Max tracks
Submitted: Friday, Sep 16, 2011 at 05:38
ThreadID: 89051 Views:2488 Replies:6 FollowUps:8
Hi ALL
I am wondering how many Max tracks do you think I will need,as I will be spending a fair bit of time on the beachand sand country in WA,at present I have two but after speaking to a few other people they have suggested that 4 may be a better option thanks Kebru
Reply By: Member - Phil B (WA) - Friday, Sep 16, 2011 at 08:40
Two is better than none but four is what I travel with nowadays after being stuck for three nights in one spot in Rudall River NP.
We were bogged and despite having a pair of MaxTraks we couldn't get out because rain kept falling and the the whole area we were bogged on, a treeless flat, turned to mush. The nearest high ground was about 800 metres away.
AnswerID: 465157
Reply By: Member - Vince M (NSW) - Friday, Sep 16, 2011 at 09:32
I started with two which was good & got you going in most places but found that with 4 it is that much better as all my drive wheels (diff locks) get the traction
Note: make sure you get the new design, it seams to be stronger, I cracked one of the old shapes a few weeks ago & now can not stack them for storage & the new replacement will not pack with them at all.
They work great in sand & mud even if it is a meter at a time some times
good luck
AnswerID: 465163
Follow Up By: garrycol - Friday, Sep 16, 2011 at 10:09
I bought two from ARB yesterday - how do I tell if I have the new ones or the old ones - ARB did not mention anything - I would assume the older ones should be cheaper.
Garry
FollowupID: 739135
Follow Up By: Member Al (Sunshine Coast) - Friday, Sep 16, 2011 at 16:32
Garry, the MKII model has keyhole-shaped hole to accept the proprietary mounting posts. The older model only has round holes.
FollowupID: 739159
Follow Up By: garrycol - Friday, Sep 16, 2011 at 17:46
Thanks for that - so I assume there are no other major differences - just checked mine has key hole holes.
Garry
FollowupID: 739166
Reply By: Crackles - Friday, Sep 16, 2011 at 17:05
"...how many Max tracks do you think I will need?"
If you have a tyre gauge & are willing to listen to the locals then None.
Cheers Craig............
AnswerID: 465195
Follow Up By: Member - Vern - Friday, Sep 16, 2011 at 20:47
Don't really agree with that statement Craig. Was out with a local running from Robe to Beachport and both running the suggested tyre pressure and had to use the max trax on the beach in a couple of spots to get his 4by(patrol) out of bog.
Cheers Vern.
Growing old not growing up
FollowupID: 739199
Follow Up By: get outmore - Friday, Sep 16, 2011 at 21:13
i agree
you say this guy was running suggested tyre pressures? suggested by who and what were they/
pretty obvios they were too high
if the sand really was that soft im assuming he was running 10-12 psi?
if not then the pressures were too high
FollowupID: 739202
Follow Up By: Crackles - Friday, Sep 16, 2011 at 22:57
Kebru asked if they are NEEDED. Clearly they are not as drivers have been able to recover themselves for years before they were invented and surprisingly still do. I've found plenty of other options for recovery in sand first & foremost tyre pressures. It still amazes me how often people won't let enough air out.
Cheers Craig .........
FollowupID: 739221
Follow Up By: get outmore - Friday, Sep 16, 2011 at 23:03
gotta say i could have done with some trax last weekend but that was in mud it would havebeen great to slip them underneath after jacking with the high lift rather than bits of lock and sticks etc
but sand yea low tyre pressures
I run low pressures and low speed on the beach
FollowupID: 739223
Reply By: Motherhen - Friday, Sep 16, 2011 at 19:56
Hi Kebru
All depends on what sort of beaches you are going onto. If you don;t plan to get stuck but want a safety back up, get two. If you go where you are more likely to get stuck, get four.
Being caravanners rather than 4wd adventurers, our pair were purchased just for insurance. Max Trax recommended getting four, but to save on money and space we just got two. With 7½ tonne over eight wheels down in the stones (so hard to dig in) at Carawine Gorge and tyre pressures as low as we could risk, i unpacked the pair of Max Trax. Like magic.
AnswerID: 465220
Reply By: Litlbalt - Saturday, Sep 17, 2011 at 22:32
You on your own or running with another vehicle ?? I believe in the Buddy system for most things including 4WD'ing. A set of 2 per vehicle will have you all sorted
2 will get you out of most issues , unless of course you were very slow in admitting your bogged and your lockers have just increased your tyres digging ability
If your towing anything then yes a second set would definitely be recomended
AnswerID: 465312
Reply By: Fatso - Sunday, Sep 18, 2011 at 19:14
I think Kebru should get 4.
4 is better than 2.
For starters it puts you 2 up on people who only buy 2.
Then it puts you 4 up on people who have none.
With 4 you can put 2 on each side of your roof rack & no matter what side you pass people on they will see your tracks.
If you put them both on one side you never know if the people you are trying to impress are going to see them. There is a 50% chance they wont see them. But you also have a 50% chance of someone seeing 4 at once if you put them all on the same side & that would be cool.
If you you only buy 2 & put one on each side you will surely be ridiculed because everybody will think you only have one.
Remember "IMAGE IS EVERYTHING", so you gotta get 4.
AnswerID: 465401
Follow Up By: Crackles - Sunday, Sep 18, 2011 at 20:03
You're a bad lad Fatso :-))
FollowupID: 739435
