Kalgoolie Mechanic
Submitted: Sunday, Mar 27, 2011 at 11:09
Member - DasherOK
Stuck in Kalgoolie! Hi to all, we are in Kalgoolie on a 3 month trip from
Sydney to WA and back. My Pajero has developed a noise in engine bay. I think it is the
water pump. Does anyone know of a good mechanic in Kalgoolie as I'm not keen to proceed without someone looking at it. Any response would be appreciated as today is Sunday and I will look for help tomorrow.
Regards Dasher.
Reply By: Member - Toyocrusa (NSW) - Sunday, Mar 27, 2011 at 11:20
Hi Dasher. Can't help with a mechanic in that area but I am in the mechanical business and have seen a couple of these fail. I would suggest not driving it too far until you have it diagnosed as the damage that can be caused to the engine can be horrendous. If it is a higher mileage engine, say 150k and up I would get the full timing belt kit installed, (belt, idler pulleys and tensioner/pulley complete with the belt) as
well as the
water pump as I have seen the bearings in these pulleys fail as
well. Most bearing specailists keep them along with Repco. Don't forget to flush and replace the coolant too. Cheers,Bob
449347
Follow Up By: Member - DasherOK - Sunday, Mar 27, 2011 at 15:36
Thanks for that Bob.
721760
Reply By: Member - Andrew H ( - Sunday, Mar 27, 2011 at 12:41
Try Hadfeild Mechanical in Hopkins st Boulder (no association)
Andy
449355
Follow Up By: Member - DasherOK - Sunday, Mar 27, 2011 at 15:37
Thanks Andy, have you used them before? My other option is to go to the Mitsubishi Dealer in town tomorrow.
721762
Follow Up By: Member - Andrew H ( - Sunday, Mar 27, 2011 at 18:51
I do know Peter and he is an honest bloke that does a good job but he is always busy, always worth a try even if for a second opinion.
cheers and happy travels
721781
Follow Up By: dieseltojo - Sunday, Mar 27, 2011 at 22:19
We had a problem with one vehicel and the local Toyota dealer did a good job .Turns out a previous dealer had not assembled the front cv's etc correctly.
721816
Follow Up By: Kiwis Ross & Cushla- Monday, Mar 28, 2011 at 21:38
Under all circumstances DO NOT GO TO THE LOCAL FORD DEALER.They cost me over $2500 due to poor workmanship in overfilling my auto transmission and popping the seal......TWICE. Stay away.!!!!
721887
