black ants
Submitted: Monday, Jan 24, 2011 at 17:40
Member - Karl G (NSW)
we have had our caravan stored for a year and it is full of black ants ,I used three bombs and two cans of surface spray and I think I am winning what else can I do ?thanks for your help
Reply By: achjimmy - Monday, Jan 24, 2011 at 17:49
Set some ant traps or ant cafes, these are preferable to spraying them. They take the sweet liquid back to there nest and it's designed to kill the entire nest. You can also place ant rid in small bottle caps, just remember that the liquid is not uv stable so you need to cover it. Very effective long term way to remove ants
442928
Reply By: Member - Norm C (QLD) - Monday, Jan 24, 2011 at 18:10
I use Amdro ant bait. It is small granules that the ants love. They take them and the active ingredient back to the nest and it wipes the colony out. Pretty expensive. Around $100 for 450 G container from memory. But it is a lifetime supply for your purpose. It may be available in smaller quantities, not sure.
When we first got our place in NT, we had lots of ants. Amdro did the job. Had not seen an ant in the house for months till we recently returned from being away for a few weeks. I put out one station and within 24 hours, no ants.
I put it out in small caps from the top of UHT milk cartons. Less than a thimble full per station. One or two bait stations around where they are active is enough. It works like a charm - and fast.
I bought it from Elders Rural Supplies. Should be available from similar sorts of
places.
Norm C
442930
Follow Up By: Gary.L - Monday, Jan 24, 2011 at 18:50
Second Amdro. Its the sort of thing that you share with you neighbours and friends as you only need a small amount, and it has a shelf life of about 3 months once opened.
Gary
714981
Follow Up By: westskip - Monday, Jan 24, 2011 at 19:34
Amdro I find is very, very efficient on what we in the West call coastal ants. They are extremely small ants and love to get under brick paving. Amdro does not work at all with our normal black ants.
714988
Follow Up By: Member - Norm C (QLD) - Monday, Jan 24, 2011 at 19:39
Yes, Amdro works on a range of ants, but not all. All specified on the label / instruction booklet.
It works on the full range of ants that seek to invade our home.
714989
Follow Up By: Member - Dunworkin (WA) - Monday, Jan 24, 2011 at 23:32
Hi westskip, we had a nest of black ants and I put some Mortein ant sand in the nest and they are all gone. I also use it for the little black ants outside. Inside I use ant rid. All works
well for me.
D
715015
Reply By: Rockape - Monday, Jan 24, 2011 at 18:41
Karl,
it may pay to check if the ants have built any nests behind switches, power points, or in your switchboard. They can certainly bugger up switches with their nests.
Happy hunting
442935
Follow Up By: Member - Phil 'n Jill (WA) - Monday, Jan 24, 2011 at 21:01
And in the loo too, if you have one. They gummed up my pump when I first purchased it.
Apparently any
water is an attraction.
G'luck - Phil
715002
Reply By: Member - DickyBeach - Monday, Jan 24, 2011 at 18:50
When I was a kid I remember Dad grinding together with a mortar and pestle a mixture of equal parts of Icing Sugar and Plaster of Paris and scattering the "powder" everywhere - the next morning there were dead ants all over the place, presumably constipated to death.
DickyBeach
442936
Follow Up By: Ozhumvee - Monday, Jan 24, 2011 at 19:09
That works
well for rats and mice too, throw a sprinkle of chocolate powder in as
Leave a dish of
water out nearby to ensure they don't go without a drink.
714986
Follow Up By: Brian Purdue - Monday, Jan 24, 2011 at 20:36
When I was a
young fellow many years ago Coopers Sheep Dip worked wonders. It was arsenic based.
714998
Reply By: Member - Karl G (NSW) - Monday, Jan 24, 2011 at 21:46
thanks for your suggestions I will try and get some amro I already have Ant rid,antsand and ant powder and they are still wandering around and hopefully they haven't attacked the switches or
toilet
442944
Reply By: Motherhen - Monday, Jan 24, 2011 at 22:46
As said, apparently wet areas do attract ants, and they can be the first
sign if
water damage under the skin. No first hand knowledge of this - just something to bear in mind and check on.
442949
Reply By: Member - mervyn p (VIC) - Tuesday, Jan 25, 2011 at 14:16
Hi Carl we had a attack of ants while we where in
Darwin last year it lasted about a week until someone put me on to dave gray ant and termite killer, we sprayed it once on all the legs an
wheels that came in contact with the ground, the very next day they where all gone, we purchased the bottle from Bunnings, it is a concintrate you mix with
water and spray where you need. cheers merv
442997
