I discover the plumber that put it in cut the copper too short so the cone tight fitting has no pipe under the cone to grab hold of - so it crushed the cone - so what did he do - wound thread seal around the cone and tightened it up just right - great until you have to play with it and it starts leaking.
I'm about to go out and give the power of 4 to it's bloody radius and see how it likes turbulent rather than laminar threats - worse than that I might have to go find my gas torch and some solder - they are wherever I left them some 25 projects ago.
Ken
FollowupID: 712087
Reply By: KenInPerth - Tuesday, Dec 28, 2010 at 12:01
Hi Sailinghampster
It sure ain't raining in Perth but it is too hot to go outside (or at least it was yesterday). I am still trying to get my fire sprinkler system in place and we are in the middle of the fire season.
Mick obviously has some very good practical experience and on the same page as I would consider myself on - and the reference to cable size for current and distance in the Blog by John and Val is the same references I was using in the other thread which was apparently "technically incorrect" - but enough of that.
I would add the following comments (for what my opinion is worth).
1. consider using 2 Isolators as per the drawing on the Redarc web site Mick pointed you at - "1 or 2 SBI's with 2 auxilliary batteries" - in your case 3 Aux. batteries. If your intention is to have all 3 Aux. batteries connected back to your alternator for charging it will ease the initial statup charge current and possibly reduce the size of your cable from front of Ute to the batteries in the caravan. I guess it will also ease the current load on your alternator and it's associated components if this is a factor.
2. you will need to roughly work out the total current you expect to draw from your Ute Aux battery (within the ute) and also seperately work out the total current you expect to draw from your batteries in the Caravan in a worst case situation - eg. like the fridge going while you are running a pump and all the lights are on. List on a reply if you like all the appliances you expect to run off the 12 Volt system in each area (the Ute and the Van seperately) with makes and models and ideally the manufacturers spec for current draw and and minimum voltage requirements if you have them.
3. As I am nearing my own project start point for the electrics I am happy to work on this with you if you trust my opinion (and with the help and ideas of anyone else out there contributing) by way of drawings and cable estimates and suggestions - reply to my post as you like in this regard. There are so many variables (duty cylces of loads, how much batteries are discharged, etc) and so many specialist areas (solar, batteries and charging, cable sizing, regulations and standards, etc) that the input of people in these specific areas will be of significant help. And practical experience is always far better than theory and you can only take the theory so far before it becomes impractical. Information can be posted as replies for others to cross check and modify.
Ken
AnswerID: 440012
Reply By: Member - John - Tuesday, Dec 28, 2010 at 15:50
POINT 4/ Wouldn't use a cigarette plug, use a more robust one, hella or narva type of plug, much better.
Merit type plugs
John and Jan
AnswerID: 440024
Follow Up By: KenInPerth - Wednesday, Dec 29, 2010 at 11:51
Good point - or as Phil suggests use an Anderson plug - but not sure you could panel mount an Anderson so I guess that depends on your aesthetic requirements
Ken
FollowupID: 711955
Reply By: Member - Phil G (SA) - Tuesday, Dec 28, 2010 at 18:38
The following is my opinions :-))) I've had many setups over many years and these days I like to keep it simple and reliable for desert travel. So my opinions are:
1.Ute auxiliary Battery? (Yet to purchase) - I would install a 100Ah AGM in the canopy and leave just the single cranking battery under the bonnet. Reason: heat shortens battery life and an AGM is the best battery to run your Engel for 2-3 days. I use a Remco ($339). You also avoid the extra cost of a second battery tray. But you will need a good earth lead going back to the cranking battery.
2.Redarc 100amp Smart Battery Isolator SB112 already Purchased - OK not my first choice, but still a popular choice. I am a fan of Rotronics isolators such as their MH10 as they don't use solenoids to switch the current (costs twice as much as a Redarc though). I'm using my second Rotronics in 23 years and 5 vehicles. Solenoid isolators can fail in short time. I would not install a DC/DC charger because it will limit the charging current to 20A. My single AGM takes 40+Amps after a nights camping so it recharges the AGM quickly anyway.
3.Fuse box under dash to feed two way radio and extra cigarette points for navigator mp3 player etc in cab - Yes thats fine.
4.Feed to cigarette point in tray canopy for engel fridge and lights - I prefer to run the fridge off a much better connection - the 50A anderson plugs are cheap these days and you won't get a better connection for your fridge.
5.Power feed to Anderson plug at rear of tray to feed back to battery bank in Caravan - Yes thats the most common way. What are you planning for the earth? I'd suggest your earth from the anderson plug go to BOTH chassis and cranking battery (for reliability).
