Portable Toilet Chemicals
We've now decided to invest in a portable toilet, and after reading plenty of reviews, etc. we decided to get a Thetford Porta Pottie 365. Now that we have it, we need to use the correct fluid for it and it needs to meet certain conditions. Firstly, availability. Is it hard to obtain when out and about? Second, is it formaldehyde free and environmentally friendly? Third is cost, fourth is lubrication of the slide and seals, including the coating of the bowl (quick flush before use) to prevent "skiddies", fifth is good breakdown of waste and odour elimination rather than just "masking". To this end, we're looking at the Thetford range of fluids and also Biomagic, which claims to meet these requirements with the added advantage of being the same fluid used in both the top and bottom tanks thereby eliminating the need for two separate fluids. There may be other fluids as well. Are we looking in the right direction? With thanks.
Reply By: Fred G NSW - Monday, Jun 20, 2011 at 10:07
Lozza, I have the same loo, and have had it for about 4 years.
A lot of us here at ExplorOz just use the home brand napisan in the bottom tank. No smell, very cheap and available everywhere.
I used the Thetford chemicals at first, but the smell of the chemicals is very strong, almost overpowering, and you need to store the bottles outside the van.
After converting to napisan, I would never go back, it's that good, IMHO.
This has been discussed many times here recently.
Cheers Fred.
AnswerID: 457962
Reply By: kend88 - Monday, Jun 20, 2011 at 10:19
I bought the 10 litre double strength Biomagic about 3 years ago and it works very well and is quite cheap when bought in bulk.
However, when it runs out I will probably use the Woolies homebrand nappisan as from all accounts it is very good and most economical.
kenD
Bris
AnswerID: 457965
Follow Up By: gqturbo - Monday, Jun 20, 2011 at 20:44
same active ingredient too
brian H
FollowupID: 731331
Reply By: Lozza - NSW - Monday, Jun 20, 2011 at 10:28
Sounds good-oh, but does it lubricate the seals and the slide? Also I forgot to mention that a friend of mine from work reckons that once you start using something in your toilet, you stick with the same thing.
AnswerID: 457966
Follow Up By: Gone Bush (WA) - Monday, Jun 20, 2011 at 10:41
Lozza,
Use Woolies nappy cleaner.
Image Could Not Be Found
One capful per application with a litre or so of water in the tank first up, after that your own "water" is all that's needed.
Safe for septic tanks. Change every three days or less.
Make up a pistol grip spray bottle of water and a little washing up liquid to give the bowl some slipperiness. Number ONE rule: he who leaves skid marks cleans them up.
Use silicon spray on the seals every now and then.
FollowupID: 731273
Follow Up By: Fred G NSW - Monday, Jun 20, 2011 at 11:01
That's the stuff.
Also should add that give the unit a good clean, whenever possible, after emptying, such around the seals and the slide, whilst the 2 units are seperated.
FollowupID: 731276
Follow Up By: Priscilla G - Monday, Jun 20, 2011 at 11:36
How much Napisan type treatment to 10 ltr tank.
FollowupID: 731280
Follow Up By: Lex M (Brisbane) - Monday, Jun 20, 2011 at 11:43
Put a dash of washup detergent in the top tank. Morning fresh is what we use. Lubricates the seals etc. and a short flush before use to wet the bowl.
If you can't empty it in three days. give it another dose of nappy treatment.
The nappy treatment won't work successfully after other chemicals until the tank has been washed several times with strong solution of nappy treatment.
FollowupID: 731284
Follow Up By: Nomadic Navara - Monday, Jun 20, 2011 at 12:47
Priscilla - just a cap full from the container will do. If it starts to smell after a few days just give it an extra dose like Lex does.
The anti smell products do not lubricate the rubber bits. You need something like olive oil to do that.
FollowupID: 731287
Follow Up By: outsider - Monday, Jun 20, 2011 at 17:58
As others have mentioned the nappy treatment works well as does a squirt of detergent in the top tank and pre flush to help prevent the skids.
We did our first trip with a portaloo last easter and it all worked great.
