tohatsu m8b transportation
Submitted: Thursday, Jul 28, 2011 at 19:55
lon s
can anyone tell me how to lie my motor down in my ute .worried about oil in the head
Reply By: Shaker - Thursday, Jul 28, 2011 at 20:52
Ok, I give up! What is a Toshiba m8b?
If it is an outboard motor, keep the powerhead slightly higher than the gearbox & don't lay it on the gear lever side.
461190
Follow Up By: Madfisher - Thursday, Jul 28, 2011 at 20:58
I think the problem with 4 strokes is the oil can get into the cfombustion chamber if laid the incorrect way. Mind you they expect us to be mind readers lol
Cheers Pete
734886
Reply By: Wilko (Parkes NSW) - Thursday, Jul 28, 2011 at 20:53
Hi Lon,
Check on the side of the motor (generally the left side) for 2 lugs. This is the side to lay it down on.
Cheers Wilko
461191
Reply By: Sand Man (SA) - Friday, Jul 29, 2011 at 07:24
On both my 15HP Mercury 2 stroke and 5HP Mariner 4 stroke, the motor can be laid down on its side with the handle side face up.
461207
Reply By: jrzoo - Friday, Jul 29, 2011 at 08:45
Lon s
My Tohatsu 6 has a sticker on the side indicating you lay it down on the handle side , not the gearstick side. My Outboard mechanic says you will still probably get a bit of oil on start up - probably not a bad thing anyway!
461210
Reply By: BrigalowO - Friday, Jul 29, 2011 at 10:20
I carry
mine on an inexpensive custom made trolley which elevates the motor, and allows me to put it into and out of the Cruiser by myself, effortlesly.
I made it out of two cheap sack trolleys from Bunnings ($14each) I can send you an image if you want to contact me offline, or if I can sort this site out, I could post one up here.....?
Robert
461224