6.Tekonsha P3 brake controller already purchased yet to install - yep, just follow the instructions - I used 12G tinned wire to the power connections and 12G to the trailer plug.
7.Solar panel (80 watt?) on roof of tray canopy. On wish list. Will need a solar regulator close to the battery I know but size type wire size etc? - I don't use solar panels - my alternator supplies a heap more power and in my experience, 30-60 minutes driving per day will recharge the canopy AGM just as much and a good set of solar panels. But it all depends on how you like to camp - I go for a drive most days. If you mount it on your vehicle, you are committed to parking in the sun.
8.Two batterys in Caravan in parallel. (Yet to purchase – AGM?) - AGM are the best choice IMO, because they are the quickest to recharge. I have an on/off switch installed on my trailer battery so I can switch the batteries off in storage.
9.Central Fuse/ Master switching block Already purchased for boat a few years ago - Yes, you can install it, but I'd expect that you'll leave it turned on all the time no matter where you use it.
10.Two 12 volt water pumps. White water and grey water from shower to Macerater toilet - yep but water pumps don't consume much power.
11.Entire lighting system in 12 volts. No 240 volt lights - Go for LED lights because of low power consumption and they are less likely to attract insects. But I still use flush mount 13W fluoros under my canopy wings because they are such a great light.
12.Two (80 watt?)Solar panels and Regulator (Yet to purchase). Yep, if you plan on staying put for more than a few days and need to recharge the caravan batteries.
13.Projector Battery Charger 7 stage. Already owned. Clamped to both batteries???? - Yep sounds good.
"So how about it? Can everyone tell me how they would do it regarding wire size and colour?" - I'll assume your Patrol alternator is about 100amp. I use the Rotronics fusible links for short-circuit protection on all auxillary batteries. Fuses can corrode with time and circuit breakers can shut off in hot weather and corrugated roads in my experience. I'd run tinned wire on all applications if you want the system to remain reliable in years to come. I'd run 6B&S wiring to the aux battery in the camper and then to the anderson plug and earth return. It covers almost all situations without the need for a calculator :-)) Colour - all pos is Red, all neg is black and the brake controller lead is best blue if you can get a blue wire in decent size (12G). Also run all red (pos) wire in split conduit for extra protection, and cable tie it to protect against vibration.
phil
AnswerID: 440040
Follow Up By: KenInPerth - Wednesday, Dec 29, 2010 at 11:49
Phil, Mick, John, and Sailinghampster
Huge amounts of good practical experience there for me to take on board also.
So can I ask a couple of more questions which may help Sailinghampster as well.
Questions
1. Sounds like you have 2 aux batteries (canopy and trailer) - given SH (and myself) is planning on 3 batteries what are your thoughts on using a second isolator between the ute and the 2 batteries in the caravan to ease the initial recharging load on the alternator and wiring in the Ute ??
2. When you say your AGM takes 40Amps initial charge is that including both batteries (canopy and trailer) or just one of them. If only one of them, this relates then back to my question above about including a second isolator to reduce the initial charge load if you up and away with both the ute and the caravan.
3. Anderson plug for fridge is a good idea - can you get a panel mount Anderson socket or have you just let the wires out through the panel and and put the socket on the end of it.
4. Chassis and Earth Return for reliability - in my earlier days working on audio equipment we used to avoid multiple earth points and always return earth's to a central point. Reason was to prevent "earth loops" which presented as "hum" (50 Hz ripple) in the audio output - but I guess this is not an issue (or negligible) in DC auto environment???
Other comments
1. The "non-solenoid" isolators sound like a good choice - as you say they cost more but look like they give much better service life.
2. LED lights definitely the way to go - they are getting better and cheaper all the time now. While not "cheap cheap" you can get some good LED "spotlights" now for when you need that extra bit of light for working on something without the high current demands.
3. Tinned wire is a must to prevent longer term corrosion and dirty connections - which can lead to longer term need to replace some cabling rather than just re-terminate it. Always leave a little bit of excess cable if you can somewhere near the end of the run for this reason.
FollowupID: 711954
Follow Up By: KenInPerth - Wednesday, Dec 29, 2010 at 14:16
An addendum and keeping it simple using the wiring guide that seems to be in general common use :
6B&S (supposedly 13.3 mm2 copper cross section)
For total wire length from terminations (Pos plus Neg cable length)
50Amp over 15Ft (4.5m)
40Amp over 20Ft (6m)
30Amp over 25Ft (7.5m)
20Amp over 40Ft (12m)
10Amp over 80Ft (24m)
8B&S (supposedly 8.3 mm2 copper cross section)
30Amp over 15Ft (4.5m)
20Amp over 25Ft (7.5m)
10Amp over 50Ft (15m)
5Amp over 90Ft (27m)
As others have said elsewhere, make sure the way it is advertised is actually the cross section of the copper and not the overall diameter of the cable including insulation. I have seen a lot of misleading representations of cable size.