I was actually dry reaching at the thought of emptying the holding tank but to my surprise it was not bad at all.
standard paper breaks down just fine and set it up in a cool shady place if possible
FollowupID: 731313
Reply By: landseka - Monday, Jun 20, 2011 at 12:09
As above, use the generic nappy treatment.
As for the dreaded skiddies...we lay a cross with two bits of toilet paper (Cottonelle works good on the PP) and, Viola..no skiddies!
Cheers Neil
AnswerID: 457974
Reply By: Member -Dodger - Monday, Jun 20, 2011 at 16:02
We also have been using woolies napisan type product and have had no problems at all for years.
As we use olive oil (not Popeye) for cooking a little smeared on the seals occasionally does the trick.
As said refurbish every three days.
The pottie will break down all very quickly when on the move and if all slides and lids are on correctly no odour or spillage will ensue.
How to use =
Or.Pottie
Cheers Dodg.
AnswerID: 457992
Reply By: CSeaJay - Monday, Jun 20, 2011 at 16:33
Second the generic nappisan
We had the loo inside our camper trailer as it was too clod to go outside ;-) and no smell whatsoever
We add some diswashing liquid to the top tank for flushing, keeps is slippery.
We start off with two capfuls of nappisan in the bottom tank and then a capful after a number two
CJ
PS I understand that if you started using chemicals, one needs to wash the loo very well as the nappisan do not react/function well when residual chemicals are present
AnswerID: 457995
Follow Up By: Member - maccax7 - Monday, Jun 20, 2011 at 21:16
Hi CJ, so you put 2 caps in bottom tank, how much in top tank? Is the capful necessary every time?
Macca
Looking forward to every weekend being a looong weekend
FollowupID: 731340
Follow Up By: Member - Min (NSW) - Tuesday, Jun 21, 2011 at 10:41
In our experience a capful is NOT necessary every time.
I understand the generic nappisan is quite environmentally friendly and the potti can be safely emptied into a longdrop if necessary. I have not done this but would be interested to hear if anyone has reliable information.
Min
FollowupID: 731380
Follow Up By: CSeaJay - Tuesday, Jun 21, 2011 at 11:57
No we don't put nappisan in the top tank. Just manually drop a capful in the bottom tank after a dropful of ****
Min is correct probably not required ebvery time but we do. You will soon see or smell if it is not enough and you can size or time your capfuls accordingly
CJ
FollowupID: 731386
Reply By: landseka - Monday, Jun 20, 2011 at 17:52
Another thing I just remembered. If you haven't used the loo for a while (a few hours or so) and / or it has travelled a bit a good idea is to crack the slide open a tad to de-pressurise the tank before you deposit a new lot in the bowl.
You don't need to be a genius to work out why...lol...DAMHIK
Cheers Neil
AnswerID: 458000
Reply By: Sand Man (SA) - Monday, Jun 20, 2011 at 18:21
Hi Lozza,
The reason why many folk use an alternative product than that supplied by Thetford is because the "green stuff", the chemical that goes in the waste tank, contains formaldehyde, a very nasty chemical.
When you buy the porta-potty you will receive a couple of small sample bottles of their chemical. My advice is to dispose of them carefully and use the Home Brand Nappysan, as has already been mentioned.
I first tried Bio Magic but it is not all that readily available, whereas the Nappysan is available at any Woolies supermarket.
As an added advantage, the nappysan can be used in a bucket to clean your "smalls" (ie undies, socks, etc.) while on the move.
Bill
AnswerID: 458001
Follow Up By: Lex M (Brisbane) - Monday, Jun 20, 2011 at 19:15
We use a jerry to catch the grey water from the sink. A dose of nappysan prevents odours with that also.
FollowupID: 731319
Follow Up By: landseka - Monday, Jun 20, 2011 at 21:06
That'll teach them for losing the war...lol
FollowupID: 731336
Follow Up By: Lozza - NSW - Tuesday, Jun 21, 2011 at 10:08
The Bio Magic pretty much had us sold, so how does it differ from Napisan? From what I've read so far, Napisan has Sodium Percarbonate as part of its active ingredients. Does the Napisan break down the solids as well as the Bio Magic and other treatments? Probably a silly question, because Napisan is, after all, a nappy treatment! And I suppose a top tank treatment would negate the Napisan, unless you use something else.
