Long range fuel tanks - Nissan Patrol
Submitted: Tuesday, Oct 25, 2011 at 11:53
Member - Kiwibound eventually
We have a 2010 Patrol GU and I am contemplating installing a long range
fuel tank to give us greater distance between fills and more consistency in pricing. We are currently in South Australia and are looking for advice from people who have installed long range tanks as to who they used, the type of tanks and the costs involved.
We have had a couple of quotes and these have varied from $2000 to $3,500. Any help or advice would be appreciated. We have also posted this question on the Nissan
forum but felt that readers towing a caravan may
well be in a position to provide a prospective from experience. Thank you.
Reply By: Robin Miller - Tuesday, Oct 25, 2011 at 12:46
Hi Kiwi
Diesel /petrol
I have 2 GU 4800 petrols , the 2010 one comes with no sub
tank and I fitted with 75lt LRA
tank - quite good , a little slow to fill though as filler not as big , this version uses external
fuel pump , and a cute little 5 LED
fuel guage.
Total useable
fuel is 165 lt or about 1000km touring
On my 2002 model , it came with sub so I got 145lt main instead giving 175lt total. No issues at all it gives about 1100km touring range.
If I can ever decide which one I like most I will fit both tanks to it giving 210lt however in practise we have been able to carry 300lt , sufficent to do such hard tracks as Madigan - so maybe won't bother.
Get good tanks not cheapies.
468509
Reply By: Member -Dodger - Tuesday, Oct 25, 2011 at 16:24
We tow a van with our GU 4.2td Patrol.
Fitted was a Long
Ranger 90ltr replacement
tank where the sub
tank goes which gives us a total of around 150ltrs without running dry.
The reason for the sub
tank replacement was to balance the vehicle rather than have the larger
tank on the rear together with the ball load.
We were fortunate as the installer, Opposite Lock in Dubbo managed to get the sub
tank gauge to read correctly,
This has also gave us a good range depending on roads and terrain.
Up to 1200 KLms when all goes
well and not towing & when towing 800 klm's + .
Both tanks are filled easily by the truck bowsers.
468517
Reply By: Mick O - Tuesday, Oct 25, 2011 at 17:16
I've had all the major brands (LRA, Long
Ranger and Brown Davis) in three vehicles over the years. Had issues with them all. If you're towing and not doing super rough stuff, you should never have a problem. The atrocious conditions of the outback tracks these days will soon take their toll on any accessory so beware.
Some good info in this search string
Long Range Tanks
and this outlines some issues I've had in the past.
The Talawana tank incident!
Cheers Mick
468520
Reply By: cookie1 - Tuesday, Oct 25, 2011 at 21:24
I have a December 2009 GU 3TD and have my auxillary LRA long range
tank which is out of my previous 2002/3 GU 3TD and it has been across the Simmo 3 times +
Cape York + Flinders +
Robe +
Birdsville + Innaminka +++ and it is still holding up very
well. Brad Newham from ARB Elizabeth installed it and I get exactly 70L out of it - it takes 70L.
I release
fuel from the auxillary once the main
tank starts emptying to about 1/2 way
Just my experience
Colin
468547
Reply By: Member. Rob M (QLD) - Tuesday, Oct 25, 2011 at 21:34
Hi Peter,
I had a long range
tank fitted to my 2002 petrol 4800 patrol manufactured by
4WD Systems in S.A.
I have heard some comments on their quality that are not very flattering, but I had no problem with the
tank in the 240000 klm I travelled with it.
I also had a Lokka supplied, and I think manufactured by them fitted to a 97 patrol also with no problems and the phone support was very good.
Since you are in S.A. it might be worth a look.
468549
Reply By: Fatso - Tuesday, Oct 25, 2011 at 21:40
G'day Peter
You don't need to be an accountant to figure out there is going to be no cost saving by spending $2000 or more on a
fuel tank to save on
fuel.
If you can save 20 cents a litre you are going to have to do that for 10,000 litres just to break even.
At 5 km/l economy towing a van you will have to travel 50,000 km on cheap
fuel to get there.
At 8 km/l without towing you have to do 80,000 on cheap
fuel.
I don't think you are going to do that.
468551
