Alice Springs to Karjini
Submitted: Saturday, Jan 22, 2011 at 08:25
Member - Turtle (VIC)
We are planning to travel from Alice to Karjini via wells 33 and 23 and
Newman. Any advice on the average time taken etc would be appreciated.
thanks - Ian
Reply By: Patrol22 - Saturday, Jan 22, 2011 at 08:41
Did most of this run but the other direction in mid 2009. Most of the road to/from Karajini are seal and in pretty good nick so no real problem. We travelled from
Marble Bar to
Carawine Gorge and this road also was in very good condition, as to was the Telfer
Mine Rd to Punmu. Punmu to
Well 33 was a little more corrugated but still 80kph running for the most part......then things went to custard. The Gary Highway from
Well 33 down to Everhard
Junction was serious corrugations and we averaged on many days aroun 25-30kph. One day the max distance we covered was 85 km. The Gunbarrel likewise hasn't seen a blade since old Len built it and I'm thinking the
Heather Highway is the same. Once down onto the
Great Central Road this were all good and the speed could be kicked back up to 80kph without a problem.
A word of caution - if you are running a modern vehicle fitted with a diesel particulate filter (DPF) - like I was - make sure you keep your revs above 1600 rpm for at least some significant parts of the day.....if the vehicle is not able to effect the auto regen of the DPF then it is a hell of a long trip from
Well 33 to the nearest dealer for a forced regen in limp home mode. Thankfully I was fully aware of this issue and was able to manage it effectively. Just one of the drawbacks of modern emission control systems and outback travelling.
442648
Follow Up By: Member - Turtle (VIC) - Thursday, Jan 27, 2011 at 07:35
Thanks for your advice. I'm running a Prado and will check out the filter situation.
Are you able to estimate the approximate time taken to travel from Karajini to
Well 33?
thanks - Ian
715248
Follow Up By: Patrol22 - Thursday, Jan 27, 2011 at 16:47
We took our time and rambled across here in a shad over 2 weeks but if you were time poor you could do it around 4 days.....without pushing the envelope too much.
I don't think you will have a DPF in the Prado as it is not yet built to Euro 5 standards.....it will come in the future though - unfortunately!
715275
Reply By: Member - John R (cQld) - Saturday, Jan 22, 2011 at 21:33
Hi Ian, Just thought I'd ask whether you really wanted to do the
Well 33 to 23 section of the CSR? Some big
sand dunes along that section. Via Punmu, Telfer
mine and
Marble Bar would be much easier.
Cheers, John
442749