FollowupID: 731374
Follow Up By: Gone Bush (WA) - Tuesday, Jun 21, 2011 at 10:18
Lozza,
Woolies Nappy Treatment actually has a higher percentage of Sodium Percarbonate in it than Biomagic.
It's heaps cheaper too.
It works very well. I've been using it for years now, countless others have too.
FollowupID: 731376
Follow Up By: Gone Bush (WA) - Tuesday, Jun 21, 2011 at 10:20
And I meant to add: don't bother putting any additive in the top tank. It's not necessary. Just use water.
And the dose is ONE capful in the holding tank. Not 2 etc like in the post above.
If the tank hasn't been emptied in 3 days (and it usually needs to be due to volume alone) then add another capful.
FollowupID: 731377
Follow Up By: Lozza - NSW - Thursday, Jun 23, 2011 at 08:54
I was leaning heavily towards the Bio Magic, but as you said, it's not readily available. And the second factor is the cost. The only dealer on our part of the Central Coast that has it is Coromal Caravans and they sell it at $45 per litre or $99 per five litres. Not that we plan using the Porta Pottie that much, so the Bio Magic would probably last us half of forever! The only thing is the correct dosage. Thetford say 2 litres in the bottom tank with their stuff. And if I use dishwashing liquid and maybe also Tea Tree/Eucalyptus oil with water in the top tank, will they negate Woolworths Napisan alternative when I flush? Admittedly, the Bio Magic seems the less fuss alternative as such. But the cost!!
FollowupID: 731654
Reply By: Member - Bentaxle - Monday, Jun 20, 2011 at 19:39
Lozza
We have a Dometic Porta-loo in our CT and use tablets as deoderiser and they also break down the solids. The chemicals that are designed for use in porta- loos release a bacteria when in contact with water/liquid this bacteria and this is how chemical toilest work. Adding Napisan will kill the bacteria, as that is what they are designed to do. Whe have used our Porta-loo for about 6yrs initilly with a tent but lately with our CT and have never had any odour problems during use or when being transported in the back of the Patrol.
Mike
May the fleas of a thousand afghan camels infect the crutch of your enemy and may their arms be too short to scratch.
AnswerID: 458012
Follow Up By: Lex M (Brisbane) - Monday, Jun 20, 2011 at 20:34
Which tablets do you use? Some of the tablets have the same active ingredients as the Nappy treatment.
FollowupID: 731327
Follow Up By: Gone Bush (WA) - Monday, Jun 20, 2011 at 20:47
Bentaxle,
how wrong you are.
Napisan uses sodium percarbonate, the same active ingredient in Biomagic.
It breaks down to oxygen.
It is safe for septic tanks so it does not have any effect on bacteria.
You are the victim of commercial forces.
FollowupID: 731332
Follow Up By: Motherhen - Monday, Jun 20, 2011 at 21:34
"Chemicals" designed for portable toilets contain Formaldehyde - which is a nasty chemical in the environment, pickles the waste product rather that assisting it bio-degrade, and do not release bacteria. The so called green chemicals are usually based on Bronopol, which breaks down to release Formaldehyde.
Sodium Percarbonate is an effective and environmentally safe alternative to nasty chemicals.
FollowupID: 731347
Reply By: Motherhen - Monday, Jun 20, 2011 at 21:42
Hi Lozza
There is no need to use anything but water in the top tank; same as i use in my home toilet flushing tank. If desired, a little sodium percarbonate can be added to the top tank.
For those who have used a Formaldehyde or Bronopol based chemical then change to a environmentally friendly substance, you need to cleanse the tanks thoroughly as traces of the chemicals can counteract the workings of alternative treatment.
We still have the dreaded can of Formaldehyde that was passed onto us by the previous owner of our van, as disposal may be difficult. We started with Bio Magic but found Sodium Percarbonate more effective.
