merit sockits and hella
Submitted: Monday, Feb 21, 2011 at 17:49
ThreadID: 84520 Views:5938 Replies:2 FollowUps:7
Hi, just wondering if anyone could tell me if merit sockits and hella sockits are the same. Will one type of plug go into the other type of sockit.
cheers in advance
Reply By: ABR - SIDEWINDER - Monday, Feb 21, 2011 at 18:14
Yes they are the same.
They will interchange.
Derek from ABR
AnswerID: 446194
Reply By: Sand Man (SA) - Monday, Feb 21, 2011 at 18:24
Eli,
Maybe a little bit of extra clarification for you.
The Hella plug won't fit into a Merit socket, if the red collar is still on it.
The Hella plug will fit both a Merit or Hella socket with the collar removed, or a standard cigarette socket with the collar on.
They are a very good plug and socket and I have standardised all 12 volt equipment to suit this standard.
Bill.
Bill
AnswerID: 446195
Follow Up By: ABR - SIDEWINDER - Monday, Feb 21, 2011 at 18:29
Hi Bill
Yes I should have mentioned that.
There is also an adapter for cigar sockets.
Derek from ABR
FollowupID: 718515
Follow Up By: brett - Monday, Feb 21, 2011 at 18:31
Depends what you refer to as a Hella plug, the plug with the red collar is not what I'd call a Hella plug, Hella do make a combination cig/hella plug with this collar but what most people refer to as a Hella plug doesn't have this and is exactly the same as a Merrit plug. Narva also make an equivilant. Check out the hella and narva websites. Personally I wouldn't use any of the combination cig type plugs, they're not much better than a normal cig plug
FollowupID: 718516
Follow Up By: ABR - SIDEWINDER - Monday, Feb 21, 2011 at 18:37
Hi Brett
The red collar ones do snap into the socket so they do hold tight, granted they are not as firm as the non red collar type but then they are not fused. It is a bit of a trade of of fused v/s non fused.
Most fridge manufacturers use the red collar type because of the fuse and ability to be used in both hella and cigar sockets.
Derek
FollowupID: 718517
Follow Up By: brett - Monday, Feb 21, 2011 at 20:21
Derek, the red collar ones do snap in and are an improvement over a cig but I found even on my Waeco the plug got warm. Replaced it with a genuine Hella and inline blade fuse, much better setup.
FollowupID: 718531
Follow Up By: ABR - SIDEWINDER - Monday, Feb 21, 2011 at 21:00
Yes as long as you fit a fuse in the circuit that is great.
I use Anderson plugs on my fridge.
Derek
FollowupID: 718540
Follow Up By: Eli J - Monday, Feb 21, 2011 at 21:09
Cheers for feedback everyone. Very helpful indeed.
FollowupID: 718542
Follow Up By: ABR - SIDEWINDER - Monday, Feb 21, 2011 at 21:18
I know I will be asked why I have 2 cables running to the fridge.
One is for the 600W Pure Sine Wave inverter. I have it mounted to the dead space below the fridge handle on the other side and use a power board connected to it.
Image Could Not Be Found
Derek
FollowupID: 718549