Thes figures allow for the generally accepted 3% voltage loss at the load using those lengths of cables.
The most significant issue I would see with SH's (and my) requirements would be cable length from the supply point in the Ute to the batteries in the caravan in terms of initial charge current of 2 batteries if high enough for a long period.
I am assuming from what Phil put up that he uses 6B&S from ute to trailer and would also thus assume he has had no problems charging the battery in the trailer - but 2 batteries in the trailer could be a different scenario - maybe Phil has an idea on that??
References:
http://www.engineeringtoolbox.com/wire-gauges-d_419.html
http://www.engineeringtoolbox.com/amps-wire-gauge-d_730.html
FollowupID: 711969
Follow Up By: Member - Phil G (SA) - Wednesday, Dec 29, 2010 at 14:40
Q1 Re 2nd isolator - Most likely you'll will find that both isolators will have joined all batteries within a few of minutes of starting. So I think a second isolator won't help. Reason is that modern vehicles have big alternators (often 110A+). The starting battery is always be full so doesn't pull much from the alternator once the preheat relay cuts out. If I run down my ute's AGM aux battery, I find that within a few minutes of starting, it quickly gets up to 13.5V and which is enough to open the second isolator. (I'm assuming good wiring and earth - I used 4Ga).
The second consideration is whether you want your ute aux battery to remain paralleled to the caravan batteries when you don't unhitch (eg single night camp). I leave mine joined.
Q2 40+Amps is the initial current with just the Remco 100Ah AGM. Measured with a digital clampmeter after the battery had been discharged to 12.0V (I'd guess about 40% capacity) and with the engine at 2000rpm. Of course the current decreases with time as the voltage of the AGM comes up - current is likely to be 15-20 amps after an hour. I measure voltage of each battery and current going into the aux batteries as I drive along. When the current has dropped to a 1-2 amps, I know the batteries are pretty much fully charged.
If you needed to, you can control the initial charge current with the size and length of wiring (this is the KISS method). For example if you were to run 8Ga (8mmsq) instead of the usual 6Ga (13mmsq) to the Anderson plug, it is unlikely that you'll ever get more than 40Amps running to the twin aux batteries in the caravan. And of course there is the more expensive option of using a DC-DC charger in the caravan, which can limit current to say 25amps. I personally do not use the trailer battery for anything more than lights/water pump/radio etc so I never had it draw more than 10amps.
Q3 Anderson plug: www.sidewinder.com.au sell a really nice flush mount for $20:
Q4 Yeah, I guess DC environment is different. Good earth is essential because of the high current involved; the likelihood of corrosion of connections and wire, and strangely enough, to reduce the likelihood of unwanted noise in HF radios (one method of reducing the high background noise in vehicle with modern TD engines is to make sure every piece of metal on the vehicle is earthed (including exhaust, fuel tanks etc))
Comment
#1: Yes, thats why I spend $270 on an isolator! They also have very low resistance well into their working life.
#2 Yes, some amazing LED lights out there now.
#3 Yes, tinned wire is essential IMO - I've seen a lot of corroded OFC wiring after 5 years service. I get mine from Whitworths but they don't have 6Ga - Sidewinder have 6Ga tinned I think.
Phew....time for a beer :-)
FollowupID: 711971
Follow Up By: Member - Phil G (SA) - Wednesday, Dec 29, 2010 at 14:55
"I am assuming from what Phil put up that he uses 6B&S from ute to trailer and would also thus assume he has had no problems charging the battery in the trailer - but 2 batteries in the trailer could be a different scenario - maybe Phil has an idea on that??"
Yes, I only have a single trailer battery, and I don't run it down much, so I don't need thicker wiring. Others on this forum will have a lot more battery power and use a lot of electricity because of compressor fridges, CPAP machines, DVD/TVs and whatever!
I keep my heavy current drawing stuff (2x fridges) in the ute, so I'm not having to discharge and recharge a trailer battery. It also means I have the fridges with me wherever we drive.
I used 4B&S from cranking battery to AGM in canopy, then 8B&S tinned from canopy battery to anderson plug. To test the voltage drop, I hooked my tyre pump (40amp draw) up to the anderson plug and checked voltage drop with a multimeter - can't remember the figure but it wasn't much.