AnswerID: 458027
Follow Up By: Lozza - NSW - Tuesday, Jun 21, 2011 at 10:06
FollowupID: 731373
Follow Up By: Motherhen - Tuesday, Jun 21, 2011 at 13:38
Yes Lozza, use the same in the top tank (if anything). We had a musty odour when using Bio Magic but not when we changed to Sodium Percarbonate. As we only use our toilet when needed, it can be used once, then after a few days in parks using their toilets, it is not nasty when emptying. Also we don't feel so bad about tipping out one day's worth when the product is so much cheaper. However our main reasons for using Sodium Percarbonate (Woolworths or Coles nappy powders) are that it is safe to dump in septics or in a hole in the ground, and best of all, it works really well.
Mh
FollowupID: 731396
Follow Up By: Lozza - NSW - Wednesday, Jun 22, 2011 at 10:53
If using home brand Napisan, exactly what is the dosage for the bottom tank? The Thetford instruction booklet says so many mls of their product in 2 litres water placed in the bottom tank. And I was thinking of the posts mentioning putting a little dishwashing liquid in the top tank to: 1. Prevent skiddies and 2. Lubricate the seals. Will the dishwashing liquid negate the Napisan stuff? I was thinking of dosing the top tank with Napisan stuff and dishwashing liquid as well. And someone else mentioned using Eucalyptus or Tea Tree Oil in the top tank to put a pleasant frangrance in the bowl. And will that negate the Napisan? So many questions, but I want to get it right, first time. The toilet is new, hasn't been used yet.
FollowupID: 731529
Follow Up By: Motherhen - Wednesday, Jun 22, 2011 at 12:45
Hi Lozza
Instructions for nappy soaker is something like a half a level lid for a bucket with 7 litres. Our cassette is twenty litres, but would rarely get beyond half full before emptying, so i add a shake the equivalent of a capful dissolved in about a litre of water (dissolving not necessary if you are on the move). You can add more if needed if using for a few days. We have only ever used water in the flush tank. If you want a slippery surface nothing is slipperier that a nappy powder solution, so a splash around the bowl before use would help. A friend said she uses spray cooking oil. I doubt detergent would negate the nappy soaker, as it can be used in the washing machine with regular washing detergent. We lubricate the seal if it sticks with silicon spray - as per Thetford instructions, although some have said their instructions recommend olive oil.
Mh
FollowupID: 731537
Follow Up By: Gone Bush (WA) - Wednesday, Jun 22, 2011 at 12:47
Lozza,
one capful of powder in the bottom tank with about a litre of water.
Empty it after 3 days.
A pistol grip of water and detergent sprayed on the bowl will stop skidmarks.
Nothing in the top tank except water.
FollowupID: 731538
Follow Up By: Lozza - NSW - Thursday, Jun 23, 2011 at 09:07
Ok, I now have the message loud and clear. It'll be the Coles/Woolies nappy treatment mixed with an appropriate amount of water in the bottom tank. A small drop or so of Morning Fresh with wather in the top tank. Possibly a little nappy treatment in the top tank to augment the process. And olive oil/silicone spray for the slide and seals as req'd. A massive difference in price from the Bio Magic! Oh, two final questions. How long does it take to break down the solids? Just so I don't empty the unit too soon! And paper type. They recommend certain paper, not normal date roll.
FollowupID: 731655
Follow Up By: Lex M (Brisbane) - Thursday, Jun 23, 2011 at 11:07
We use cottonelle. Breaks down well. We've had no problems with it.
FollowupID: 731667
Follow Up By: Motherhen - Thursday, Jun 23, 2011 at 16:16
Hi Lozza
I can only say what works for us, and managing a caravan toilet is really not very different to managing one at home (we have our own septic system). I don't use anything but water to flush - either at home or in the caravan. I don't use any harmful cleaning products or additives in either. I use septic safe toilet paper both at home and in the caravan - and after all, toilet paper that is marketed here is septic safe; any brand yo choose will do.
With the movement of travelling, paper dissolves very quickly. If you are stationary for a few days cassette contents will not all break down into the smooth slurry it does with travelling, but still all pours into the dump point easily enough. If you are static for periods of time, you can always keep a plastic bag handy and dispose of the paper without putting it into the toilet. Incidentally, my daughter just spent a few days holidaying in Bali, and due to their primitive disposal systems, a bag beside the toilet for the paper was the norm.
Camping used to be simple, and still can be if we ignore the market forces trying to cash in one us.
Mh
FollowupID: 731695