FollowupID: 711974
Follow Up By: KenInPerth - Wednesday, Dec 29, 2010 at 15:35
Phil (and others) - thanks for all the info.
Enjoy that beer.
Hopefully all that will help SH and myself out once we get going. As they say "some powerful good information amongst all that".
I'll get back to my fire sprinkler disaster and and have a beer a bit later. I am starting to think sprinklers and pressures and pumps and are far worse than electrics.
Ken
PS - I can see myself doing a few "dry runs" with the electrics and testing things with practical measurements rather than theory before I do the final hook up.
FollowupID: 711978
Follow Up By: Member - Phil G (SA) - Wednesday, Dec 29, 2010 at 19:15
"testing things with practical measurements rather than theory"
I can see you have a scientific mind and we appreciate your input into this forum. I like to measure voltage drop with the circuit under a heavy load, and I like to measure voltage and current continuously from within the vehicle so I know what is normal with the batteries on my vehicle with my style of camping.
Measuring current is simple - my voltmeter reads to two decimal points, and has leads going to each battery pos terminal via an on/off/on switch and the voltage difference is proportional to the current travelling thru the wire (same as a shunt ammeter using the wiring as the shunt).
BTW, I'm also very dependant on my alternator, so I carry a spare alternator!
FollowupID: 711993
Follow Up By: KenInPerth - Wednesday, Dec 29, 2010 at 21:25
Now that is another excellent point - while people carry Generators and Solar they will not always be much good if you end up somewhere remote with a dead alternator even if you do have the ability to charge the cranking battery from them.
So there is a another question - have you ever tested how far you can go in a car on a battery with no alternator and everything turned off (assuming daytime and no lights either)?? Probably less today than old days without all the electronics driving the car?? or maybe further???
I guess that might be a good reason to be able to bypass the isolator and have the house batteries connected to the cranking battery in such an emergency ??
Now - where is that beer I have been waiting for ????
PS
I have just been through a tutorial on Head Feet calculations, pipe friction losses, pump curves, flow rates, and the like - I swear it is harder than electrical theory, but I guess not if you are doing it every day then ....... - I even went and asked the local pump store a few questions and I am not sure they gave me the right answers either.
Oh well - what did I say about "trial and error" in a field you don't know.
FollowupID: 712008
Follow Up By: Member - Phil G (SA) - Wednesday, Dec 29, 2010 at 22:25
Gday Ken,
If you like remote travel, you need to have a few "what if?" answers up your sleeve.
An alternator can fail suddenly from a regulator failure or brushes wearing out (I've had both of these happen), or a fusible link fail or a battery can short between cells and drag the other down with it...or someone can leave the lights on....
Safety in numbers is my referred solution - easy to swap batteries between vehicles. But I travel a lot with others who own diesel Landcruisers so a spare alternator in the group is easy insurance. Also its very easy to pull out an alternator and check the brushes for length - it's something I would routinely do after 150k. Alternator brushes should be a maintenance item, not a repair item.
The solo desert travellers need to have other options - so solar panels or a generator can recharge the batteries enough to keep you going...slowly. Or carry a spare alternator or keep a charged battery tucked away.
How far can you go with a dead alternator? Modern vehicles may be better than some older diesels. All that electronic wizardy may not actually consume a lot of power. I had a HJ61 Landcruiser that could only go about 4 hours on an N70 battery - but it was night and I disconnected one headlight to reduce power consumption, but the 2H had an EDIC motor that controls the throttle position, and it consumes 10-15amps. I must get the clampmeter out on some other diesel vehicles and see what gives.
"bypassing the isolator....in an emergency" You don't really need this built into the isolator. If you are in this uncommon situation, simply use jumper leads, or swap the batteries or put both isolator leads onto the one terminal. The latter is what we usually do when a solenoid isolator fails on a trip.
I thought plumbing and electricity had a lot in common! I just remember that laminar flow is proportional to the 4th power of the radius.
Cheers, and BTW, I'm now enjoying a red!
FollowupID: 712018
Reply By: Sailinghampster - Monday, Jan 10, 2011 at 10:01
Hi People of power,
Firstly an apology for the apparent ignorance in not replying sooner.
Life is just not the same here in Rockhampton at the moment. Something to do with the excess of water.
The caravan is sitting pretty in what I suspect is probably about a meter plus of water. I had it up on blocks so couldn't move it even if I could have gotten to it. (Parked at another property)
Meanwhile there is a lot to digest and I thank the posters very much. When Life settles down and the project gets back on top of the list I will have to digest all and see what happens. I have decided to keep things separated with no connection (Power Feed wise) between the ute and the van.
Thanks again.
Cheers all.
AnswerID: 441331
